Blade profile/grind style preferences?
Discussion in 'Edged Tools' started by SwissArmyKnife, Mar 4, 2013.
  1. SwissArmyKnife
    SwissArmyKnife Scout
    Jul 23, 2012
    647
    Westville, OK
    I've got a few knife ideas in my head and am curious about your preferred grind for various activities.
    What grind (flat, convex, micro-bevel...) do you prefer for:
    Every day use
    Batoning
    Field dressing, cleaning game
    Cutting material
    Carving
    Fine carving
    Feather sticks/shavings
    Holding an edge
    Freehand Sharpening
    Other uses not listed.
    *EDIT*
    Also, a brief summary as you why you like each type for a given activity would be appreciated. Thanks
  2. Iz
    May 2, 2009
    29,222
    870
    The outlaw state
    Every day use: convex
    Batoning: convex
    Field dressing, cleaning game: convex
    Cutting material: convex
    Carving: convex
    Fine carving: convex
    Feather sticks/shavings: convex
    Other uses not listed.: convex
    :D:5:
  3. SwissArmyKnife
    Jul 23, 2012
    647
    Westville, OK
    Lol, I think there's a pattern there. Thank you. I'd also like to know a bit about why you like it better. I'll edit my first post.
  4. darkwolf777
    darkwolf777 Tracker
    Jan 25, 2013
    152
    Central Louisiana
    LMAO. Iz, do you like a convex grind or would you rather the Convex grind? We could always order you one with the conVex grind so you could have a selection. JK:16:
    Me, I like them all and can use most grinds for most chores: except fine carving and that's because I can't carve fine, but for everything else, whatever I have I make it work. Oh and Iz likes his a little on the anti-hollow ground side:38: (sorry Iz, just had to, I'm still laughing a little).
  5. MtnManJoe
    MtnManJoe Guide
    Nov 7, 2010
    3,189
    19
    PNW (N Oregon Coast)
    uh - You are stuck in a rut .. have you ever considered trying a 'convex' grind?
  6. shonuffisthemaster
    shonuffisthemaster Scout
    Jan 11, 2010
    201
    Isanti, MN
    this is an intresting post, really got me thinking.
    Every day use -
    I carry a Mora craftline robust daily, mostly because its cheep and I don't mind if it gets lost, damaged, etc., its also easy to maintain a good edge on a scandi grind. when I'm out in the woods though, I either carry a convex or FFG, mostly because thats what the slightly larger knives i like come in, i would say my preference is FFG with a single primary bevel and no microbevel, its easier to sharpen in the field without a microbevel.
    Batoning -
    for baton splitting I would go with convex for the slightly more robust edge and better wedging action, after that i would pick a saber grind for the same reasons. for baton cross cutting it would be FFG with a single primary bevel and microbevel, because it will bite in more redily but is still a bit sronger.
    Field dressing, cleaning game -
    I like a Mora because its easy to get a really good edge on it, otherwise i dont see much difference in this task, as long as its sharp
    Cutting material -
    anything will do imo
    Carving -
    FFG with small primary bevel, it makes for the best slicer and imo the best for carving too, second choice would be convex, i don't like scandi's all that much for carving as i feel there is a bit of wedging action that takes over the cut that I don't like, but they certainly will work. a thin ffg with a small bevel wedges into the wood less than either a scandi or convex, thus it makes more accurate cuts imo
    Fine carving -
    same as above
    Feather sticks/shavings -
    everything is about the same imo, except i would say a really thick blade with a scandi grind dosent work verry well because of the angle you have to hold it at to carve, and that angle tends to make it want to bite int. this is why i would say
    Holding an edge -
    really just depends on what your final angle is, not much difference really. this is a misconception i think people have about different grinds, they think this or that grind is "sharper" or "tougher" or cuts better, when in reality it just depends on the angles involved and the geomitry, even with a convex edge there is a final "angle", i think the tendincy is to profile different grinds differently, and that is why they get there different reputations.
    Freehand Sharpening
    definatly a scandi for ease of freehand sharpening, but its also the most labor intensive to sharpen due to the wide bevel / allot of steel to abrade, i would say followed closely by convex, very easy and natural to sharpen by hand, and Flat ground with a wider bevel is my third choice. i have found it pretty difficult to put an accurate "true" microbevel on by hand, especially in the field, and re sharpening a microbevel by hand accuratly is verry difficult
  7. MJGEGB
    MJGEGB Guide
    Jan 2, 2013
    2,434
    2,506
    Portsmouth Virginia
    Every day use: FFG good all around grind with a good balance of strength and cutting ability.
    Batoning: Scandi or Scandivex, I find that there tends to be less binding as the bevel directs the wood away from the blade.
    Field dressing, cleaning game: FFG a good slicer that won't chip easily.
    Cutting material: FFG again good all around.
    Carving: Scandi because the wide flat bevel gives good control or an FFG if that's what I have.
    Fine carving: I wouldn't call my carving fine but we'll say same as above but smaller blade size.
    Feather sticks/shavings: same as carving.
    Holding an edge: This depends more on the steel/HT IMO but I give a slight edge to the FFG.
    Freehand Sharpening: FFG I'm the odd man out here I only free hand and after years of doing blades with secondary bevels I am used to it where as a Scandi grind is rather new to me and I've only recently learned how to sharpen them. Because there is less material being removed I find the FFG takes less time.
    Other uses not listed: If you had not figured it out I like the FFG it fits my keep it simple ideology and can anything well. I have come to apreciate the scandi grind but it doesn't cut it with some tasks such as slicing.
    As for the blade shape I like I prefer a simple drop point nothing drastic; enough to get the benifits of a natural distal taper a strong tip and still keep a very useful point on the knife think Mora or ESEE.
  8. shonuffisthemaster
    Jan 11, 2010
    201
    Isanti, MN
    Thats pretty similar to my philosophy too, and i love the esee's! I learned how to sharpen on ffg and for a long time thats all i carried. Im a fairly recent (last couple years) mora convert too.
  9. SwissArmyKnife
    Jul 23, 2012
    647
    Westville, OK
    Forgive me for asking, what does FFG stand for? Also, since I thought a scandi was a flat grind (shows how much I still have to learn), what's the difference between them?
  10. MJGEGB
    MJGEGB Guide
    Jan 2, 2013
    2,434
    2,506
    Portsmouth Virginia
    Full Flat Grind; a Swiss Army knife normally comes with a FFG blade. A Mora (scandi) has no grind really just the edge bevel where as if you look at a SAK you will notice that it was first ground to a v shape (thiner near the edge thicker at the spine) then a secondary or edge bevel was put on to make it sharp.
  11. DanielKrier
    DanielKrier Scout
    Feb 23, 2013
    252
    South Jersey
    Scandi grind for fine work, convex for just about everything else.
  12. Prairiewolf
    Prairiewolf Guide
    Jun 18, 2012
    1,205
    160
    Illinois
    I saw an ad for a Enzo Trapper D2 with what looks like FFG. Anybody have any experience with this?
  13. Bax 40
    Bax 40 Supporter Supporter
    Oct 25, 2010
    7,449
    3,321
    Arkansas
    I think you have a convex fixation!!:cool:
  14. chiefs50
    chiefs50 Banned Member Banned
    Dec 30, 2009
    737
    A convex for wood carving? You have to be kidding.
    Every day use - Convex
    Batoning - Convex
    Field dressing, cleaning game - Size and shape of blade are more important than type of grind. My Buck 110 has field dressed many Whitetail Bucks. It is hollow ground and works well for this purpose. For small game I use my old Marble's Bird and Trout knife.
    Cutting material - depends on type of material. Light stuff probably a Scandi grind. For heavier stuff, a convex.
    Carving - There is no room for discussion here. All carving knives are Scandi grind. Ask the Swedes, Finns, Norwegians, or just about any wood carver.
    Fine carving - See above.
    Feather sticks/shavings - Scandi Grind
    Holding an edge - Convex
    Freehand Sharpening - Scandi. Simple, just follow the angle. Easy to do in the bush.
  15. S.Gossman
    S.Gossman Guide Vendor Supporter
    Jan 12, 2010
    3,124
    2,936
    God's country, Maryland
    I'm with Iz. There's nothing I can't do with a convex grind. It can be adjusted (primary grind and edge) to do all of the listed tasks.
    Scott
  16. knifeman85
    knifeman85 Scout
    Oct 13, 2012
    520
    Tensaw River Delta
    Scandi or 1/2 flat,because the thinner blade profile seems to carve wood and process game a littile easier than a thicker blade.I also have exellent results batoning with these edges.For me I can sharpen these profiles easier.
  17. RoundBear
    RoundBear Banned Member Banned
    Aug 25, 2010
    691
    Middle Tennessee
    Every day use: depends on the day, lol. Lately its been a pro ground knife.
    Batoning: convex but prefer to use an AXE for splitting wood.
    Field dressing, cleaning game: hollow
    Cutting material: pro grind
    Carving: pro grind or scandi
    Fine carving: pro grind or scandi
    Feather sticks/shavings: scandi
    Holding an edge: rockwell hardness plays the main role in this.
    Freehand Sharpening: pro grind
  18. SwissArmyKnife
    Jul 23, 2012
    647
    Westville, OK
    Im learning alot of useful information on this thread, as I'm sure many lurkers are as well.
    So what's "half flat" and "Pro-Grind?"
  19. Seeker
    14,487
    6,122
    Every day use: I'd prefer my SAK's natural grind, but i can't sharpen flat, so it's convexed. but most of what i do on a daily basis involving my EDC knife would be better done with a scandi/flat grind.
    Batoning: I don't baton with my knives. That's what a hatchet is for. If I did it, I'd prefer a convex.
    Field dressing, cleaning game: Convex.
    Cutting material: scissors, or doesn't matter.
    Carving: scandi/flat
    Fine carving: scandi/flat
    Feather sticks/shavings: scandi/flat
    Holding an edge: this is largely dependent on the steel, not the grind.
    Freehand Sharpening: convex. i can't sharpen a flat/scandi freehand worth a flip.
  20. HoboTree
    HoboTree Guide
    Feb 11, 2013
    1,237
    13
    State of Jefferson
    all around I prefer convex edges but scandi grind is nice too.
  21. ED-E
    ED-E Banned Member Banned
    Jun 19, 2011
    113
    Europe
    Every day use:Scandi/Flat
    Batoning:Scandi/Flat
    Field dressing, cleaning game: Scandi/Flat
    Cutting material:Scandi/Flat
    Carving:Scandi
    Fine carving:Scandi
    Feather sticks/shavings:Scandi/Flat
    Freehand Sharpening:Scandi/Flat
    Other uses not listed: Scandi/Flat
    Because I sharpen freehand and strop my knives after, they nearly all have developed a convex micro bevel.
  22. Mr.LCV
    Mr.LCV Knife Snob
    Mar 7, 2013
    4,968
    38
    Northern Michigan
    Ditto
  23. shonuffisthemaster
    Jan 11, 2010
    201
    Isanti, MN
    Thats just not true, allot of flexcut knives are not scandi, if im not mistaken quite a few wood carvers use those, so if you ask those wood carvers......
  24. Foilist
    Foilist Scout
    Dec 29, 2012
    931
    301
    Connecticut
    I like a flat grind for all around use, due to its slicing ability and ease of sharpening.
    That said, I don't shy away from other grinds if I otherwise like the knife.
  25. donal
    donal Banned Member Banned
    Sep 5, 2010
    478
    I'm not about to split all the hairs
    and differences in grind bevels, angles, or an 'appleseed' edge; being the lack thereof, or methods, and grits. I sharpen to the typical use... leather, wood, rope, ect. If I have to chop something with a tool, it gets heavier bevels/convexing, and maybe a different degree of polish, at the completion of sharpening. I use India stones, files, diamond sticks, and sometimes stropping using one of two rouges to get the edge I need. I have a Belgian blue stone, needs truing BAD; and a beautiful black Ark. stone, for an absolute polish, before stropping. I test my edges by filleting the paper off of a cigarette, sometimes doubling it back, with thinner knives, at a higher polish. Best field sharpener IMO, is the Eze-Lap Model 'M'..not perfectly coated, evenness-wise, but they work, and will not break, and they're compact.
  26. MtnNomad
    MtnNomad Guide Bushclass I
    Jun 5, 2011
    1,397
    NC Mtn's
    Convex for me.
  27. SwissArmyKnife
    Jul 23, 2012
    647
    Westville, OK
    I found a good wiki Page on grinds image using for reference now with this thread.
    http://en.m.wikipedia.org/wiki/Grind#section_2
    1. Hollow grind — a knife blade which has been ground to create a characteristic concave, beveled cutting edge along. This is characteristic of straight razors, used for shaving, and yields a very sharp but weak edge which requires stropping for maintenance.
    2. Flat grind — The blade tapers all the way from the spine to the edge from both sides. A lot of metal is removed from the blade and is thus more difficult to grind, one factor that limits its commercial use. It sacrifices edge durability in favor of more sharpness. A true, flat ground knife having only a single bevel is somewhat of a rarity.
    3. Sabre grind — Similar to a flat grind blade except that the bevel starts at about the middle of the blade, not the spine. Also named "Scandinavian Grind", it produces a more lasting edge at the expense of some cutting ability and is typical of kitchen knives. Also sometimes referred to as a "V Grind", made with strength in mind and found on tactical and military knives. The Finnish puukko is an example of a scandinavian ground knife.
    4. Chisel grind — As on a chisel, only one side is ground (often at an edge angle of about 20 – 30°); the other remains flat. As many Japanese culinary knives tend to be chisel ground they are often sharper than a typical double bevelled Western culinary knife. (A chisel grind has only a single edge angle. If a sabre grind blade has the same edge angle as a chisel grind, it still has two edges and thus has twice the included angle.) Knives which are chisel ground come in left and right-handed varieties, depending upon which side is ground. Japanese knives feature subtle variations on the chisel grind: firstly, the back side of the blade is often concave, to reduce drag and adhesion so the food separates more cleanly; this feature is known as urasuki. [2] Secondly, the kanisaki deba, used for cutting crab and other shellfish, has the grind on the opposite side (left side angled for right-handed use), so that the meat is not cut when chopping the shell. [3]
    5. Double bevel or compound bevel — A back bevel, similar to a sabre or flat grind, is put on the blade behind the edge bevel (the bevel which is the foremost cutting surface). This back bevel keeps the section of blade behind the edge thinner which improves cutting ability. Being less acute at the edge than a single bevel, sharpness is sacrificed for resilience: such a grind is much less prone to chipping or rolling than a single bevel blade. In practice, double bevels are common in a variety of edge angles and back bevel angles, and Western kitchen knives generally have a double bevel, with an edge angle of 14-16° (included angle of 28-32°) and a maximum of 40° as specified by International standard ISO 8442.1 (knives for the preparation of food).
    6. Convex grind — Rather than tapering with straight lines to the edge, the taper is curved, though in the opposite manner to a hollow grind. Such a shape keeps a lot of metal behind the edge making for a stronger edge while still allowing a good degree of sharpness. This grind can be used on axes and is sometimes called an axe grind. As the angle of the taper is constantly changing this type of grind requires some degree of skill to reproduce on a flat stone. Convex blades usually need to be made from thicker stock than other blades. [1] This is also known as hamaguriba in Japanese kitchen knives, both single and double beveled. Hamaguriba means "clam-shaped edge". [citation needed]
    It is possible to combine grinds or produce other variations. For example, some blades may be flat ground for much of the blade but be convex ground towards the edge.
  28. skbenton
    skbenton Tracker
    May 3, 2012
    185
    Knife grind you prefer
    What is your preferred knife grind? Scandi, convex, hollow, etc...
    And why?
    Sent from my DROID RAZR HD using Tapatalk 2
  29. Murphnuge
    Murphnuge Scout
    Jul 29, 2012
    397
    S. Indiana
    Flat grind, strength and simplicity.
  30. Mr.LCV
    Mr.LCV Knife Snob
    Mar 7, 2013
    4,968
    38
    Northern Michigan
    Hasn't this been done? Convex it works and easy to maintain
  31. GrandLarsony
    GrandLarsony Guide
    Jun 15, 2012
    1,395
    Rochester, NY
    And slicing ability. FFG totally my fav.
  32. Mr. Tettnanger
    Jul 14, 2010
    7,120
    1,783
    SE Pennsylvania
    A sharp one!
  33. Yevoc1
    Yevoc1 Supporter Supporter Bushclass I
    Nov 26, 2012
    1,591
    191
    S. Indiana
    Scandi or Saber!
  34. Bax 40
    Oct 25, 2010
    7,449
    3,321
    Arkansas
    Convex of course!
    Larry
  35. Paul Foreman
    Nov 20, 2012
    6,334
    2,211
    the scandi grind on my mora bushcraft black (as opposed to the scandi grind angles on my other moras), and the full flat on my grohman no. 1 stainless ...
  36. Thump
    Thump Tracker
    Aug 26, 2013
    129
    Sweden
    Scandi grind with a small secondary convex bevel for my home knifes ( kitchen, working in the yard etc)
    Full flat grind with a convex secondary bevel for the woods.
    Hollow when used for leather work, razorblades etc.
  37. wingnuts
    wingnuts Guide
    Feb 1, 2012
    2,288
    325
    NJ
    Full flat! But I have tons of knives with different grinds.
  38. JV Rooster
    JV Rooster Guide
    Jan 4, 2013
    1,222
    PENNSYLVANIA
    Full flat grind for me.
  39. GreatLakesWoodsman
    GreatLakesWoodsman Scout
    May 1, 2013
    857
    280
    West Michigan
    Full Flat or scandi
  40. FortyTwoBlades
    FortyTwoBlades Banned Member Banned
    Jul 31, 2011
    4,765
    Full flat primary with a thin convex edge to reduce the shoulder transition.
  41. Sanjuro
    Sanjuro Tracker
    Aug 25, 2012
    158
    Central Texas
    There is no perfect grind IMO. Each one has it's pros/cons, and a time and place.
    Camp and Bushcraft: Scandi or Convex. I slightly prefer convex most the time.
    All-purpose blade and EDCs folders: Full flat grind
    Hunting and Skinning: High hollow grind.
  42. outdoorsintx
    outdoorsintx Scout Bushclass I
    Jan 1, 2012
    258
    12
    Fort Worth, TX
    The convex grind I maintain on my Condor Bushlore works for the applications I put it too, like splitting wood for fires and beating it through stuff. However, the scandi grind on my Mora 120 carving knife is great for the applications I put it to. What application are you considering when you ask the question?
  43. PaulK
    PaulK Banned Member Banned
    Aug 25, 2011
    1,383
    Tucson, AZ
    Flat, convex and scandi. Each has its benefits. Not a big fan of hollow ground but in a pinch I can make any grind work for general cutting duties.
  44. skbenton
    skbenton Tracker
    May 3, 2012
    185
    General bushcraft and camping...still on my eternal search for the"light sabre"
  45. Nih
    Nih Scout
    Dec 8, 2012
    386
    Pacific Northwest
    It depends on the knife and what I'm doing with it. However, most of my knives end up with a slight convexity after I've sharpened them a few times due to my method of sharpening.
  46. Longbow29
    Longbow29 Tracker
    Jul 8, 2011
    197
    Back in the Piney Woods
    I like a rolled point edge, similar to a Japanese sword, or the old Blackjack Anaconda....But for ease of sharpening it is hard to beat a Scandi - edge.
  47. Iz
    May 2, 2009
    29,222
    870
    The outlaw state
  48. turtlepwr281
    turtlepwr281 Hobbyist Hobbyist
    Jan 17, 2013
    1,036
    199
    SE Pennsylvania
    For shaving my face...hollow.
    For everything else...leaning very heavily towards convex with varying degrees of secondary bevel.
  49. woodsghost
    woodsghost Guide
    Aug 6, 2011
    2,317
    12
    Lincoln, NE
    The answer to what grind YOU prefer is: get out there and play with your knives! :) Try them all, and see what you keep returning to.
    You have a pretty good sample here of what people like.
    I prefer different flavers of convex. Most of my blades are some version of a full flat primary with convex secondary, with different levels of shallow or obtuse curves. I have a few that are basically full convex. I have one hollow ground primary bevel with a convex secondary, that rocks my world (old model Ka-Bar Warthog). Sometimes I have to put a micro bevel on even my convex blades! I think I am hard on knife edges, but there might be other factors at work (steel type, heat treats, way I use my knives, etc).
    On one carving knife, I have a scandi, which I like. I think I will keep that one a scandi and only use on soft woods.
    Have fun with those knives in the woods! :50:
    Iz: thanks man for putting that together!
  50. TheWanderer
    TheWanderer Banned Member Banned
    Aug 29, 2013
    541
    Slightly convexed Scandi (seems easiest to sharpen for me) or convexed
    BTW: Hello all, new to the forum
