Blueing My Mora Knife - Applying a Rust Resistant Coating using Vinegar
Discussion in 'Self-made Gear' started by MungoSaysBah, Dec 18, 2009.
  1. MungoSaysBah
    MungoSaysBah Tinder Gatherer
    Dec 15, 2009
    Toronto, Ontario, Canada
    The other night I was cleaning up my Carbon Steel Mora with a bit of fine sandpaper - the metal tends to discolour with regular rough use. The surface became nice and clean, nice and shiny, but I wanted to try to keep the surface protected. In lieu of spraying it with messy WD40, I thought I would oxidize the surface to get Black Rust to create the result known as Bluing. Creating Black Rust (magnetite Fe3O4) is known as bluing - a process in which steel is partially protected against Red Rust, and is named after the blue-black appearance of the resulting protective finish. Black rust effectively coats the iron/steel and prevent oxygen from reaching the underlying metal. The red rust you normally see is (Fe2O3).
    Previously I have spread regular mustard onto the blade, wrapped it all in plastic food wrap, and left it overnight. Being somewhat worn out after work, and thinking about the 10 stairs I would need to ascend to reach the mustard in the kitchen, I decided instead to grab some vinegar from the cold room in the basement and fill a Nalgene partially with a 50/50 solution of vinegar and water.
    I put the knife up to the hilt in the liquid and left it for 36 hours.
    I took it out, wipped it with a paper towel and lo and behold I had a nice, rich looking patina. My fingerprints were evident in the coating - next time I will clean the blade with a bit of methanol etc... prior to treating it.
    Although I didn't take any photographs of the metal prior to treatment, I am comparing it with a laminated steel Mora (the blade contains rich carbon steel in the middle - hardness about 59/60, sandwiched between slightly tougher, lower carbon steel laminate strips).
    Cheers,
    Mungo
  2. Okbushcraft
    Okbushcraft Guide
    Oct 2, 2009
    2,860
    Oklahoma
    Thanks! May play around this. John.
  3. snakedoctor
    snakedoctor Deceased
    Jul 26, 2009
    6,266
    missing the salt of FL
    Thats a great job! I like it!
  4. pocomoonskyeyes
    pocomoonskyeyes Guest
    Too bad you were tired. I like the "patterning" you can do with Mustard. But I only left it on my blade for about 6 hours. Does it really need to stay so long?
  5. MoxemDeliph
    MoxemDeliph Guide
    Nov 2, 2009
    1,367
    Depends on the design you want. I usually play with "splotching" rainbow colors with it and get neat effects within several 25 minute sessions. It gives a bit of a swirl and layered look depending on how its applied. I like both mustard and vinegar.
    If you get three gallons of vinegar and freeze them, the juice that isnt froze is concentrated and when combined, by my math, equals a hefty 35% acid solution. I get good,deep results with it. You will not get much out of three gallons though, as its only 5% acid when you buy it...so you get about 16 ounces out of three gallons.
  6. tnrick55
    tnrick55 Banned Member Banned
    Oct 22, 2009
    2,263
    INDIANA,BLUFFTON
    very usefull post thanks.adding to this post im trying it now lets see what happens.
  7. wolfy
    wolfy Guest
    Pardon me,.....but would you have any Grey Poupon!
  8. KuRUpTD
    KuRUpTD Guide
    Dec 8, 2009
    1,720
    Brooklyn, New York
    Looks good ... I may have to try that on my Mora.
  9. Sgt. Mac
    Dec 11, 2008
    53,536
    64,337
    Land of Lincoln
    Thats a great idea,and Demo
    Thanx
  10. FrauHilda
    FrauHilda Guide
    May 29, 2009
    1,035
    MT
    When restoring an old blade, you can clean all of the rust off with fine steel wool or a scotch-brite type kitchen scrubber and some Bar Keeper's Friend, and then force-patina again this way.
    I have always used straight vinegar without diluting - so I will give that tip a try.
    A light oiling after this treatment and you will NOT get rust unless you leave the knife wet for several hours, even then, the red rust usually just wipes right off.
    After honing my kitchen knives, I'll run the edge through a lemon and then just dry without washing - that will bring the patina down to your edge again. If you keep the oil to a minimum, you also keep that nice, flat black, 'parkerized' look.;)
    This will oxidize with certain foods so beware. Harmless, but will turn.. say eggs for example, a most unappetizing shade of grey.
    Thanks for the demo and tips Mungo. :)
  11. Iz
    May 2, 2009
    29,222
    870
    The outlaw state
    Nice stuff, man.
    Naval jelly works pretty good, too.
    Iz
  12. FrauHilda
    FrauHilda Guide
    May 29, 2009
    1,035
    MT
    I just wanted to add to my above post and clarify that when I said "restore" I meant a utility blade, like vintage kitchen cutlery, or a rusty old garage sale find etc.
    I wouldn't presume to offer suggestions for the restoration of fine antiques, custom, or otherwise priceless blades. ;)
  13. Jason
    Jason Founder Staff Member Administrator Vendor
    Sep 15, 2008
    5,771
    191
    Missouri
    That is a good patina you got there, better than any one I ever made. I would never be able to make it to 36 hours being as impatient as I am! I think I made it 2 hours once with vinegar on a paper towel. Now my favorite thing to do is use the Mora to slice some meat and I get a nice blue/yellow patina.
  14. Iz
    May 2, 2009
    29,222
    870
    The outlaw state
    I do agree with that. I like the blue hue that meat gives to carbon steel. It's purty.
  15. Outrider
    Outrider Scout
    Nov 26, 2009
    455
    13
    South East Tennessee
    That's a really nice patina, I like that a lot. I like to do mine with mustard...that's vinegar too but not as concentrated. I'm surprised how there was no effect at all on the handle, vinegar is pretty caustic.
  16. wingbone
    wingbone Tracker
    Oct 30, 2009
    162
    Tennsessee
    good info mungo...brownell's offers a good selection of cold blues as well as Belgium rust blue.
  17. lobstercreek
    lobstercreek Guide
    Dec 4, 2009
    1,025
    Ecuador
    ive decided to try this on a few knives ive made before i give them for Christmas
  18. plowboy
    plowboy Tracker
    Nov 30, 2009
    53
    Fantastic job! I appreciate your discussion of blue rust v. red rust. Again, great looking job.
    Thanks,
  19. hayride
    hayride Tinder Gatherer
    Jan 5, 2012
    I hear you can also give your mora a nice patina by sticking it in a longer variety potato leaving it for a few hours. Haven't tried this yet, I'm about to tonight with a mora I just bought yesterday and I'll post pics and description of results.
  20. solocanoe
    solocanoe Bushmaster
    Nov 2, 2010
    7,574
    25
    AR/OK border
    I stuck my Mora in a potatoe overnight - that was 6 months back...the one I posted that I did the hundreds of graprefruits with since..... it's still holding up great.
    not as fancy as this thread, though. congrats on your results
    (and thanks for the pics - the science was a bit thick there for me! :D)
  21. Keepntime
    Keepntime Scout Bushclass I
    Dec 2, 2011
    595
    Caddo Mills, Texas
    I will be trying that with my Mora. Thanks
  22. Capt. Jeff
    Capt. Jeff Guest
    very cool! i like how dark you were able to get it! i have done this before, but never kept it in for that long. i may have to try this in the future!
  23. Gryphonblade
    Gryphonblade Guide
    Jan 13, 2011
    1,863
    Saint George, UT, temporarily out of state (and mi
    You can get spots by spritzing a blade with straight vinegar. I did that on both my kook and my Hultafors.
  24. Easy_rider75
    Easy_rider75 Bushwhacker
    Dec 18, 2009
    10,394
    66
    Wander the roads of Connecticut
    Really seriously thinking bout doing this to my Mora
