Cleaning rusty tools using vinegar??
Discussion in 'Edged Tools' started by WFR, Jan 24, 2013.
  1. WFR
    WFR Tracker
    Jan 21, 2013
    147
    I have several old tools that have been exposed to the elements and have rust on them.
    I have been told that soaking them in vinegar will help remove the rust.
    How do you go about doing this?
    I can get a gallon of distilled white vinegar at Costco for a little over $3.
    I have a small plastic bucket.
    How long do you leave the tools in the vinegar?
    Any guidance would be appreciated.
    Thanks!
    WFR
  2. OutdoorEnvy
    OutdoorEnvy Guide
    Jan 12, 2012
    2,779
    206
    Oklahoma
    Leave them in as long as it takes. It can take anywhere from 1-5 days from my experience.
  3. harvey_birdman
    harvey_birdman Scout
    Jan 9, 2011
    928
    Kentucky
    +1 on 1-5 days.
    Also make sure you wash them good with soap and water when done. The black film that builds up on the steel is some nasty stuff.
  4. Ron
    Ron Guide
    Jun 23, 2011
    1,901
    16
    Sweden
    use a steel wirebrush or some sandpaper first. Than put it into the vinegar.
    Speeds up the proces and gives a smoother, better looking finish.
  5. Hank McMauser
    Hank McMauser Scout
    Jan 15, 2013
    502
    12
    Payette county Idaho
    I've had better luck using electrolyses. all you need is a power source(I use a car battery charger) a bucket ,some water with a little bit of baking soda, and some sacrificial junk steel you don't mind getting more rusty. if you look it up,there's plenty of tutorials online with better instruction than I could give you.I've even used the process to clean up corroded lawnmower carburetors.
  6. TSisk2
    TSisk2 Tracker Bushclass I
    Dec 27, 2012
    192
    Sandhills of NC
    Wood handles
    I have a hatchet I want to do, do you reckon the vinegar would mess up the handle?
  7. BushMetal
    BushMetal Banned Member Banned
    May 24, 2012
    1,342
    USA
    Until all the rust is gone.
    Brush it with a wire brush every few hours or at least once a day.
    When you have no more rust your done
  8. 2stoves
    2stoves Scout Bushclass I
    Nov 7, 2012
    923
    101
    My best guess is yes. I dumped an old knife with wood handle in vinegar and let it set over night. Wood handle swelled and seperated. I assume it would do the same to a hatchet handle if it was wood.
  9. MiddleWolf
    MiddleWolf Guide
    Sep 29, 2011
    3,352
    247
    Pacific NW
    Also look at Naval Jelly. I does some of the same things.
  10. barkeep8
    barkeep8 Scout
    Sep 4, 2012
    242
    Manhattan Kansas
    Friend just told me about this the other day. He is trying it now:
    Electrolysis tutorial
    http://www.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
  11. Hank McMauser
    Hank McMauser Scout
    Jan 15, 2013
    502
    12
    for light rust go under the kitchen sink and grab some barkeepers friend it is a mild abrasive that also contains oxalic acid to help you wipe away the rust, I like to put it on with very little water so it makes a paste and rub it in.
    lol I just realized the poster above me is barkeep8, what a conicidence:32:
  12. giantslor
    giantslor Tracker
    Aug 23, 2012
    115
    TX
    For smaller stuff, you can also scrub it with aluminum foil and water, or foil and vinegar. I think aluminum works in a similar way to the electrolysis method, but without the need for actually using electricity.
  13. TLewallen
    TLewallen Guide Bushclass I
    May 10, 2012
    1,539
    37
    Nacogdoches
    Electrolysis has been the easiest and most thorough method I have found.
  14. WFR
    WFR Tracker
    Jan 21, 2013
    147
    Okay,
    I dumped the 5 liters of white vinegar in a plastic bucket then put in a fireman's axe head and an old rusted pie iron.
    After 5 days the results are pretty amazing.
    Final step?
    Take them out, rinse with water then apply WD40 or some kind of oil to prevent rust?
    Thanks!
  15. 1066vik
    1066vik Guide
    Jan 17, 2012
    2,961
    325
    NE Ks
    if you're going to cook with the pie iron, don't use WD-40 on it -- season it just like a cast iron skillet.
    wipe it with a generous coating of vegetable oil and bake it at 300-350 for an hour.
    on the axe head, you can wipe it down with used motor oil - or give it a coat of car wax.
  16. Shnick
    Apr 27, 2012
    10,971
    194
    Wichita Falls TX
    Anywhere up to about 4-5 days, if you want to conserve your vinegar put the item in a ziploc but DO NOT seal it up all the way.
    It'll offgas and it'll need to vent. POnce it's done soaking hit it with a bit of soap and water.
    Wipe dry then apply oil to the moving parts (like wire cutter hinges) and lightly coat with your favorite lightweight oil to prevent rusting.
    If it isnt too late, use these instructions to re-season cast iron cookware.
    I use mine, rinse off and put on a thin film of coconut oil.
    No soap, no scratch pads.
