Estiwing Riggers hatchet/ axe??
Discussion in 'Edged Tools' started by scottman, Oct 7, 2012.
  1. scottman
    scottman Guide
    Aug 16, 2011
    1,091
    57
    I can find little about this one.
    I have an estwing hatchet I found in the woods, still serviceable. I have the 26 campers axe I've had forever.
    How does the riggers hatchet/axe compare? chop better? split better?
    I can find very little of these axes on youtube....
  2. FortyTwoBlades
    FortyTwoBlades Banned Member Banned
    Jul 31, 2011
    4,765
    I have one and use it all the time around the homestead. The Rigger's Axe is a good deal smaller than that 26! Think about "tactical 'hawk" size. Very thin bit that chops quite nicely, and the straight edge--while impairing depth of cut penetration--gives very controlled material removal and allows you to connect your blows better than a rounded bit so you actually make it through targets in about the same span of time. The nail puller notch comes in handy for pulling old fence wire (came in handy removing a bunch of old barbed wire at one point!) and the hammer poll is great for pounding stakes. It'll split if you need it to, though it'd be limited to smaller stuff (calf thickness and thinner) or else you might get it stuck. Contrary to what most folks say I find I don't experience significant discomfort choking up on the steel haft, though of course it's not as comfortable to do so as a wooden haft would be.
    It's a homesteader's multitiool and I think I'd be plenty comfortable with it in the woods. Doesn't get half the attention it deserves, in my opinion.
  3. scottman
    scottman Guide
    Aug 16, 2011
    1,091
    57
    How does it split and chop compared to the 26 inch campers axe?
  4. FortyTwoBlades
    Jul 31, 2011
    4,765
    Well the 26 is going to easily out-perform it in both respects simply due to the much longer length and greater weight. However, for its size it chops well. As I mentioned, it'll handle splitting logs up to the size of your calf. Any larger than that and the thin bit will kind of just sink in without splitting. That's fine, though, as that's really only as large as you should have to split for the fire anyway, and you could nibble away at a larger piece if you had to.
  5. scottman
    scottman Guide
    Aug 16, 2011
    1,091
    57
    cool thanks!
    how does the rigging hatchet compare to the normal estwing sportsman hatchet? the one I found in the woods has somewhat of a limbing/hollow profile.
  6. FortyTwoBlades
    Jul 31, 2011
    4,765
    The Rigger's Axe is a hollow like the Sportsman, but a thinner, almost knife-like form. It's a very flat chopper, only bowing outwards as it transitions to the neck and then the hammer poll.
  7. scottman
    scottman Guide
    Aug 16, 2011
    1,091
    57
    If the riggers doesn't split bigger then calf size pieces, does it leave a wide enough crack to put a wood wedge when you pull it out of larger pieces?
  8. FortyTwoBlades
    Jul 31, 2011
    4,765
    I'm sure you could get it to produce that result. I just haven't tried, to be honest! It's about the size of a tomahawk, so bear that in mind.
  9. scottman
    scottman Guide
    Aug 16, 2011
    1,091
    57
    So the estwing riggers axe weighs 1 more pound for 5.5 inches of increased weight over the riggers hatchet? Are the bits identical in size?
  10. FortyTwoBlades
    Jul 31, 2011
    4,765
    Nope! The Carpenter's Hatchet is practically pocket-sized (though by pocket I mean cargo pants pocket.) I'll see if I can snap a pic for you later.
  11. scottman
    scottman Guide
    Aug 16, 2011
    1,091
    57
    Thank you, I was confused on how 5.5 inches could bear so much weight! lol
  12. FortyTwoBlades
    Jul 31, 2011
    4,765
    PM with the pics incoming, broseph. :D
