Homemade Knife from Circular Saw Blade
Discussion in 'Self-made Gear' started by LukeDeBee, Jan 17, 2011.
  1. LukeDeBee
    LukeDeBee Scout
    Oct 16, 2010
    476
    147
    I looked around for a place to post this. If there is a better place, please let me know.
    I read elsewhere how it is possible to make a knife from a circular saw blade.
    I thought I would give it a go, since I had an old saw blade, and some time today.
    My dremel and a metal cutting disk did a great job. Having finished one, I decided to try another style, plus a small blade I hope to use as part of a carving set.
    The one in the middle seems to fit my hand the best. There is nothing new here as far as a design. I basically followed a tried and true pattern for a sheath knife.
    I really don't know what kind of steel it is, but a bastard file can work the metal. Does this mean it will need to be hardened more? Can you help me out with this, I am real "green" about metal work and hardening steel.
    Thanks,
    Luke DeBee
  2. tjwilhelm
    tjwilhelm Scout
    Mar 28, 2010
    233
    East-Central Illinois
    Looking forward to watching this project progress!
  3. NightOwl
    NightOwl Scout
    Dec 13, 2008
    419
    Rochester, Illinois
    this is cool. can you do a video? just askin.. :D
  4. Rubarb
    Rubarb Contributor
    Sep 19, 2008
    7,539
    me too, like the look of all of them.
  5. Two Rivers
    Two Rivers Guide
    Dec 12, 2009
    1,332
    Looks like a good project. All 3 look like they could be useful.
  6. Son of liberty
    Son of liberty Scout
    Sep 22, 2010
    744
    Kentucky
    I cant tell from the photo, but if the blade has carbide teeth then the steel is not ideal for a cutting tool. In most cases particular blades can be made in to good knives but with so many blades out there its hard to find the good ones. You need the older type or a new one that is not just hardened on the teeth.
    Best bet IMO would be to heat treat it again before you grind the bevels and see just how it dose. Because the steel is relatively thin you wont have a whole lot of work to do while its hard. If you grind it first you will have to leave the edge a bit thick to prevent overheating using primitive hardening techniques. Myself not knowing what type of steel it is would heat until a magnet docent stick to it and slightly longer then quench in mineral oil, fallow that up with a temper at 450 deg in your oven at home. You can reach the heat you need to harden it in a BBQ with charcoal and an air supply, blow drier, air compressor, bellows, or even a tube to blow, but don't inhale!.
    If that docent seem like an option then just work it as it is and see if it will take and hold an edge or sharpen part that you dident use and see how well it dose.
    A friend of mine makes his carving tools from masonry nails, they are hard already and he just files then to shape and sharpens them up, they work great.
  7. Lg&m
    Lg&m Scout
    Aug 3, 2010
    826
    57
    Nebraska
    I like the idea and have thought about it myself. I wish we knew what kind of steel is was. I will be watching with interest. Thanks.
  8. karlsefni01
    karlsefni01 Guide
    Nov 27, 2009
    1,167
    Middle of the Mitt
    I hope it works out buddy! good idea, look forward to seeing more of it!
  9. donk
    donk Guide Bushclass I
    Sep 7, 2010
    2,207
    40
    Nice looking knives. Good for you on using existing materials. I agree with SOL above, if the blade has carbide teeth added to a steel blade it probably won't heat treat. Looks good though. Inspiring.
  10. LukeDeBee
    LukeDeBee Scout
    Oct 16, 2010
    476
    147
    Thanks...
    The old blade doesn't seem to have carbine on the tips. A medium bastard file shaped the saw blade tips with out much trouble. Would this be the case if it was a carbide tip? I put an edge on this steel to test it. It cut well into oak, but the edge didn't hold.
    So my conclusion is that I will make this into an good old lesson in the school of life. I plan to follow up with some more shaping, and then try my hand at hardening this unknown steel using the magnet test. Why learn something from this.
    One step at a time....
    Comments and insights most welcome.
    Luke DeBee
  11. Big redneck
    Big redneck Scout
    Jan 6, 2011
    263
    Fort Worth, TX.
    Darn it!! I go through a a lot of blades sometimes 5 or 6 a month. I guess I will keep a few for projects.
  12. Son of liberty
    Sep 22, 2010
    744
    Kentucky
    All is not lost , that just means that the steel could have been tempered down to provide a nice spring surface to support the hardened tips. You would not be able to get anything off the teeth if they were carbide short of a green wheel on a grinder. This is actually good news as now you can harden the edge and make a decent cutting tool.
    I would always suggest that one start with known steel, its cheap and knowing what your working with dose help. Its not expensive to make your own knife, its just time consuming. If you want to send them to me ill heat treat them for ya and send them back, just drop me a pm.
  13. mainewoods
    Jan 18, 2010
    15,472
    2,008
    Central Maine
    Looks Like a Good Start My Friend, Can't wait to see the finish Knife! Thanks for sharing.
  14. petrifiedwood
    petrifiedwood Guest
    Seems like a non-carbide saw blade would be differentially hardened using induction nowadays to heat just the teeth, right?
  15. Son of liberty
    Sep 22, 2010
    744
    Kentucky
    bingo !probably an air hardening steel as well
  16. Independent
    Independent Scout
    Jan 7, 2011
    379
    NC
    Looks good. I particularly like the shape of the middle one. I made a few similar blades when I first got started. The problem I encountered was not finding blades made of L6. I finally acquired a few old relatively giant sawmill blades that were probably something similar to L6 and was able to make some relatively clunky choppers and such, but that's a lot of work to go through to duplicate a machete. With the smaller saw blades I never did achieve anything that would hold an edge worth a darn. I think the problem was my inexperience with picking the better saw blades (ie, not the carbide toothed ones) and my lack of understanding of how to heat treat things that aren't 01 or 1095. That said, it's pretty cheap to pick up blanks of the appropriate materials compared to how much work one can sink into a sawblade cutout that will never measure up to even a cheap Old Hickory butcher knife. I sincerely hope that comment does not dampen your spirits or quelch your enthusiasm. Keep on keeping on. But there are some thing you learn as you go along. One thing I learned after I'd pretty much transformed a garage into a metal shop is that when it comes to knife making, ... I'm a BBQ cook.
  17. solocanoe
    solocanoe Bushmaster
    Nov 2, 2010
    7,574
    25
    AR/OK border
    When I scrolled to the first pic my first thought was "dang! another reason why I need a REAL dremel!" lol!
    (I was given one last Christmas...but it's a rechargeable...totally gutless / worthless thing.)
    anyway...congrats on "seeing" that blade in there! What an idea - very cool! Keep plugging on the edge thing...but geez...seeing that blade hiding in there...and getting it out...good on you, man! :)
  18. LukeDeBee
    LukeDeBee Scout
    Oct 16, 2010
    476
    147
    Another great idea to try!
    Luke DeBee
  19. lobstercreek
    lobstercreek Guide
    Dec 4, 2009
    1,025
    Ecuador
    hey, its good experience, learning what might work and what doesnt is hard work.
    good job starting and working on it. my first 4 knives were made of useless bed frame metal. I Learned that metal is not good for a knife. surprise. I had a lot of fun working on those and learned a lot. so keep at it. if the saw blade doesnt work just get yourself some 0-1 or 1095. its great easy steel for making knives. keep progressing.
  20. Adam B
    Adam B Guide
    May 29, 2009
    2,383
    SE Michigan
    Plenty of good advice here. I would add that you might want to try your heat treat on the remaining scraps of the blade--you'll get more tries to heat treating it right that way.
    You can bring it to non-magnetic and let it air cool, see if that hardens.
    If not, oil quench it and see if that hardens
    Finally as a last ditch you could brine quench it.
    Another thing you may or may not have noticed: What did the sparks flying off the Dremel look like? Though it cannot tell you what steel you have for sure, if you've got a simple carbon steel you'll see great branching on the sparks.
  21. LukeDeBee
    LukeDeBee Scout
    Oct 16, 2010
    476
    147
    What I noticed was that it looked like a 4th July sparkler. Is that what you mean? Was that a good sign?
    Luke DeBee
  22. tnrick55
    tnrick55 Banned Member Banned
    Oct 22, 2009
    2,263
    INDIANA,BLUFFTON
    SAW BLADE KINVES
    HERE IS MY SAW BLADE KNIVES. nessie.jpg GOOD LUCK ON YOURS YOU HAVE A GOOD START.
  23. Adam B
    Adam B Guide
    May 29, 2009
    2,383
    SE Michigan
    Luke,
    That is a VERY good sign. Skip the water and oil quench it first. My guess is that you're gonna have some nice blades.
  24. Adam B
    Adam B Guide
    May 29, 2009
    2,383
    SE Michigan
  25. LukeDeBee
    LukeDeBee Scout
    Oct 16, 2010
    476
    147
    I never knew this stuff. Very practical!! Thanks for directing me to this info. There has been so much encouragement to me as I learn about these things. In other settings it would not be uncommon to be have these interests belittled or dismissed. Thanks for the encouragment &support. Great forum. Info / pics posted here to pass it on .
    Luke DeBee
    http://en.wikipedia.org/wiki/Spark_testing
    Here is a link with pics for HSS / carbides. My blade sparked with forks alot more than anything here.
    http://www.webuycarbide.com/SparkTest.html
    Then following your lead, I found this site ....
    http://forum.ih8mud.com/chit-chat-section/159460-some-silly-metallurgical-questions.html
    with these pictures:
    Thanks. Just passing it on as I'm passing on through this journey....
    Luke DeBee
  26. mosinfan462
    mosinfan462 Tracker
    Jul 8, 2010
    149
    upstate ny
    nice looking blade
  27. Big'n
    Big'n Tracker
    Aug 3, 2010
    137
    Wisconsin
    Any chance on getting some pics of those?
  28. Son of liberty
    Sep 22, 2010
    744
    Kentucky
    here are the ones on my desk, you get the idea though, one is a chisel point, one is a background tool, one is a blade with no handle. I have various others around but not right in front of me.
  29. Big'n
    Big'n Tracker
    Aug 3, 2010
    137
    Wisconsin
    Those are pretty cool. Off to the hardware store tomorrow to get some nails.
  30. LukeDeBee
    LukeDeBee Scout
    Oct 16, 2010
    476
    147
    A friend on this forum offered to harden the blanks for me. Before this was done he touched them up on a sanding belt to profile the edge. He was so helpful with advice and even sent me some brass rods for fastening the scales.
    Blessings to him for helping me out like this.
    Well here is a picture after he returned them to me:
    The top one is my favorite. All the scratches are from my file work before I sent them blanks to him. I still have to finish drillling the holes. The middle one is going to be a small wood whittle knife. I haven't decided what to do with the bottom one yet.
    I'll keep you posted as I make progress...
    Thanks again friend!
    All the best,
    Luke DeBee
  31. BadgersDen
    BadgersDen Tracker
    Jan 26, 2011
    22
    Sumter, SC
    Great idea, I love the progress and the finish of the uppermost knife. I can't wait to see the finished product and will give these a go myself.
  32. Dr. Redneck
    Dr. Redneck Guide
    Jun 25, 2011
    1,227
    the backroad of the backroad
    might have to try that myself
  33. Tyronethepro
    Tyronethepro Tracker
    Apr 17, 2011
    97
    Tampico,Yakima,Washingon
    Great looking knives, great work there, no doubt about it.
    I believe saw blades are L6 steel.
  34. ElectricHellfire
    ElectricHellfire Scout
    Jul 20, 2011
    364
    Great little blades. If they are L6 steel that is a good thing! I love L6.
  35. bsred
    bsred Guide
    Jan 7, 2011
    1,199
    Mobile, Al
    Whatever came of these?
  36. stronghorse
    stronghorse Guide
    Jan 28, 2012
    1,025
    Coastlands of Virginia
    Great job!
  37. crusher
    crusher Scout
    Nov 18, 2012
    816
    Kentucky
    Good on you,
    This is one reason I like this forum so much, everyone seems to step up and help out each other...
