Stevens Model 311A
Discussion in 'Firearms' started by gm42, Jul 16, 2011.
  1. gm42
    gm42 Scout
    Jun 12, 2010
    596
    25
    San Ramon California
    Hey Guys,
    What can you tell me about a Stevens Model 311A double barrel shot gun? Are they common and are they well built?
    I just got one from my dad.
    Thanks,
    Geoff
  2. GreyOne
    Oct 11, 2008
    40,176
    4,248
    Savage/ Stevens 311 is a very good, very plain double barrel. They are great hunting guns, and very reliable. They are not pretty and graceful like more expensive double barrel guns, but they were one of the most common farm guns for a generation or more.
    Shoot us some pictures, and tells what guage, barrel length, choke markings, etc.
  3. DancesWithaTrout
    DancesWithaTrout Guest
    I have a couple 311a Stevens shotguns, 20ga and .410.
    They are well built, parts are common to the Savage/Springfield/Fox series. Parts are avail when needed from this source.
    http://www.gunpartscorp.com/catalog/Products.aspx?catid=603
    The average prices you would expect to pay are $250 to $600. The .410 in 21" barrel are the hardest to find. If you are looking for a common 12ga in used condition, I would not pay more than $300. New or as new condition - $400. 410's deman preimum prices and have honestly seen them bid up to $1000.
    The most common thing to go wrong are the firing pins being mushroomed out and the entire action being stiff from the type of grease used when made, it hardens out over time. Simple soak in kerosene or mineral spirits w/o the stock on will cure that situation. Just re-lube with a good spray oil into the action after the soak and dry.
    If you are buying a used one....here are some weak points to look for:
    1. Wrist area of the stock for cracks and hairline cracks. You will find many of them with repaired cracks using pins and epoxy.
    2. Mid barrel bulges. There will be slight swells about mid-length on the barrels from people using Buck, Slugs and alternate shot like bismuth, alloys etc..... These bulges are easy to repair, but should detract a lot of cash on a sale.
    3. Failure to fire and failure to extract/eject. The firing pins, extractors and ejectors are easily worn on these shotguns, also easy to detect with fired cases marked with a permanent marker. Load the shells, fire both barrels in a safe direction, open and extract.......if they extract well and show a decent firing pin impression... all is A-Ok.
    If there is FTF/FTEe, then check the shell, this should tell you where wear points are as indicated on the inked shell casing.
    4. Flared barrel muzzles. Often hunters and amateur gunsmiths will flare the muzzles in hopes of averting cracked muzzles and choke points when they use alloy or slugs. Easy fix for most gunssmiths.
    Hope this helps, please contact me if you have need for more information on these shotguns.
  4. Ahnkochee
    Ahnkochee Bushmaster
    Mar 6, 2011
    6,312
    1,054
    Moku Manu, Hawai'i
    My very first shotgun was a 20 gauge model 311, loved that shotgun but when desperate for first date money I sold it to a friend. That date ended well as she's still with me 31 years later so i guess it was a worthy sacrifice. ;)
  5. scallop
    scallop Scout
    Aug 31, 2010
    874
    central ohio
    They make a damn fine bunny gun!
  6. Charlie_X
    Charlie_X Scout
    Apr 14, 2011
    274
    I've been after a Stevens 311 ever since I saw one at the first gun show I attended.
  7. rdraider
    rdraider Guide
    May 24, 2011
    1,463
    12
    Mineral Wells, Texas
    i had a model 511, which is basically the same as a 311. It was a great gun! Enjoy it, it won't disappoint.
  8. A K Church
    A K Church Guide
    Sep 5, 2010
    1,747
    62
    So many are being cut up for cowboy games, that it's possible that un-monkeyed examples will see a bit of a premium pretty soon.
    Its ancestor the 5100 was one I really liked. Mine was a 12G 30" Mod/Full. Overweight by a pound or more, and just ever so long, it was a squirrel killing machine. It patterned well with any stuff you fed it.
    If I lived in a buckshot for deer situation, it would have been definitive in that role.
  9. Gryphonblade
    Gryphonblade Guide
    Jan 13, 2011
    1,863
    Saint George, UT, temporarily out of state (and mi
    I've owned two Stevens arms. Both were among the cheapest I've ever had and are two of the guns I miss the most.
    One was a bolt-action 12 ga goose-gun: 28" barrel, two round mag and adjustable choke. Great, reliable, impressive-looking gun. Blew minds with it when I opened up with that thing around folks who didn't know what it was.
    The other was a "Sheriff" model .22 bolt rifle. Single-shot, chambered .22 LR and Shorts. Fun, fun little gun. Scary accurate too. It was also free. Friend found it in a dumpster, corroded and clogged. He got the bolt loose and gave up. I got it, rodded the bore clear, cleaned the whole thing and test fired it with a string. It shot great! I never even adjusted the sights. What a squirrel slayer!
  10. EdD270
    EdD270 Guide Bushclass I
    Dec 19, 2009
    2,467
    Mogollon Rim, Arizona
    A 311 was the first shotgun I ever bought. Had it for about 45 years, one of my daughters has it now. Great gun, had to replace the spring on the safety button about 10 years ago, other than that, no problems.
  11. wolfy
    wolfy Guest
    My first two row 311 I bought from the school janitor when I was in the eighth grade. We cut the deal in the hallway just outside my class room. I think that would rate as a felony on both our parts these days. I still shoot side by sides in cartridge and muzzleloader configuration.......they get in your blood.
  12. Buzzard II
    Buzzard II Tinder Gatherer
    Sep 16, 2013
    Northern New Jersey
    I finally found a mint 311A in 16 gauge to go with my 12 and 20. Yeah, I kinda like the Stevens 311. Nicer guns (read pricey) out there, but the 311 is just a neat gun to own, and will pass them on to my grandson. All are original, unbutchered.
  13. WesinND
    WesinND Supporter Supporter Bushclass I
    Jan 3, 2013
    874
    258
    Northern Prairie
    My first shotgun was a Savage/Springfield Model 511 in 20 gauge. I bought it at Sears and Roebuck many years ago and killed a lot of game with it, mostly rabbits and squirrels. I still have it, but it doesn't see much action. It'll get the job done if it hasn't been abused.
    Wes
