Tanning hides / furs
Discussion in 'Self-made Gear' started by greyhawk, Oct 6, 2010.
  1. greyhawk
    greyhawk Tracker
    Oct 3, 2010
    20
    It is common knowledge that an animals brain is sufficiant to tan its own hide but few folks know about the use of acorns for the same purpose...No mess or bad smells... You prepair a hide as usual (I leave the fur on cause I use it for fly tying) and put it on the board fur side against the board... Gather the acorns and shell them... Grind up the acorn meats untill it is about like peanutbutter... Now that the acorns are prepaired,,,,,,,,,,,,
    (1) spread a layer of the acorn butter on the skin side of the hide...
    (2) when the acorn butter starts to crack and you see hide through the cracks go ahead and peel the acorn butter off the hide...
    (3) take the hide off the board and work it a little and put it back on the board...
    (4) you will have to do steps 1-3 2 or 3 times then your done...
    It works great and leaves the hide soft & pliable and no bad smell... Acorns has tannic acid in them and the darker colour yellow the acorns are, the stronger the tannic acid content is and thats why acorns are bitter tasting...
  2. jimmyt
    jimmyt Supporter Supporter
    Sep 10, 2010
    1,382
    144
    south east NH
    Good info. How long does it take for the "butter" to dry enough to crack?
  3. Long Hunter
    Long Hunter Scout
    Sep 21, 2010
    470
    12
    East Central Fl
    You can also use a potash alum method or, believe it or not, a turpentine/wood alcohol method. Neither of these methods is better than another, but brain tanning is still my preference.
    *Note, brain tanned hides are more durable when smoked after tanning and before oiling.
  4. redneckdan
    redneckdan Tracker
    Aug 4, 2010
    82
    I have a raccoon in the freezer I will pull out and give it a try. I'll let yall know how it turns out.
  5. Mad Russian
    Mad Russian Scout
    Sep 20, 2010
    346
    New Iberia, Louisiana
    I've used regular table salt on rabbit furs. Works great but leaves the skin a little stiff. I then rub Neat's Foot Oil on them to soften them up and wash the oil off with warm water mixed with diswashing liquid.
  6. wisconsinwalter
    wisconsinwalter Supporter Supporter
    Sep 15, 2010
    2,837
    600
    Stoughton WI
    Great post!
    Thanks! I have been looking for a post like this
    Does it matter how old the acorns are in relation to falling from the tree?
  7. greyhawk
    greyhawk Tracker
    Oct 3, 2010
    20
    It takes around 2 days for the cracks to start forming in warm sunny weather... As for the age of the acorns, the newer fallen they are the better... Once they dry out they loose the natural oils and wont work properly...
  8. OddTheViking
    OddTheViking Guide
    Aug 30, 2010
    2,370
    Cedar Rapids, IA
    How do you keep it from eating all your food??? :D
  9. wisconsinwalter
    Sep 15, 2010
    2,837
    600
    Stoughton WI
    I guess I will have to wait until next year
  10. amcardon
    amcardon Scout
    Feb 16, 2010
    255
    Portland, OR
    I've got a bear hide (skinned him last night) and have never tanned a hide before but want to practice on him. I was going to use salt and alum but this sounds interesting, just not sure if I can get enough acorns to grind up for 3 applications to an entire bear hide! Thanks for posting this, maybe I'll be able to give it a try on something smaller scale first.
  11. BackwoodsUncleBub
    BackwoodsUncleBub Scout
    Sep 25, 2010
    626
    SaleCreek, Tn
    Raw eggs and vegetable oil mix works too. Leaves the hide as if it was brain tanned after its been smoked. Allows the leather to "breath" like the brain tanning proccess.
  12. leaf and lightning
    leaf and lightning Guide
    Jun 30, 2010
    2,262
    158
    Chenango Co. NY
    what is the ratio??
  13. BackwoodsUncleBub
    Sep 25, 2010
    626
    SaleCreek, Tn
    I use 4 to 5 eggs per cup of oil. Depending on the size of the eggs...
    Beat the eggs in the oil till it thickens up ( your basicly making unseasoned mayonnaise ). Work it into the hide as best you can. Place the hide in a plastic bag or bin to allow it to soak in for a day or so, massaging the mixture in each day while you check it. After a day or so, rinse the hide in cold water. Strech and work it dry, then smoke it.
