tree blaze & trail/property marker guide?
Discussion in 'Other Skills' started by alukban, Jan 22, 2017.
  1. alukban
    alukban Guide
    Mar 12, 2010
    3,509
    2,451
    NYC <--> NW CT
    Is there a definitive reference available regarding how to interpret tree blazse and trail/property markers?
    There are bits and pieces of information available but not a single, all-encompassing guide. Maybe we need a sticky to collect all this information on BCUSA.
    For example, what do the various indian trail trees mean?
    Also, in my state of Connecticut, what do 3 blazes on top of each other (as opposed to just the yellow band or the yellow band + one blaze) that mark the boundary of State forest mean (see image below)?
    PS. I got a tick buried in my neck last night as a reminder from nature after a deer scouting escapade in yesterday's glorious 52° weather :(
    actichy, Nakadnu, Broke and 8 others like this.
  2. MrFixIt
    7,645
    13,773
    Check with an older surveyor in your area, they could possibly help.
    And if you do, please post your finding!
    alukban likes this.
  3. RavenLoon
    Sep 6, 2012
    1,872
    639
    U.P. Michigan
    Research projects would be another activity that would have different tree marks. That looks like some kind of witness tree to the pipe corner but I've never seen one painted like that. Original witness trees in the 1785 general survey the blazes were one at the base and one at 4 foot facing the corner, three or four total, with scribing on the blaze face. Connecticut was earlier metes and bounds system so may not be a standard there.
    Forestree and alukban like this.
  4. hdlv
    hdlv Hobbyist Hobbyist Supporter
    Jan 3, 2015
    675
    910
    New York
    If I remember correctly 3 on top of each other is a forestry service property marker. I think it is used to mark a corner. Or I'm totally wrong and is a reference tree or witness tree (not like a circle war witness tree) but one that a forester follows a gps to before starting a survey.
    I know I learned this one last summer but the memorie is a little blurry and my googlfu is proving inadequate.
    Pastor Chris and alukban like this.
  5. alukban
    alukban Guide
    Mar 12, 2010
    3,509
    2,451
    NYC <--> NW CT
    You may be right on that "reference tree" thing. Thanks!
    There is a pin right beside that tree (definitely not a corner) so it probably does indicate a reference point nearby (i.e. the pin).
  6. Ghill
    Ghill Tinder Gatherer
    Jan 16, 2016
    19
    PA
    When i had my properity surveyed here in pa.The tree nearest the orignal corner pins was blazed three times (From the orignal survey)and they tied a ribbon above so it could be seen from all directions. The blazes was facing the direction the corner turned.Single blazes was straight properity lines.Thats what they told me. I didnt do any research to see if was right or wrong ,just went with it.
    alukban likes this.
  7. Forestree
    Forestree Scout Bushclass I
    Jan 16, 2014
    810
    652
    DBX, wildbill50, GreenFrog and 2 others like this.
  8. Seeker
    14,477
    6,085
    Love it Forestree... "Paint shall be neatly applied"... so sad that you have to spell that out for a contractor.
    DBX and alukban like this.
  9. remington79
    remington79 Scout
    Apr 18, 2010
    415
    237
    various parts of the US
    When I used to survey in Texas there were a variety of ways you would find blazes. I'm not sure how along they started the new standard but we would find older bearing trees that had scarred over.
    For a property corner we would stand on the corner and take a bearing to a tree. Then that tree would have an X chopped into it. Just enough to remove the bark and puncture it a little so it would scar over. The center of the X is pointing at the corner. Then we would hit the the tree with our machetes putting 3 horizontal lines above and below the X. After the tree scars over you can still clearly see the markings. In addition to taking and recording the bearing we would also measure the distance to the tree, the DBH (diameter at breast height. It's a forestry term and is roughly 4 feet above the ground.) and the type of tree. The minimum would be 2 trees but we made it a point to use 3 trees or other permanent objects.
    If the corner was somewhere in a tree (they grow) we would set witness corners. From what I've seen USFS land uses red paint and has red bands and a plate on the tree. I'll post pictures of that.
    When I lived in CT the white blazes are the Appalachian Trail and the blue blazes were for the Blue Trails. I don't know if they have another name but we always called them blue trails. If you see a rectangle or two above each other it shows you are on the trail. If you see a rectangle (will be paint) and the rectangle on top being off set it means that another trail goes off in that direction. These are usually found at trail intersections.
    alukban likes this.
  10. remington79
    remington79 Scout
    Apr 18, 2010
    415
    237
    Here are the pictures I took of a USFS corner.
    alukban likes this.
  11. remington79
    remington79 Scout
    Apr 18, 2010
    415
    237
    Traverse points would be recorded the same way as corners but instead of an X and hack marks we would scrap away a little of the bottom of the tree pointed towards the traverse point and then put a hack in it and put a piece of flagging in it. This was called a toe blaze.
    One of my friends surveyed a little in CT and he found corners from the 1700s that were holes drilled in rocks and they were still on after all those years.
    alukban likes this.
  12. Carver 83
    Carver 83 Tinder Gatherer
    Jul 22, 2016
    The standard trail blaze for the old U.S. Forest Service was a top bark blaze two to four inches wide, two inches long over a bottom bark blaze that was two to four inches wide by eight inches long. The tree was blazed on both sides.
    alukban likes this.
