(Used) Austrian Heavyweight Wool Sweater, Olive Drab
Discussion in 'Reviews' started by pik, Jun 19, 2010.
  1. pik
    pik Scout
    Feb 27, 2010
    730
    13
    Duluth, MN
    Product
    Translated tag (via some brief Googling)
    (front) textile / productions / company with limited liability / city name / 10 44 / 100% virgin wool
    (back) army property / 1985​
    Materials
    100% virgin wool (rib-knit and boiled)
    ???% cotton patches on top for durability​
    Color
    OD green​
    Size
    L (according to SG)​
    Measurements
    21.5" (55 cm) armpit to armpit
    33" (84 cm) waist/hem circumference
    26.5" (68 cm) center back length from base of hood
    32" (81 cm) sleeve length from center back​
    Wool fabric
    From what I've read about boiled wool at Wikipedia, it sounds like this fabric was mechanically knitted in large sheets, then boiled, then cut and sewn into a sweater. This makes sense, since I suppose it would be hard to make the wool shrink to the exact size you wanted. Anyway, the result is a thick, ribbed wool fabric about the weight of a wool blanket, the advantage of knitting being stretchiness (with of course more stretch perpendicular to the ribbing). The cost, however, is breathability; this sweater lets through more than twice as much wind as a similar-weight pullover I made from an Italian army blanket. The fabric feels pretty poky on the skin (after all, virgin = long fibers), and I can't tell if the boiling removed the wool's natural oils (anyone know more about this process?). If the lanolin is gone, then the pokiness might be fixed by treating the wool.​
    Cotton patches
    SG says "cotton," but I claim "cotton blend." My guess is cotton/nylon, but it could be cotton/polyester or something else. I have mixed feelings about these. Obviously they add durability to the shoulders/elbows, which is nice for, say, wearing a backpack on this. But two things: (1) they make those areas quite stiff, causing for instance the shoulders to hang a bit strangely, and (2) since they are sewn on top of the wool, the sweater cannot stretch in those areas. If I were keeping this sweater, I would remove them. They look relatively easy to remove; just two lines of a running stitch, and if you go from the cotton side it should protect the wool while you're poking around with the seam-ripper.​
    Cut/fit
    Although I've never purchased other military sweaters, I think this follows the typical design: relatively tight waist and short arms, with a lot of material in the armpits. Like all sweaters of this neck/collar design, the neckhole wants to travel down your shoulders when you have the buttons undone. I won't say much more about fit because this sweater was too small for me (6', 130#), and in any case I have a feeling it would fit better if I had a bigger chest and shorter arms.​
    Cleanliness/smell
    Although used, this sweater arrived in a very clean and nice condition. The cotton patches looked brand new, and the entire sweater had virtually no smell (viz. did not smell like naphthalene). In several places, the cuff material was beginning to separate from the sweater (again, the sweater parts are sewn together). However, they could be sewn shut again relatively easily, ideally with wool yarn.​
    Verdict
    I won't keep this sweater, but if I could have gotten an XL or XXL I would have. The fabric makes a very warm and heavy sweater while retaining the breathability and flexibility of rib knitting. Proportionally, it is a bit short in the arms, but this is less of a problem with winter clothing due to gauntleted handwear (not to mention that the problem is usually too much fabric near the wrist). Secondly, 100% virgin wool for $23 is unreal. I suppose I'll find someone to give it to, or maybe put it in the "goodie box" if I ever get around to signing up for that.​
    More pictures
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Nerual the Mad
    Nerual the Mad Guide
    Apr 25, 2010
    2,050
    Duncan OK
    Looks like a good product. Are they cut small or are you just a big guy and should have gotten an XL? I'm 6ft 235lbs and wear either a large or XL depending on the cut. How would you rate the sizing?
  3. pik
    pik Scout
    Feb 27, 2010
    730
    13
    Duluth, MN
    Well, the measurements are from the sweater I got (size L), but I don't know how tight people like these. If you want it tight-fitting, a L might be borderline okay for you. I was intending to wear it sort of like a coat, over a midweight baselayer (for example level2 ECW fleece), so for this I would have liked an XXL, I think. (SG only has up to size L.)
    I see neither size nor brand on the tag (maybe 44-inch chest from "10 44", but why would Austria use inches?), so I don't know how SG determined sizing. The size L that I have is consistent with other WWII-ish European sizing, at least in my experience. For example, one wearing a size L Swedish army anorak would want this sweater in size L to wear underneath.
    My feeling is that you would also want a larger size than SG offers. (And let me know if you happen to find larger sizes somewhere else with similar pricing.)
  4. traveller
    traveller Tracker
    Oct 5, 2009
    106
    pik,
    thanks for the review.
    I saw one of these at a flea market and was considering getting it.
    This wool sweater-do you think if you hand washed it you could gently stretch the wool whilst wet for a more looser garment fit?
    I had a woolly pully made in UK sweater ages ago and as long as you got the sweater a little bit bigger than your actual size I found it to be quite good-warm. Did have to wear a long sleeved cotton top underneath it but it would keep you warm.
    Sadly, I made a slip on the washing instructions and it shrank...much smaller so ended up giving it away.
  5. mischief
    mischief Guide
    Dec 20, 2009
    1,344
    21
    N W Florida
    Forget about the recruiting posters,I have found that with a wool pully always go 1 size larger.Wool and air make very good insulation.
    I'am a Gerontologist,Look it up
    Mischief
  6. pik
    pik Scout
    Feb 27, 2010
    730
    13
    Duluth, MN
    Seems like that might open up the knitting a little too much and you'd end up with a double-duty wool shirt/net :D, but I'm new here and don't know much... I bet hushnel could give you a higher-confidence answer because he knits sweaters.
  7. mischief
    mischief Guide
    Dec 20, 2009
    1,344
    21
    N W Florida
    I did not know that::)The man is very talented
  8. pik
    pik Scout
    Feb 27, 2010
    730
    13
    Duluth, MN
  9. pik
    pik Scout
    Feb 27, 2010
    730
    13
    Duluth, MN
    got some XL's
    I saw that SG had XL's available, so I got two. Both arrived in what I would call "like new" condition. One is the same maker, same thing; the other's tag says "1982 / RACK / 9853 Gmünd" besides the obligatory "Heereseigentum" and "Reine Schur Wolle." Gmünd is a town.
    The Gmünd has no epaulets, which saves me the trouble of taking them off. It has a velcro bar on the front right breast and a patch on the left arm that says "Österreich Bundesheer" ("Austrian Army").
    Gmünd "XL" measurements
    23" (58 cm) armpit to armpit
    32" (81 cm) waist/hem circumference
    28" (71 cm) center back length from base of hood
    33" (84 cm) sleeve length from center back​
    Haugschlag "XL" measurements
    31" (79 cm) waist/hem circumference
    27.5" (70 cm) center back length from base of hood
    32.5" (83 cm) sleeve length from center back​
    The wool of both of these feels way better than my first (L) - I didn't even bother wearing another shirt when trying them on. The Haugschlag has two pinkish spots that look like bleach action, but I don't see any structural damage between the two. I maybe didn't measure perfectly all three times :eek:, but these are a bit larger overall and I will keep them.
  10. Swissarmy
    Swissarmy Scout
    Jan 6, 2010
    302
    S.W. Michigan
    I've had my eye on these for about a year now.
    Thanks to your fine review I pulled the trigger, and an XL is on it's way to "Santa in the brown truck". :)
    I'm looking forward to it's arrival on my porch!
  11. Sgt. Mac
    Dec 11, 2008
    53,541
    64,338
    Land of Lincoln
    Pic I normaly wear XL would the XL of these work?
  12. pik
    pik Scout
    Feb 27, 2010
    730
    13
    Duluth, MN
    Sorry Mac, not unless you like 'em really tight - I'm 6', 140#, 32"-waist and usually wear "medium long." Like I said in my first review, I'm not sure where SG comes up with these sizes, but I'd say it's more like WWII-era than the 1980's when these are from.
    All of the numbers I have listed are measured flat and unstretched on the dining room table - the sweaters are cut in two identical pieces, "front" and "back," so they lay as flat as can be.
  13. brionic
    brionic Blissful simpleton Supporter
    May 4, 2009
    6,510
    973
    Iowa
    Mac I received mine yesterday and it was tight. Not unwearable, because the wool is soft and has some stretch to it, but I wouldn't want to wear it out on the town.
    For reference I'm 6'2" 210.
  14. Swissarmy
    Swissarmy Scout
    Jan 6, 2010
    302
    S.W. Michigan
    I will let you know sometime next week.
    I have an XL on the way, and I'm 6'1" @ 220.
    I have re-shaped many a Goodwill sweater with a few tricks I've picked up.
    I will start a How-to thread when I re-size (if need be).
  15. Sgt. Mac
    Dec 11, 2008
    53,541
    64,338
    Land of Lincoln
    Thanx Buddy lookin forward to it
  16. Zig
    Zig Guide
    Sep 23, 2010
    1,685
    Knoxville, TN
    Bit of a thread revival here, but "Winter is coming" and I'm looking at getting one of these. I wear a size 38 suit jacket, which is typically a medium (sometimes small) in t-shirts.
    I was wondering if medium or large would be the way to go for a close fit. I'm aiming for against/close to my base layer without any squeezing. Too big and my outer layer won't fit... too small and it could be uncomfortable.
    (+1 if you caught the Game of Thrones reference)
  17. justin_baker
    justin_baker Hobbyist Hobbyist
    Jun 13, 2010
    5,184
    151
    California
    Yeah, i'm 5'11 and 140lbs. I am wondering small and medium. 90% of the time, medium is too big and small is just perfect with sweaters and coats. But I might go medium for winter use to put some stuff underneath it.
  18. pik
    pik Scout
    Feb 27, 2010
    730
    13
    Duluth, MN
    I think the numbers I gave are the most help I can give you guys there, since it is difficult for me to imagine how something will fit someone else. The measurements are taken with the sweater unstretched, so there is some give, but not much because of the fabrics weight.
    However, I wouldn't put it past SG to make the sizes for the new stock completely different.
  19. Leif
    Leif Staff Staff Member Super Moderator Vendor Bushclass I Bushclass Instructor
    Dec 19, 2008
    20,785
    770
    Adirondacks
    I ordered an XL from sportsman guide. I was on backorder for 2 months. When they sent mine last week, it was a small at the very least. Couldn't even get the sweater past by elbows.
    Contacted them back, they tell me the sweater is on back order again until late dec. So needless to say I was upset they sent me the wrong one, but also couldn't exchange it out for me.
    Something tells me they never had an XL to begin with.
  20. pik
    pik Scout
    Feb 27, 2010
    730
    13
    Duluth, MN
    Since they have taken to listing products months before they even have them, it wouldn't surprise me.
  21. Leif
    Dec 19, 2008
    20,785
    770
    Adirondacks
    Its what I was thinking as well.
    Bad business...
  22. thr33n0r
    thr33n0r Tinder Gatherer
    Feb 9, 2012
    Has anyone found a source for these lately? I ran into someone that owns one of these and was very impressed by it....
