What kind of sharpener do I need?
Discussion in 'Edged Tools' started by surffisher, Aug 4, 2012.
  1. surffisher
    surffisher Banned Member Banned
    Jun 1, 2011
    218
    California
  2. Lg&m
    Lg&m Scout
    Aug 3, 2010
    826
    57
    Nebraska
    That is a hard question. Lots of ways to go. I like diamond "stones" like EZ lap and DMT. Natural stones used with oil are very good the best can be $$ . Then you have the ceramic stones / sticks. Also good as are Japanese water stones. Aluminum Oxide Stones are very common but not my choice. I am not even going to get into all the "systems" and other gadgets you can get.
    I think learning the skill is more important than what you use. You want to keep the angle the same for every stroke and do the same amount on each side. coating the edge with a marker is a good way to see where the edge is meeting the stone.
    Convexing is also a good option. I will let others cover that. What ever you do please stay away from Tungsten Carbide sharpeners as they scrap away to much material The same for most power grinders. Both of witch will never give you the skill.
    By the way that is a nice looking knife. Good luck hope I helped a little.
  3. swamprat
    swamprat Guide
    Dec 11, 2008
    2,632
    Monroe, LA
    That question cannot be answered easily. It depends on personal experience and how much money you are willing to spend. If you have never sharpened a knife you should try to get with someone and try different methods. I think it is easier for most beginners to use either a "Lansky Type" set of stones with the clamp and different stones. Another good beginner method is one of the kits which have diamond and ceramic rods which fit in a base that holds the rods in a "V" shape.
  4. GreyOne
    Oct 11, 2008
    40,154
    4,094
    Fine sand paper or the fine grit hardware cloth , used on a wooden backer, will give you a very good edge, if you can hold a constant angle.
    The diamond stones are very fast and effective, but prices run from the 20 dollar range on up, and the number of brands and choices can be confusing.
    I have used an old coffee cup, a steel , and a strip of belt leather as a sharpening kit when up at the farm. Worked well, too.
  5. Lg&m
    Lg&m Scout
    Aug 3, 2010
    826
    57
    Nebraska
  6. Two Bears
    Two Bears Banned Member Banned
    Oct 5, 2010
    1,778
    That depends on your skill level, can you keep and angle between the stone and knife. If not you need to practise a lot. I love my diamond hones, if you have a Walmart see if they carry the Smith's diamond hones, you can get one with a handle that has two sides for $15.00. Its gray and black and comes apart, you turn the stone around an insert it into the handle. One side is course and one side is fine. I've gotten lazy in my old age and started carrying a small yellow plastic Smith sharpener. It has limited use however, but the angles are pre set. It has ceramic rods and carbide cutters. As has already been said, be careful with anything that has carbide cutters. I have used carbide cutters before to re-set the angle and straighten an edge that was trashed pretty bad, but they take a lot of metal off of the knife fast. I was at my local Gander Mountain the other day and found that Gerber makes something similar to the Smiths, but uses course and fine diamond rods instead of ceramic and carbide, so I bought the last 2 they had and will be looking for more of them. They were only $5.00 each. They will be replacing the Smith's in my packs. They also have wide enough slot to fit my thicker bigger knives. Depending on your skill level you might want to learn with some kind of flat stone then move onto something faster and easy later after you develop the skill.
  7. statikpunk
    statikpunk Guide
    Jun 7, 2010
    1,305
    Northern Nevada
    I really like the falkniven stones, and lg&m's advice is good, thats how i learned to sharpen a knife, using the black magic marker method to help keep my angle right. as a matter of fact I still use that method when reprofiling a grind.
  8. Aven
    Aven Banned Member Banned
    Sep 18, 2010
    5,432
    Surffisher, check out the Bushclass no. 6, sharpening. The lesson is a great place to start figuring out what you need and how to use it.
  9. Lerch
    Lerch Bushmaster Bushclass I
    Jun 13, 2010
    5,632
    44
    Wentzville Missouri
    As was already alluded to it is easier to tell you what not to do. In my earlier years I destroyed more than a couple knifes with "easy to use" gadgets. Avoid the all the electric grinders and gadgets that "help" you set your angles. Most especially stay away from the following carbide scrapers like this one;
    With a knife like the one you linked I would recommend either the sandpaper method listed in the bushclass or a set of Japanese wet stones even an inexpensive diamond set will work good. Just go slow and use a fine grit. This knife shouldn't require re-profiling out of the box so just go slow with the amount of material you remove. It can be intimidating but you'll get a feel for doing it by hand with practice.
  10. coaldigger
    coaldigger Scout
    Jan 30, 2010
    529
    Kentucky
    I love my Spyderco Sharpmaker ! and sand paper works good to !
  11. spyder1958
    spyder1958 Scout
    Apr 27, 2011
    595
    florida/ E. Tenn.
    Please don't try and learn how to sharpen that new knife and scratch it all up. Get some old cheap knifes, with different steels and get the feel first. I've got several Bokers and I mostly touch up the edge with a ceramic rod or leather pad with green compound.
    Good luck
  12. teranaut
    teranaut Scout
    Mar 16, 2012
    509
    Sandpaper, a crock stick (ceramic rod), and a strop are what I'm using most these days. I can reprofile, sharpen, and hone with the whole get up. My main cost is paper and compound. Neither are incredibly expensive, but when you have to buy packs of the fine stuff it can get a tiny bit spendy. Depending on the quality of paper you get of course. There are many methods, and some work better than others for each individual. The main point is practice, practice, practice. Try honing the craft using inexpensive blades before you move up to the nicer knives. Just to make sure you have it down and don't end up doing damage to an otherwise fine piece of cutlery. Good luck to you and your edges.
