4x4 Stuck In The Mud?
Discussion in 'Transportation' started by Flint_2016, Jun 30, 2018.
  1. Flint_2016
    Flint_2016 Guide
    Apr 27, 2016
    1,689
    5,930
    Pottsville PA.
    Ever get so stuck with your 4x4,no matter what ya got?I found this idea(I'll leave the link)searching for fishing spots in Canada.
    Save the day with a chunk of wood
    1. Find a 16-inch-long piece of solid wood, preferably split in a triangular shape, such as a piece of firewood. The wood must be solid and stiff enough to be tied down from both sides without breaking or bending, and to withstand the weight of your vehicle.
    2. Feed a ratchet strap (or rope) through the rim of one wheel (a front wheel on a front-wheel-drive vehicle, or a rear wheel on a rear-wheel-drive vehicle). Ensure you feed the strap close to the right side of a spoke so it won’t slip when the wheel rotates backwards. Next, place the piece of wood on top of the tire and loop the strap around both ends. Tighten the wood securely to the tire using the ratchet device (or a suitable knot, such as a trucker’s hitch, if using rope). Make sure there’s enough clearance for the tire to turn without the wood hitting and damaging the wheel well or fender.
    3. If you’re driving a 4x4, you can leverage the power going to both axles by repeating the process on the opposite tire on the other axle.
    4. Place the vehicle in reverse and accelerate very slowly, letting the tire (or tires) rotate until the wood meets the ground. At that point, the wood should act as a paddle and grip the ground, providing traction for the vehicle to continue to reverse. Proceed very slowly, or you risk damaging your vehicle’s axle, differential or drivetrain. Once you’re back on solid ground, remove the strap and wood, and carry on.http://www.outdoorcanada.ca/Going-off-road-You-need-to-know-this-great-trick-for-getting-unstuck
    5. (You might wanna keep that hunk of wood in your 4x4 if this ever comes up.It may not be available at the time ya actually need it)
  2. cbrianroll
    cbrianroll Professional Tinkerer
    Jul 2, 2017
    1,298
    5,276
    wet western washington
    Nice! I've seen it done vertically like a oar on the wheel. Worked for a bit till the strap broke.
  3. Tangotag
    Apr 7, 2015
    2,345
    10,567
    WI
    My Jeep doesn't have enough wheel well clearance in mud before doing that.
    After it should be just fine.:16:
  4. gila_dog
    gila_dog Supporter Supporter
    Apr 11, 2011
    2,750
    6,461
    New Mexico
    That's a good idea. I hope I never have to try it, tho. It's another good reason to keep a couple of ratchet straps in your truck.
  5. crewhead05
    crewhead05 caffeine, nicotine, knives and nature. Supporter Bushcraft Friend
    Mar 14, 2014
    4,826
    11,583
    NW Montana
    WILL, Lichen, mash4077 and 5 others like this.
  6. Flint_2016
    Flint_2016 Guide
    Apr 27, 2016
    1,689
    5,930
    Pottsville PA.
    I checked the trac grabbers out.Great idea.Only $59 for an SUV.Thanks,Crewhead!
    fatcat55, central joe and crewhead05 like this.
  7. Foulwind
    Foulwind Guide
    Jan 29, 2014
    1,549
    1,315
    Most off-roaders I know, do at least carry ratchet straps, and some, even their own firewood! Novell idea! 12,000 lb. 2-sp Hydraulic winch in front bumper helps immensely too.
  8. lowtidejoe
    lowtidejoe Supporter Supporter
    Jun 27, 2014
    257
    1,088
    Arizona
    Got stuck in extremely silty sand, used all of the stakes we had for our archaeology survey and the floor mats from inside the truck to get the F250 out. It worked! I was calling it a “road building excercise”
  9. drobs
    drobs Scout
    Feb 22, 2014
    909
    1,468
    Africa & South Central Missouri
    WILL, Flint_2016, lowtidejoe and 4 others like this.
  10. central joe
    6,726
    39,505
    Good idea young fellar. joe
  11. fatcat55
    fatcat55 Supporter Supporter
    Feb 17, 2012
    762
    2,260
    Many years ago I did the same thing with trailer ramps to free a 4040 John Deere tractor buried up to the axles...it was a valuable learning experience:rolleyes:...I never had to do it again;)
    Flint_2016, lowtidejoe and crewhead05 like this.
  12. crewhead05
    Mar 14, 2014
    4,826
    11,583
    NW Montana
  13. bush-hunter
    bush-hunter Tracker
    Oct 1, 2017
    35
    189
    I read about a world war 2 manual on how deal with a stuck jeep. I dont remember the site i saw it on, nor could I find the manual.
    But i saw a windless winch, logs strapped to the outside of the wheel.
    But the coolest method i remember, was a empty rim a length of rope or cable and poof every car on the road has a winch.
    I try not to get stuck and the best way to get unstuck is not to get stuck.
    Winterhorse likes this.
  14. boomchakabowwow
    boomchakabowwow Guide
    Jan 7, 2015
    3,118
    2,883
    Bay Area, California
    that F250 idea was great!!
    that must have sucked picking it all up afterwards. yuk!!
    lowtidejoe likes this.
  15. Lichen
    Lichen Supporter Supporter Bushcraft Friend
    Sep 22, 2011
    3,776
    7,657
    Scottsdale, AZ
    Thanks. I'm going to order some.
    crewhead05 likes this.
  16. wrath0r
    wrath0r Supporter Supporter
    Feb 19, 2017
    845
    3,708
    Eastern Massachusetts
    Maxtrax are also an excellent way to go, and can also serve as shovels or even make a bridge. Having a winch also helps.
  17. lowtidejoe
    Jun 27, 2014
    257
    1,088
    Arizona
    We (field people) hate the F250 but all the bigger trucks from enterprise come with Kevlar tires so that’s why they rent them. It did indeed suck picking up all the stakes. We had a 12 mile day in Salome, AZ like 107 degrees before getting the truck out.
    Also, I have the X-Bull traction boards for my personal 2008 Tacoma and they are fantastic. That’s where the stakes idea came from
  18. Crazysanman
    Crazysanman Supporter Supporter Bushclass II
    Jun 7, 2012
    7,897
    14,289
    Colorful Colorado
    I have some very thick and wide zip ties that I keep in my FJ for extra traction. Kind of like the trac grabber link that crewhead posted above but not that thick.
    You can also use a heavy rope or tow strap as a winch by tying one end through the tire like the straps above and then tying the other end to a tree or boulder. As the tire spins the strap or rope will wrap around the tire and pull the vehicle forward.
    I also always carry a shovel and a set of MaxTrax knockoff traction boards.
    drobs likes this.
  19. Pinelogcreek
    May 9, 2016
    448
    1,902
    Redneck Rivera
    I’ve used the wood trick on a tractor several times and it works well. First tip is lowering tire pressure to about 15 psi or lower, you would be amazed how much that changes things. The bad part is most of the time you have to pass back through that area to get out.
    americanstrat98 likes this.
