A Question Of Alloy
Discussion in 'Edged Tools' started by Jim L., Jan 11, 2018.
  1. Jim L.
    Jim L. Supporter Supporter
    Mar 24, 2011
    1,824
    8,398
    Brunswick, Georgia
    Anyone familiar with "copper" grounding rods? What I believed to be solid copper was actually copper clad steel.
    Ordinarily, I'd of thought the steel would have only enough carbon in the mix to actually call it steel. When I cut a shank off to do what I hoped would be copper work, the cutting wheel on the old angle grinder through a bunch of really nice complex bright yellow sparks.
    So I forged a 3 inch section down to about 3/32 inches, brought it to critical and quenched in water. Then I laid it across the anvil and gave it a good wack.
    Nothing .
    Another, and another wack. A slight bend. Not only that, but the piece bounced and rebounded not unlike a spring.
    So I'm confused. Passed the spark test, failed (?) the quench/snap test, but acts like spring steel.
    Also the copper remained on the steel. Can/would someone clear this up for me?
    Quinlan likes this.
  2. Skeptiksks
    Skeptiksks Green Haired Weirdo Supporter Bushcraft Friend
    Mar 13, 2017
    2,545
    14,591
    Everett, Washington
    As far as I have seen they are just copper plated mild/whatever steel. Current travels over the skin of the conductor so a more conductive surface is a good thing, but the cost difference is stupid.
    My guess is the ground rod manufacturers buy whatever they can get a deal on so best of luck with your sample.
    To be honest a ground rod is something to be driven into the ground and then left there, they just need to be strong enough to be driven all the way into the earth. I have seen ground rods stop dead under full jackhammer weight for 5 minutes and have heard stories of them popping up a few feet away and do a huge curve under the ground. They are tough for sure, but probably not the best material for tools.
    They do make awesome window bars though...
    CHREBA, Quinlan, grizz78 and 3 others like this.
  3. OrienM
    OrienM Guide
    Mar 13, 2013
    1,782
    6,435
    Gila, NM
    So many weird things to be found in the scrap pile! ;) Hard to say, but there are some high-copper steel alloys (among others, probably) that are fairly hard/springy without being able to actually quench harden. My rule of thumb is if it won't harden enough to shatter, it won't make a knife.
    I sure wish those bars were solid copper....pure copper is amazing to forge.
    Quinlan and Skeptiksks like this.
  4. Ptpalpha
    3,905
    15,520
    You can get solid copper ground rods, but they ain't cheap!
    @Skeptiksks is spot-on: the copper clad steel is better suited for power-hammer driving 10' into the earth.
    Which is never fun.
  5. Jim L.
    Mar 24, 2011
    1,824
    8,398
    Brunswick, Georgia
    All very good points. Points as guidelines that I try to follow.
    I would never have even brought it up except for the fact that I hit it hard. A
    1 inch wide x 3/32 inch thick sample, with about 1 1/2 inch over hang. The 1 pound hammer rebounded.
    I know you will get some rebound from mild steel, but you will also get deformity in the test piece. I didn't notice any until the third strike. That's what has me asking questions.
    I played with that sample a bit and found that the copper cladding is still in tact. When ground to the steel, it has an interesting pattern reminiscent of mokume (sp?). Me thinks arrow heads. :15:
    Quinlan likes this.
  6. Jim L.
    Mar 24, 2011
    1,824
    8,398
    Brunswick, Georgia
    I
    A local electric supply place said to me "yeah, we have solid copper rods". He looked at me kinda funny when I pulled a magnet from my pocket. I'm glad he didn't try to tell me that copper's magnetic.
    Quinlan, ManyHammers, Kreger and 3 others like this.
  7. charlesmc2
    charlesmc2 Scout
    Apr 17, 2017
    513
    1,388
    Central Texas
    For conventional use of a grounding rod, at least in our soils, it is amazing how much a trickle of water will facilitate driving that rod into the ground. It's still serious work, though.
    Quinlan, Skeptiksks and morganbw like this.
  8. Coryphene
    Coryphene Guide
    Mar 27, 2014
    4,015
    12,651
    Chapel Hill, NC
    But copper and magnets do interact! Copper and magnets interacting is how we have generators and electric motors. Fun experiment: Drop a strong magnet through a copper pipe. It takes 4x or so longer to fall through the copper pipe than just falling to the ground.
    Army compasses use a strong magnet at the tip of the needle and have a copper wire wrapped around the inside of the compass. As the magnet moves around (needle finding north), the interaction with the copper wire dampens the needle allowing it to stop moving within seconds.
    LarryB, Quinlan, ManyHammers and 2 others like this.
  9. Jim L.
    Mar 24, 2011
    1,824
    8,398
    Brunswick, Georgia
    Copper and magnets do interact, but not attract. Place copper wire within a moving magnetic field will proportionally move electrons through it.
    Aluminum will form a magnetic field proportionate to its vector throught an opposing magnetic field. That's how automatic brakes work on roller coasters.
    And please, any experts out there correct my terminology or understanding of those principles.
    Quinlan, Skeptiksks and Coryphene like this.
  10. Zunga
    Zunga Bushmaster
    Dec 5, 2017
    5,358
    26,325
    British Columbia
    I've read! The presence of copper will make a forge weld fail every time. That's based on web research. So grain of salt. But if true it will affect what you can do with it. Unless you remove the copper.
    Cheers
    Jim
    Quinlan and Jim L. like this.
  11. Jim L.
    Mar 24, 2011
    1,824
    8,398
    Brunswick, Georgia
    I would please be corrected here, I believe that nickel is forge welded to copper to make makome (sp?). I don't know if copper affects forging ferrous metals.
    I can sling hammer, but am no blacksmith.
  12. DarrylM
    DarrylM Supporter Supporter
    Sep 2, 2016
    2,850
    13,976
    NE Washington State
    A roto hammer for drilling concrete, that has a hammer only setting, can make easy work of installing ground rods.
    ManyHammers and Skeptiksks like this.
  13. Skeptiksks
    Mar 13, 2017
    2,545
    14,591
    Everett, Washington
    We always used a ground rod pounding socket in a jack hammer for that. Works great until your generator runs outta gas and you are stuck driving the ground rod by hand with a mini sledge... not fun.
    DarrylM and ManyHammers like this.
  14. ManyHammers
    ManyHammers Supporter Supporter
    Feb 15, 2017
    1,169
    4,286
    Minnesota
    Lenz effect and eddy currents. Pixies and voodoo.
    Skeptiksks likes this.
  15. charlesmc2
    charlesmc2 Scout
    Apr 17, 2017
    513
    1,388
    Central Texas
    I have one of those toys--you spin a magnetic top over a magnetic surface and if you do it just right and have the surface really, really level the top will spin levitating over that surface. You'd think it would spin a long, long time since it's not touching, only friction with the air to slow it down. Doesn't work that way. The moving magnetic field induces eddy currents that dissipate enough energy that it would only spin 30 seconds or so as I recall. Interesting stuff. Scottsman James Clerk Maxwell tied it all together about the time of the American Civil war. I believe he is regarded as just a hair behind Newton and Einstein as theoretical physicists go. I believe his theoretical work led more or less directly to radio. He predicted the nature of electromagnetic waves. In other words this was not a discovery we stumbled on to, rather one we were searching for and found. Physicists were pretty smug about knowing all about the basic laws of physics. Then along came the photoelectric effect and eventually quantum physics.
    Real bushcraft stuff, huh?
