ATV implements
Discussion in 'Homesteading' started by sweet trav, Jun 20, 2019.
  1. sweet trav
    sweet trav Guide
    Oct 11, 2012
    1,509
    2,288
    ...the panhandle...and loving it!
    Anyone use any atv implements for plowing for farming?
    Ive seen some online just not sure on quality.
    Thnx
    T
  2. Forestree
    Forestree Treeforest Supporter Bushclass I Bushclass II
    Jan 16, 2014
    1,475
    4,349
    I’ve used a pull behind disc quite a bit. It could be flipped over and would ride on the wheels to pull to the site. It worked really well for me but would usually tie a couple of concrete blocks to the top to give it some more weight. Also I’d typically disc the area at least twice.
    Have also used a pull behind rough cut mower that worked great as well.... if you could ride over it with the atv then it’d get cut. Up to about 2 inch diameter or so.
    Tried using a hay rake to clear pine straw from fire breaks but that didn’t work out very well. Too many roots
    Only other implement I’ve used was a pull behind seed/fertilizer spreader that worked excellent and could be pulled across pretty rough terrain.
    I don’t have much land now and no use for an atv, but they can do a lot of great work
    gila_dog and sweet trav like this.
  3. gohammergo
    14,511
    86,293
    I have a 5' blade I use on my Yamaha Big Bear, for pushing snow and brush. I've also used it for grading the driveway. I have a couple of small trailers I pull behind for various things.
    I made a water sprayer from a 55 gallon barrel, an old snowmobile trailer axle, and a 12volt water pump. We filled the barrel and pulled it behind the wheeler to fill water buckets for the sheep and horses.
    I also have started on a skidding tool for hauling logs out of the woods.
    An ATV is pretty darn handy to have around.
    gila_dog, sweet trav and ezra45 like this.
  4. sweet trav
    sweet trav Guide
    Oct 11, 2012
    1,509
    2,288
    I have a bucket trailer...and a not so good grader...looking into plows now...
  5. bgf
    bgf Scout
    Mar 12, 2014
    353
    488
    Central KY
    I'm curious about what type of plowing you want to do. Just offhand, for plowing up a good piece of ground for the first time to grow vegetables for sale or something similar (canning for large family maybe), I would get a farmer to do the plowing and maybe an initial discing. You can use your atv, a garden tractor, small row-crop tractor, two wheel tractor, hand tools etc. later for maintaining the plot.
    I've used small plows like the ones on atvs behind big garden tractors and it isn't all that great, compared to even a small tractor, but you can turn an existing plot pretty well. I'd also be concerned about how an atv would fare with a lot of plowing on unbroken or heavily compacted or trashy ground. Even a large tractor can be halted instantly with an old root, big rock, etc. My guess is an atv would break traction quickly which might be best for its drivetrain or it might burn out clutches or whatever with regular use. Just my thoughts.
  6. marbleman
    marbleman Supporter Supporter
    Jan 24, 2015
    3,006
    11,613
    Yes, @bgf beat me to it. If you are doing initial plowing (often nick-named sod-busting) a plow behind an ATV is not the right tool for the job. A disc is another story, because the nature of it, it rolls mostly on top of the ground, but that's a secondary tillage tool. A plow is digging in. I have no experience pulling farm equipment with an ATV, but I have decades of experience pulling farm equipment with real tractors.
    If it's a single-bottom plow, in loose sandy soil, with a large ATV that is weighted down? Maybe. No ATV has the weight/traction/power that a real tractor does.
    Forestree, sweet trav and bgf like this.
  7. doulos
    doulos Supporter Supporter
    Jul 27, 2013
    2,966
    7,724
    Northern Nevada
    I have a dump trailer I used for landscaping.
    Forestree and sweet trav like this.
  8. Crusher0032
    Crusher0032 Appalachian Arthfael LB-42 Supporter
    May 9, 2016
    2,851
    16,845
    West Virginia
    I have a 7' plow on my Teryx for snow and minor dirt pushing. It's mandatory for where I live. I also have dual winches, I use the rear one for skidding logs. Works great!
  9. marbleman
    Jan 24, 2015
    3,006
    11,613
    I think for plowing dirt, as in land tillage for farming, he is looking at something like this, not a snowplow:
    EDIT: This is a moldboard plow, the oldest type. There are newer types, chisel plow, disk plow, and sub-soilers, but this is the traditional plow. That piece (plow share) on bottom is harder than the rest, and is replaceable. That's what takes all of the wear. That sharp tip of the share is being pulled along, 4 to 8 inches deep.
    Forestree and bgf like this.
  10. sweet trav
    sweet trav Guide
    Oct 11, 2012
    1,509
    2,288
    I do have a front plow for snow...im looking into brush cutters too for the atv...i think the rear farming plow may be too much for the atv as has been noted.
    Forestree likes this.
  11. Raymond Eisele
    Raymond Eisele Scout
    Jun 8, 2019
    236
    998
    We have a utv on our farm, which is very handy. As far as field work, that is all done with our tractor. Where I live, it is very rocky and hilly. I never use a plow on new ground. I use a roto tiller behind my tractor. First pass shallow, pick rocks. Second pass, a little deeper, pick rocks etc. Go very slow. I think an atv with a plow is under weight and under powered for this job. After a few growing seasons, this may change, it would be easier on a smaller machines.
