Axe and Saw PICS!
Discussion in 'Edged Tools' started by IA Woodsman, Mar 9, 2009.
  1. CHREBA
    CHREBA Scout
    Mar 21, 2017
    938
    3,386
    Northeast Woodlands
    I'm borrowing the pallet idea please and thank you .
    Subdood likes this.
  2. Subdood
    Subdood Ex-bubblehead Supporter Bushcraft Friend Bushclass I
    Apr 24, 2012
    5,237
    6,195
    Anniston, AL
    Yardman and Holmesmade like this.
  3. TraditionalbyChoice
    TraditionalbyChoice Guide
    Nov 19, 2014
    1,065
    1,938
    Upstate NY
    Rehung all of these today, they are all sitting for their oil treatment now. All hung on their old handles.
    Left to right
    -Collins legitimus CT pattern, pitted but a workhorse
    -Warren 4lb USA military axe
    - Plumb 3.5lb CT pattern, with a sheath I made out of scrap leather
    -4lb plumb jersey
  4. LJHfrstr
    LJHfrstr Supporter Supporter Bushclass I
    May 2, 2016
    341
    2,313
    The Homestead NC
    Alright, I'm wanting to learn here. When you say rehung on their old handles do you mean you were able to remove the original handles intact, refinish, and then rehang? If so, how do you remove the original handle without damaging it?
    TraditionalbyChoice likes this.
  5. TraditionalbyChoice
    Nov 19, 2014
    1,065
    1,938
    Upstate NY
    Yep, all had the original handles removed, soaked in linseed oil and re hung. I usually screw a wood screw into an old wedge, and pull the screw out with a claw hammer. The wedge normally comes out pretty easily. if not, I drill the wedge out carefully with a drill bit slightly smaller than the wedge width. If theres a metal wedge in it, it gets a little harder. With a metal step wedge, I normally drill a very small hole on each side of the wedge, and use a pair of needle nose pliers to wiggle it until it comes out. When wedged properly, the holes will be filled by the wedge expanding. For example, heres the top of one of the handles that I had to drill the wedge out of.You can see how the wedge filled the spots where the drill bit hit the insides of the kerf.
  6. Holmesmade
    Holmesmade Supporter Supporter
    Oct 5, 2010
    2,110
    2,002
    Tempe, AZ
    I learned that trick from a few threads around here and it works great! The only time it hasn't worked was with a wedge that had dry rotted from sitting in a shed in Arizona for a long time. I dug that one out in shreds with an old, cheap screwdriver.
  7. Derzis
    Derzis Scout
    Feb 8, 2017
    246
    653
    Canada
    My new Welland Vale pick head axe: +2lbs on 26" handle
    dancan, pipehand, Tangotag and 14 others like this.
  8. NakedSteel
    NakedSteel Tracker
    Sep 17, 2016
    43
    141
    I finally got around to fitting the axe head to a new handle. I picked up the one closest in size to the original at a nearby Ace Hardware, and it had an almost sticky coat already applied. Due to time constraints I rushed, and so I am not super happy with my work. I may go back and reshape the shoulders to better match and I might also go back and sand down the entire handle and re-stain/reapply linseed oil. I got a little carried away carving the handle to fit into the eye, and so I had to do a lot of hand sanding to even the shoulders back out. I also sawed the wedge off flush, which I now regret. I need to go back and coat the top with beeswax or something so water and moisture don't get down inside it and rust. The shoulder area you can see I applied linseed oil where I sanded the stain off and just called it good for now. I am going to see how well it splits wood when I get a chance and if it seems solid I will leave it be and let the next generation work on it. All in all this has been really fun and I hope to find a lot more old axes to work on.
  9. Derzis
    Derzis Scout
    Feb 8, 2017
    246
    653
    Canada
    Good looking axe, just next time use a smaller metal wedge and stick it at 45 degrees. The idea is to push the wood toward the eye edges, not the metal.
    Manu Ferrum and NakedSteel like this.
  10. NakedSteel
    NakedSteel Tracker
    Sep 17, 2016
    43
    141
    Thanks for the tip, I will make sure to do that next time. I just used the wedge that came with the handle. I was looking for one of the hollow circle ones, but came up empty. So to clarify, is it better to go at an angle with the grain rather than against it?
    Manu Ferrum likes this.
  11. Ptpalpha
    Ptpalpha Supporter Supporter
    2,681
    9,557
    What is the consensus on round wedges vs standard? I've got some stainless tubing I was considering trying as a wedge.
    big belly jon and Manu Ferrum like this.
  12. Derzis
    Derzis Scout
    Feb 8, 2017
    246
    653
    Canada
    I don't want to speak for others, but cilinders are a pain to take out. I avoid as much as possible metal wedges.
  13. Derzis
    Derzis Scout
    Feb 8, 2017
    246
    653
    Canada
    Grain has little to do with the wedge angle. You have two pieces and a wood wedge there, the grain is not the problem but the tight fit. Be sure it has some wood on each end of the wedge.
  14. Brown85
    Brown85 Guide
    Jan 24, 2014
    1,245
    1,175
    Bucks Co, PA
    I think they work about the same. Speaking strictly visually I prefer the look of no wedge, but if I had to choose I go with a smaller flat wedge. I find that most times the wedges House or other companies provide are way too wide at the top, aside from looking bad IMO, they also seem to be more prone to cracking the wood. The few times I used a metal wedge I bought one sized for a hatchet/hammer.
    Yardman and weltondl like this.
  15. CHREBA
    CHREBA Scout
    Mar 21, 2017
    938
    3,386
    Northeast Woodlands
    Well done young Sir .
  16. Craig Brown
    Craig Brown Tracker
    Apr 4, 2017
    26
    195
    image.jpg image.jpg image.jpg Newest addition.... Hibbard True Value hewing hatchet. I like the look as is just gonna sharpen and work on a nice handle.
  17. Ptpalpha
    2,681
    9,557
    Thanks for the info on the round wedges. I think I'll stick with no wedge, and if absolutely necessary I'll do a standard steel type.
    Love this place!!
    big belly jon likes this.
  18. CHREBA
    CHREBA Scout
    Mar 21, 2017
    938
    3,386
    Northeast Woodlands
    I'm gonna start first by thanking Bax40 for helping with questions about a project I was looking to undertake . I have a Craftsman boys ax laying around , the axe was fine except I wanted a more compact offering . Not necessarily lighter but more packable . So I removed the handle and looked at my options for handle lengths . I felt 24" wasn't a lot shorter to make the whole project worth the effort .
    I decided to go for a 19-20" length but that brought to mind yet another concern , weight/balance so out came the marker . I started marking out ways to lighten the head and this is what I came up with . The original weight of the head was 2.2 pounds . After mods I now come up with a weight of 1.14 pounds . I think even that minimal drop in weight will help achieve what I'm after in my home brew pack axe project . A packable axe still capable of serious work and compact enough for finer task one handed .
  19. MT_Fin
    MT_Fin Axe'aholic Supporter Bushcraft Friend
    Nov 25, 2014
    2,650
    9,360
    Finished up this beauty the other day. Really really liking it!
    From today.....
  20. CHREBA
    CHREBA Scout
    Mar 21, 2017
    938
    3,386
    Northeast Woodlands
    Really lol . Great job she's a looker to boot .
  21. MT_Fin
    Nov 25, 2014
    2,650
    9,360
    Really really
    CHREBA likes this.
  22. Brown85
    Brown85 Guide
    Jan 24, 2014
    1,245
    1,175
    Bucks Co, PA
    Nice job on that one! Glad to see it has a good home!
    MT_Fin likes this.
  23. teotwaki
    teotwaki Scout
    Dec 26, 2016
    425
    1,482
    California
    From a recent 5 day camping trip in the mountains of the high desert http://suntothenorth.blogspot.com/2017/04/a-2017-desert-renewal.html
    My main tool was the BowHack, next was the Gerber and last the long handled axe (because it needs sharpening). The saw could not handle the lower trunk's diameter and the big axe was a bit dull so I left a couple of feet of good dry wood behind.
    Forestree, Derzis, Yardman and 4 others like this.
  24. Craig Brown
    Craig Brown Tracker
    Apr 4, 2017
    26
    195
    image.jpg image.jpg Flea market find....Handle is in good shape looks like it's been rubbed with bees wax.
  25. moblues
    moblues Supporter Supporter
    May 4, 2014
    744
    411
    Within earshot of the Kenmore Range - Snohomish Co
    A Disston 30 inch. Teeth still have set.
  26. moblues
    May 4, 2014
    744
    411
    An early Kelly.
  27. LJHfrstr
    May 2, 2016
    341
    2,313
    The Homestead NC
    I saw the vinegaroon idea on this thread and just finished brewing up a batch. You mind posting a quick step-by-step process of how you apply it to the wood? Do you put the vinegaroon on the wood and then immediately wipe down with the baking soda paste? Just finished hanging my second axe head and would like to apply the groon on it.
    Holmesmade likes this.
  28. Ptpalpha
    2,681
    9,557
    Here's an old Craftsman hand sledge that I just rehafted; sanded the wood down, rubbed it with damp coffee grounds to add tannins, then grooned it and let it sit for about 15 minutes. Rinsed with the water and baking soda solution, let it dry, then blo'd it a couple times.
    Here it is next to the Keen Kutter wearing it's new mask.
  29. Holmesmade
    Oct 5, 2010
    2,110
    2,002
    Tempe, AZ
    The vinegaroon gets better as it ages and coverts the iron.
    I usually jut wipe it on with a cloth or cotton pads and let it sit for a while. When the color is about where I want it, I scrub the surface with a baking soda slurry for a bit to be sure I've covered everything, then rinse with very warm tap water.
    It probably doesn't have to be really warm, but I do it, anyway.
    After the wood dries, apply BLO with steel wool to smooth out the surface grain that raises.
    Ptpalpha, Land and LJHfrstr like this.
  30. Brown85
    Brown85 Guide
    Jan 24, 2014
    1,245
    1,175
    Bucks Co, PA
    BOOOO HISSSS! Get that hammer outta here, don't you know this is an axe thread, buddy!?!?
    Nice looking hammer though! I just bought a bucket of heads that had a few half hatchet heads, but mostly old straight peens, cross peens, ball peens, cobblers, masons, framers ETC. I'm looking forward to doing some hammer resto's here real soon!
    weltondl and Ptpalpha like this.
  31. Ptpalpha
    2,681
    9,557
    Lol, took ya long enough!!
    That's why I threw in the pic of the Keen Kutter!
  32. CHREBA
    CHREBA Scout
    Mar 21, 2017
    938
    3,386
    Northeast Woodlands
    Well I worked on my CHREBA built pack ax some more today . I took a full sized House ax handle (standard size eye) and used my 4 in all and sand paper to bring it down to fit my modified boys axe head , It's a 19" handle . Removed the lacquer and applied one rub of BLO so far . Im liking the bit profile , it should be a good ax . And the balance is spot on which was a major concern . Removing that metal from the head was just the ticket . I just missed my hopeful weight of 2.5 pounds , it weighed in at 2.10 pounds .
  33. rcwells
    rcwells Supporter Supporter
    Mar 17, 2015
    956
    4,773
    Heart of Dixie
    New additions, AS Bucksaw and Mountaineer.
    One of my Lee Reeves pack axes:
    New Gransfors Bruks wilderness axe Ray Mears edition alongside my new AS Classic
    AS Mountaineer , AS Classic, and Stephen Wade Cox 30th Anniversary knife
    Some of my Lee Reeves axe collection on custom display I made. Several more not pictured but I haven't finished making a display for the rest yet.
  34. weltondl
    weltondl Sergeant of Marines Supporter
    May 25, 2016
    1,637
    6,321
    North coast of ohio
    Wow!
    rcwells likes this.
  35. Brown85
    Brown85 Guide
    Jan 24, 2014
    1,245
    1,175
    Bucks Co, PA
    IMG_1498.JPG IMG_1499.JPG Any of you guys ever seen a pattern like this? Picked it up in a lot with a bunch of other tools. About 2 lbs, with a hatchet sized eye. Unmarked.
  36. CHREBA
    CHREBA Scout
    Mar 21, 2017
    938
    3,386
    Northeast Woodlands
    Sitting around working on getting my pack axe dialed in . Sanding and so and contemplating the weight . I decided to look at factory offerings in the 19-20 inch range and saw that my weight of 2 pounds 10 ounces is right in the ball park of the factory offerings of this size tool so I'm more than pleased . I didn't get out in the brush with it , but I did beat up on a stump out back . I like the feel of it , it'll definitely be in rotation now . This'll is the size axe that will make me rethink some things ? I have hatchets and Hawks as well as large knives and larger axes . Some pretty close in weight (Kukris) and as much as I like them . This added weight when processing wood will most definitely be welcomed .
  37. LJHfrstr
    May 2, 2016
    341
    2,313
    The Homestead NC
    Just finished hanging my second axe. Learned a lot from my first experience and things went better this time around. Got the handle from House and it was great other than the fact that I didn't pay enough attention to the eye size and had to lop almost a half inch off the front of the eye and off the belly. I've only got basic tools like a hack saw and use an oscillating tool to sand things down, so little things like that can still pose a bit of a challenge.
    The vinegaroon idea intrigued me so I started up my first batch a little over a week ago and applied it to the handle. Was really cool to see how light it went on and then how much the color deepened. At the risk of having a mismatched handle I stopped part way through to compare the bare wood to the vinegaroon stained wood. Finished it all up with a coat of BLO.
    Really enjoy doing this and this new hobby will make for some great gifts for family and friends. I'm hooked.
    I'll be taking these 3 camping with me this weekend:
  38. weltondl
    May 25, 2016
    1,637
    6,321
    North coast of ohio
    Looks good!
  39. MartyJ
    MartyJ Supporter Supporter
    Feb 17, 2014
    393
    1,637
    California
    That Diston is sweet, 30 inch is a hard size to come by. Perfect camp saw for processing larger wood and fits behind the truck seat for getting a log off the road. Nice you got the helper handle with it. Really adds to the leverage and reduces the fatigue. Reminds me that I have a 36" Superior in need of a helper and a tooth cover. Might be today's project. I have a serious case of saw envy.
    GotTheCrohns, Holmesmade and moblues like this.
  40. MartyJ
    Feb 17, 2014
    393
    1,637
    California
    Looks hand made. Shaped and weighted for splitting.
    Brown85 likes this.
  41. MartyJ
    Feb 17, 2014
    393
    1,637
    California
    You had to get this axe with the Saw! Serious old school logger tools there. Great find.
  42. CHREBA
    CHREBA Scout
    Mar 21, 2017
    938
    3,386
    Northeast Woodlands
    Nice
  43. MartyJ
    Feb 17, 2014
    393
    1,637
    California
    My 36" Superior as mentioned above. Sorry deleted the "before" pictures. Got it in an antique shop cheap, around $20 as it had a rusty blade and a broken handle held together with finishing nails. The set was good and the teeth sharp and appeared to have little use other then being stored in a shed somewhere. I am sure the owners looked it as only yard art. I was tickled to have it as my others are well over 40 inch blades and hard on an old man. Besides I like to rescue and put to use old tools that need love.
    I managed to gorilla glue the handle back together, left the nails but filed them off flush and smooth. A little oil and wax on the handle finished it off. I took the surface rust off the blade and lightly filed the teeth. I oiled the blade and the white appearing scuff marks you see is bar soap for lube. Cuts like a champ.
    It didn't come with a helper handle and the existing blade holes were smaller then the handles I had so I put together a homemade. Doesn't come off as easy as a commercial helper but I am not likely to use this as a two man due to the blade length but could switch it with a wrench. Made it out of ash and a little stout but it fits my hand.
    I like to keep a cross cut in the truck or jeep as more then once I have turned down a road and found a tree down across it. Hasn't happened yet but expect to be out during a storm and have a tree go down blocking me in so the big saw makes a handy low tech chain saw fueled by bacon and Irish whiskey. Doesn't do though to have these big saws bouncing around behind your seat bopping down the rutted roads as the it ruins the set and anything nearby. So along with the helper handle, I threw together a blade guard. Nothing fancy, just a couple of 1 x 4's separated by a blade width piece of lathe and screwed and glued together. A couple of leather holds to keep it all together. One of those fun projects, not too challenging but for once, everything went well.
  44. MT_Fin
    Nov 25, 2014
    2,650
    9,360
    After a 7wk wait, some Finnish beauties showed up at my door, all the way from their home land.......
    Billnäs 12.2 axe and a vintage Finnish Viiala File!!!! Excited to have these in my collection after wanting a Finnish axe for so long. I now have a box with a bunch more headed my way from Finland.
    What can I say, it was a long wait and I was bored and impatient, so I found a source for more.......... :)
    Keyser Söze, pik, hicountry and 7 others like this.
  45. Craig Brown
    Craig Brown Tracker
    Apr 4, 2017
    26
    195
    image.jpg image.jpg Finished this Kelly up today
    Keyser Söze, Forestree, pik and 7 others like this.
  46. Rockgod1619
    Rockgod1619 Supporter Supporter
    Apr 18, 2015
    2,033
    3,963
    Oklahoma
    New toy! Plumb boys Axe. Not sure of the head weight since it was already hafted when I bought it. Pretty happy with this flea market score! I may end up taking the wedge out and head off and bringing the shoulder down a little, then re-hangng the head just to get past that bit of broken out haft at the top of the eye, plus so I can get a little sticking out the top. What do you guys think?
    Also, anyone ever seen this with these where one side of the eye is thicker than the other?
    Next to my Norlund Voyager.
    Keyser Söze, Forestree, Land and 7 others like this.
  47. Ptpalpha
    2,681
    9,557
    That's a really nice Plumb!
    Rockgod1619 likes this.
  48. Muleman77
    Feb 13, 2014
    2,267
    8,766
    Here's a few I've been using in the last couple weeks
    Kelly perfect doubles 3.2
    Bluegrass beveled jersey, on vintage handle 4lb
    Plumb beveled kentucky 4lb
    True temper /marshal wells zenith 4.2 swamper
  49. Fixedblade
    Fixedblade 3% Supporter
    Jun 8, 2015
    4,747
    18,366
    The Old Line State
    Cleaned up a old friend!
  50. Alaskantinbender
    Alaskantinbender Tracker
    Nov 17, 2016
    33
    269
    Just a few of my favorite things with a new Mora 125 stainless knife. Old Schmidt pack saw and hunter Axe 17918029_10207750531514425_5644587826941108759_o.jpg
    moblues, VICARY, Keyser Söze and 6 others like this.
