Cast Iron stripping with oven cleaner
Discussion in 'Cooking & Water Purification' started by Toyotaholic, Apr 20, 2017.
  1. Toyotaholic
    Toyotaholic Tracker
    Apr 9, 2017
    27
    166
    SW Washington State
    Hello, my grandmother gave me her cast iron skillets that were her mother's before. They were so gunked up around the sides and on the bottom I couldn't even tell what they were. Very well used and loved. But I figured It was time to strip them so I could put my own seasoning on them.
    I did some research, found that most spray on foam oven cleaner's have lye in them. Which is the main thing for stripping old seasoning off because it's oil. It turns it to a black goo on the pan that is suppose to rinse off. Well really it worked fairly well.
    I sprayed my pans and put them in a plastic garbage bag to hold the moisture and left them for a day. Most if the crud sloughed right off. But there was carbon build up that just didn't want to budge. I ended up getting copper wool scrubbie thing that worked wonders. I even tried a wire brissel brush. It worked well too. But oh what a task. Took me about 3 days. Probably because of being impatient and not letting the oven cleaner work long enough. But enough elbow grease and I got enough off to be happy about it. I wonder what my grandma will say when she sees all the years of seasoning gone..
    RavenLoon, IzaWildman and Winterhorse like this.
  2. IzaWildman
    IzaWildman Old Dog Supporter
    Mar 7, 2016
    2,197
    11,918
    North Cacalacky
    She will probably come after you with a switch! Never tried it, but some say to remove old seasoning, just through them in a campfire and remove them when cool.
    Jdmt318, Toyotaholic and RavenLoon like this.
  3. RavenLoon
    Sep 6, 2012
    2,210
    2,324
    U.P. Michigan
    Cast iron is porous and will absorb some of the chemicals in oven cleaner. My favorite method to clean up an old cast iron pan is to build a big fire and put the pan in it, or put it in the firebox of a wood stove and burn the crud off.
    Toyotaholic, captbrian and Bannertail like this.
  4. Makarov
    Makarov Scout
    Nov 26, 2012
    563
    498
    I have never tried it but have been told that putting a pan in a self cleaning oven and cleaning the oven will also clean the pan.
    Jdmt318 and Toyotaholic like this.
  5. JasonJ
    JasonJ Scout
    Nov 26, 2014
    951
    1,869
    Bay City, MI
    Pictures? Before and after? How are you reseasoning?
    Toyotaholic likes this.
  6. Bannertail
    Bannertail Scout
    Jan 30, 2017
    282
    782
    Sometimes on road construction jobs we had to sandblast things.
    Well, someone brought his cast iron pans to work to sandblast them clean.
    Worked so well, it blasted a hole right thru one of the pans!!!:(
  7. isme
    isme Guide
    Nov 18, 2014
    2,299
    11,469
    Foothills of the Great Smoky mountains, Tn
    I cleaned up some cast iron pans that had been my grandparents. My uncle had "ruined them" left them uncleaned and untouched for years. I was given them and cleaned them with a wire brush chucked in my drill. I finished with sandpaper and then reseasond the skillets. I gave them to my daughter for Christmas this past year.
    There may be faster ways but if they are centamental, there worth taking the extra time. JMO YMMV
  8. captbrian
    captbrian Bush League Urbanite
    Jan 30, 2013
    995
    335
    USA
    Pile 'em on a hot campfire for a good long while, they'll come out of it back at Factory Square 1, if ya burned 'em long enough. After using the oven cleaner, I'd do this for sure, burn off all that nasty chemical in the pores.
  9. PERRO
    PERRO Supporter Supporter
    Jan 29, 2013
    1,272
    1,671
    CALIF
  10. manitoulinbound
    Apr 27, 2014
    2,746
    4,433
    Ontario, Canada
    I've used oven cleaner on 3 pans, does a great job as far as I can tell, then I season as you normally would.
  11. Toyotaholic
    Toyotaholic Tracker
    Apr 9, 2017
    27
    166
    SW Washington State
    I regrettably did not take pictures before I started. The inside's of the pans were great looking, just all the nasty crud around the outside and on the bottom. There was so much, plus just carbon build up on them I couldn't tell if they were marked at all. Very gunked up. Here's what they look like now 20170419_234235.jpg look it's a Wagner! Wow couldn't see that at all before.
    Couldnt see the 6 before either.
    This is the other pan there was so much carbon build up on the bottom that it was level with the ring on the inside. I could see the top of the R sticking out. BUT uncovered an 8 as well. No other marking's on this pan actually curious if anyone knows a little about it? 20170419_234353.jpg no marking's on the handle either
    Keyser Söze and RavenLoon like this.
  12. TWill
    TWill Guide
    Dec 30, 2012
    1,735
    2,097
    central MN west of Twin Cities
    Lots of the good old ones are not maker marked but that means there are still lots of stuff out there that haven't become collectible by brand name and may be easy on your wallet. Birmingham, Wagner and Griswold made good quality and can still be good buys but get a better price at flea markets and antique shops.
    If you use a fire to burn off the old burnt on food just keep in mind you don't have to have it up to forging temps. A gentle fire will do fine and leave it to cool slowly on the side after a thirty minute burn. Our grandma's would have approved of the method and probably did it. Just don't ask cast iron to go from smoking hot to a dunk in water or set on a cold surface, they will split.
  13. SmilinJoe
    SmilinJoe Supporter Supporter
    Nov 11, 2013
    3,391
    5,319
    Kyle, Texas
    http://www.castironcollector.com/unmarked.php
    That site has great info on identifying unmarked CI. Looks like you may have a 1930's Lodge.
    From that site, why you don't want to throw a pan into a fire:
    "There's another form of damage which results, unfortunately, from good but misguided intentions. You'll often hear or read how simple cast iron cleaning can be if you just burn a pan in a fire. If the fire burns too hot, however, the molecular structure of the iron can be irreparably changed. Iron so-damaged will have an often scaly, patchy, dull red appearance, different from regular rust's orange/brown. Re-seasoning over such damage is usually not possible. "
    A fire-damaged pan:
  14. JasonJ
    JasonJ Scout
    Nov 26, 2014
    951
    1,869
    Bay City, MI
    Those pans turned out beautiful! They look brand new! I have a similar wagner myself... love it.
  15. Muleman77
    Feb 13, 2014
    2,314
    8,965
    The cleanup job looks great! I've always been leary of burning them in fires, my dad quit that after a couple got ruined.
    One time my trail crew was helping do the after season cleanup. We have about 15 or 16 nice dutch ovens. They cleaned them thoroughly, and wiped everything down with BLO from the tool room!!!
    Oven cleaner for that mess......
    Toyotaholic and SmilinJoe like this.
