Chainsaw Lumber Milling
Discussion in 'Homesteading' started by stillman, Sep 23, 2018.
  1. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    We just bought a house in the mountains and are in preparations to move there. That's the topic of a different thread. The preps involve building a workshop, which I hope to do with all self-milled lumber.
    I'd like to talk about milling lumber with chainsaws. There are several different kinds of mills, all with strengths and weaknesses. What kind do you use and why?
    I'm using a couple of Alaskan mills with Stihl chainsaws. I chose them primarily because I can go to the tree without needing any heavy equipment to move it. Heavy equipment is too expensive for me to maintain, much less buy.
    I have a couple of milling projects going right now. A huge oak fell at my parent's homeplace and a friend had some straight pines dropped in his yard.
    The pines are 24" across. I'm planning to make my new workshop floors with this. Boards are 1.25" thick.
    I should get about 600 sq ft. Going to sticker them under a shed roof to dry.
  2. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    The oak is a much more interesting tree. Probably over 100 years old. Some limbs are over 24" in diameter. I'm sure there'll be a lot of movement as the wood dries so I'm cutting thick slabs to account for it.
    The trunk is a 5 foot wide mystery. It'll stand for a while, until the limbs are finished sometime after deer season. Some of it is rotten but there should be some nice tabletops in it. I'll have to get my cousin to help load the slabs with his tractor.
  3. Vanitas
    Vanitas Supporter Supporter
    Feb 28, 2013
    6,873
    8,678
    New England
    Rip chains for the win! There are a few small mills around so I don't need to own one but for the money I think the Alaskan mills are a good buy
  4. KFF
    KFF Scout
    Feb 8, 2017
    774
    3,311
    Finland
    I'm dreaming of one of those Alaskan mills. Maybe one day.
    The planks and plans are great, especially the gorgeus oak. I can see a glass top table with a hollow trunk as a foot, or even several trunk sections to make a long table.
  5. sweet trav
    sweet trav Supporter Supporter
    Oct 11, 2012
    1,247
    1,542
    ...the panhandle...and loving it!
    Im staying tuned to this thread...good stuff.
  6. whtshdwwz
    whtshdwwz Supporter Supporter
    Sep 15, 2016
    485
    1,575
    You want to paint the ends to avoid severe cracking and if possible go a bit thicker on the decking...what spacing are you giving to use for the floor juices? Depending on what cut you use can make a difference in the pine as it dries.
  7. 1066vik
    1066vik Guide
    Jan 17, 2012
    3,726
    3,162
    NE Ks
    I have a Sperber mill - similar to the alaskan mill, but uses rollers on top instead of square tubing as a riding surface, so less friction.
    also uses a dual threaded spindle to raise and lower the rollers, so I can theoretically cut up to a 35x16 beam.
    using a Stihl 076 on each end of the bar for power.
    Muleman77, MrFixIt, cek and 4 others like this.
  8. carpenter
    carpenter AXE MOB Supporter
    Feb 22, 2011
    853
    3,347
    NW GA
    Never used a chainsaw mill. I have access to a Woodmizer. But there is a great satisfaction milling your own lumber. Nice looking boards you have there.
    Muleman77, MrFixIt, KFF and 2 others like this.
  9. sweet trav
    Oct 11, 2012
    1,247
    1,542
  10. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    Paint the ends of the sawn boards or the logs?
    I'm not sure about the joists. A friend who builds houses is going to help me get started, and we're still working inside the house right now. The shop is waiting for the lumber to be gathered and dried.
    MrFixIt and RI Chevy like this.
  11. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    That's quite a set up. I'd love to go with double power heads.
    I'm running a single 661. I looked for a larger, used saw but couldn't find anything within a reasonable distance. This will cut about a foot/ minute in this 24" pine so it's not bad for the small amount of milling I do.
  12. ozarkhunter
    ozarkhunter Guide Vendor
    Dec 12, 2014
    1,445
    5,023
    Paint the ends of the logs, but since you have cut boards, yes, paint the ends to help reduce checking (cracking). You can use old latex paint sitting around from a previous project, or you can buy a product called Anchor Seal. This is made specifically for painting the ends or surfaces of freshly cut wood. It dries with a waxy feel. The latex paint will help. Use several coats as they dry. This will reduce checking, but not completely stop it. You can expect checking to go several inches into the ends of the logs as they dry.
  13. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    I've painted logs that were going to sit for a while but never thought about painting plank ends.
    Muleman77, MrFixIt and RI Chevy like this.
  14. ozarkhunter
    Dec 12, 2014
    1,445
    5,023
    As I understand, moisture escapes most quickly from the end grain, thus checking being worst on the ends. Once you cut into planks, it does evaporate from all sides without bark, but still most quickly from the ends.
  15. RI Chevy
    RI Chevy Scout
    Jul 10, 2018
    301
    754
    Ocean State
    I know a few guys that mill with an Alaskan Granberg mill. They both use Anchor Seal as soon as they are done cutting on both ends.
  16. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    I went back to this job yesterday and learned a couple things.
    First, my new MS661c was not running well at the end of the day last time I was using it. The saw ran fine without a bar but was hard to crank and then wouldn't idle. I pulled the clutch drum and saw that two of the springs were broken. I called every Stihl dealer in the area and couldn't find replacements so I just put the drum back on and went to work. Yeah, I know it's not safe but life is a gamble sometimes. This site is 50 miles from home and my old truck gets 10mpg. Can't afford to come home empty handed. Nobody had the springs in stock so I ordered a Chinese clutch assembly from Amazon. I'll rob the springs from it and save the rest for emergency parts.
    My aunt-in-law gave me an old US made, 2.8hp, 7.25" Skilsaw. I used it to pre-rip the edges of the boards, which removed all the bark and some of the live edge I would be removing anyhow. Slabbing was easier with a smooth surface for the mill "skis" to run against.
    The first log, the one stacked on top in the first picture, was more difficult to cut than the other two logs. It was the butt of a large tree and the pith was off-center. I'm working under the assumption that it was due to the grain not being as straight as the other two, which are from further up the tree and the pith is in the center. There's only one inch of taper in 10 feet.
  17. gohammergo
    gohammergo I like sharp things.... Supporter
    7,824
    39,923
    Another thing I seldom see mentioned is to frequently clean the air filter. I don't recall much mention of that in the limited research I did before I built my mill.
    I'm also running Stihl. I run 40:1 instead of the recommended 50:1 too, and only premium fuel.
  18. gohammergo
    7,824
    39,923
    It's a lot of fun milling. A lot of hard work too, but very satisfying. :)
  19. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    That's good advice on the air filter. I milled some cypress a couple of weeks ago. That stuff turns to a fine powder and does a number on the air filter and really cakes with excess bar oil.
  20. RI Chevy
    RI Chevy Scout
    Jul 10, 2018
    301
    754
    Ocean State
    For milling you might want to go 32:1 or 36:1 with your fuel mix.
    MrFixIt, cek and stillman like this.
  21. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    I ran this gas a little "oilier" than the specs but not quite 36:1. Is there any downside to these ratios?
  22. tristndad
    tristndad Supporter Supporter
    Mar 20, 2016
    201
    927
    NY
    I use the alaskan mark iii with my Husqvarna 372xp.
    Got a ton of white ash dying off from the emerald ash borer. Been trying to mill about every 4th tree I harvest, the others go into my firewood pile.
    It is defiantly a slow process on the hardwoods, but it sure feels good when I get to mill spruce or pine. I feel like I'm moving thru the logs like lighting.
    My only complaint is being bent over the muffler having to breath the exaust. 20170711_182745.jpg
  23. tristndad
    Mar 20, 2016
    201
    927
    NY
    I use a 24in bar without a sprocket and file my chains at a 15 deg angle. I also use an old fashioned oil can filled with bar and chain oil to hit the tip off the bar. 20161012_163028.jpg
    Dubhelix, Muleman77, MrFixIt and 2 others like this.
  24. tristndad
    Mar 20, 2016
    201
    927
    NY
    Milling a red maple tree, found some really cool curls in this batch. Ended up making a dinner table out of it for my lean to. 20161012_163415.jpg
    Muleman77, MrFixIt, KFF and 3 others like this.
  25. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    I'd like to take a swing at milling ash. We don't have muchof that down this way.
    I wear a washable dust mask. It helps with the dust and exhaust fumes. I'm allergic to the dust and would never finish a big job without the mask. I didn't expect it to help with the fumes but it does.
    http://www.dustbeegone.com/
  26. RI Chevy
    RI Chevy Scout
    Jul 10, 2018
    301
    754
    Ocean State
    Not really. As long as your more "oilier" than 50:1 you should be ok. Milling makes saw work harder, creates a bit more heat and stress.
    You also have to make sure the tune on the saw is correct as well.
    MrFixIt and stillman like this.
  27. gohammergo
    7,824
    39,923
    I wear a good quality paint respirator when I saw. A dust mask may mask the dust and some of the odor, but you are still inhaling fumes. With my respirator I can't smell exhaust at all.
  28. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    Stihl no call from my dealer about the replacement clutch springs. The complete clutch I ordered from Amazon arrived. It gave up its springs, the saw is back in business, and I have a few spare parts.
    RI Chevy and Muleman77 like this.
  29. Muleman77
    Muleman77 Hobbyist Hobbyist
    Feb 13, 2014
    3,766
    19,283
    I've used an Alaskan mill quite a bit. It's a great way to get lumber out of the woods.
    Ive got a Peterson as well, a higher production circle machine. But there are still times I put the Alaskan to work. I use my 660 with it.
    I use about 40:1 for milling. I've heard arguments both ways in oilier mix. What I know for sure is that I've put a lot of 40:1 through mine with no ill effects.
    Hard work, but very satisfying.
  30. tristndad
    Mar 20, 2016
    201
    927
    NY
    Still milling the pine, or busy with hunting season? Can't wait to hear how the oak goes for you. Guessing it's going to be an extremely slow and back breaking process with an awesome reward.
    stillman and RI Chevy like this.
  31. marbleman
    marbleman Supporter Supporter
    Jan 24, 2015
    2,231
    7,824
    I know an old man in Midwest USA (not myself) with 100 year old sawmill hardware for sale cheap. Cheap, as in the price of scrap iron. It's all potentially working, but he is in his 80's, and hopes to get it together. Honestly, it is not going to happen.
  32. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    I had carpal tunnel surgery this Friday instead of milling. I'm hoping to get back on the pine next Friday.
    Rifle season starts October 20. I need to have my other hand fixed so the start of hunting may be delayed for me. I guess it's ok, since it's bucks only until Nov 2 and I usually take does.
    I wasat my folks' place this weekend and looked at the oak. Its going to be a big job with some interesting crooks and bends. Hoping to make some furniture from it.
    RI Chevy likes this.
  33. RI Chevy
    RI Chevy Scout
    Jul 10, 2018
    301
    754
    Ocean State
    Anyone try freehand milling?
    stillman likes this.
  34. Muleman77
    Feb 13, 2014
    3,766
    19,283
    I have somewhat done this, cutting cedar posts for ranch fencing. Ive made thousands of them. I just freehand rip a lot of my cuts instead of trying to split everything. It gets me more uniform posts, with less waste. Taking the sapwood off, necessary for good posts, it's a big timesaver too. Knots are no issue with splitting out. A lot of times I rip partially, or through a knot, and hit it a swing with an axe to pop it free. That's a very fast way to make posts.
    Compared to any kind of mill accuracy is wildly haphazard, but thats not important at all for posts.
    I haven't done it this way, but if a person used a stringline and square for layout, similar to hewing, it could be much more accurate and would probably do for post and beam or timberframe work.
    Torrin, RI Chevy and stillman like this.
  35. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    I watched a video of some Central American guys freehand milling. It looks like a fast way to go once you get good at it.
  36. RI Chevy
    RI Chevy Scout
    Jul 10, 2018
    301
    754
    Ocean State
    Yes. I saw that video too. Pretty good job done by them. I have done some small 4 foot pieces. Not too bad. But not like using a mill. LOL
  37. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    It looks like a good, fast way to make rough lumber. There would be lots of uses for it on a farm or ranch. I kind of wish I lived on a farm or ranch.
    Merk3030 and RI Chevy like this.
  38. gohammergo
    7,824
    39,923
    I have done a fair amount of freehand work building cabins. When you spend a fair amount of time with a chainsaw in your hands, you get pretty darn good with it. I got so good cutting stuff with my stihl, that I could make better cuts in framing lumber than the other guys could do with circular saw. :)
    We used to finish off most of our basements. In MI, the basement beam has to be supported by a steel post. I used to rip a log in half, cut a channel in it, and put it together around the steel post, so the home had the appearance of log structure throughout. On inspection day, our building inspector told me i had to take the logs out and replace them with a steel post. :) Fortunately by that time i had my film developed. ( It was awhile ago :) )
    I saw a video of a guy who was ripping boards freehand, but would stand the log upright. Seemed to be easier doing it that way for shorter pieces.
  39. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    No milling this week, either. I have to attend a work meeting over an hour in the opposite direction from the milling job. Hard to chainsaw mill in the morning, then travel 2 hours to a big corporate meeting. Maybe, if I showed up smelling of chainsaw exhaust and sweat, covered in oil and sawdust, they'd quit "asking" me to attend meetings on my day off.
    RI Chevy and Guy like this.
  40. stillman
    Aug 7, 2009
    3,208
    3,030
    Notlanta
    I found myself with a few free hours this afternoon so I headed out to the job to mill for a while. I had some truck trouble (the truck is 50 years old and temperamental) so I lost an hour of work time.
    Thankfully, the saws ran perfectly and I was able to cut 6 slabs before I ran out of daylight. I should be able to finish the job if I could get full day of cutting. That's not likely to happen, so maybe 2-3 partial days will be enough.
