First try at natural cordage
Discussion in 'Other Skills' started by bmatt, May 30, 2012.
  1. bmatt
    bmatt Guide
    Oct 22, 2008
    1,949
    66
    US/Finland
    Well, I finally got around to trying my hand at making natural cordage. First, I located a willow shoot.
    Then I made a slit through the inner and outer bark, down to the wood.
    I carefully peeled off the bark.
    Then I separated the inner and outer bark.
    This was followed by cutting the inner bark into strips.
    The next step was to twist one of these strips over its entire length, until it wanted to kink (forgot to take a picture of this). I allowed it to kink (which became the end of the cord), while continuing to twist the two strands. The way I did this was to roll the strands on my leg with my fingers and palm.
    When I was finished making the short piece of cord, I tied off the end. It's not long, but I think it's OK for a first try.
    I tested its strength by pulling on it until it broke. It was surprisingly strong. Later on, I made a slightly longer piece.
    I was happy to find that making cordage like this is really easy. I don't think it will replace my paracord anytime soon, though. ;)
  2. stronghorse
    stronghorse Guide
    Jan 28, 2012
    1,025
    19
    Coastlands of Virginia
    Nice job!
    Jim L. likes this.
  3. saintnick001
    saintnick001 Guide
    Jun 15, 2010
    1,409
    Riverview, FL
    Well done. I've been practicing this at home for a while with a bag of raffia.
    Jim L. likes this.
  4. Pict
    Pict Qualified to attempt things at home Supporter
    Oct 24, 2008
    3,129
    4,754
    Grand Rapids MI
    Good on you for starting with this important skill! IMO this is something that everyone not only needs to learn but master. Your cordage looks great. Next is to learn how to splice until you can make as long a cord as you need. Thigh rolling is the way to go. Sometimes it helps to pre-roll the lengths of material on your thigh to get them going in the right direction, it really speeds things up with flat material like bark.
    Jim L. and rsnurkle like this.
  5. Longbeard
    Jan 22, 2012
    6,182
    3,310
    Iowa
    Not bad for your first time.
  6. bmatt
    bmatt Guide
    Oct 22, 2008
    1,949
    66
    US/Finland
    Thanks, Mac! Actually, there are splices in both of those lengths of cordage. :)
  7. GKiT
    GKiT Supporter Supporter
    Dec 30, 2010
    3,515
    4,592
    That looks good. I find soaking the strips of willow bark in a tub of water for a few days helps to limber them up for breaking down into smaller strips. The soaked cordage will have less stray "hairs" to remove and it seems to tighten up when it dries. If you take a willow bark cord like you have made and twist it with another one you will not believe how strong of a rope it makes...takes a good while to make though.
  8. GeorgeHedgepeth
    GeorgeHedgepeth Tracker
    Apr 17, 2012
    117
    If you shred your material instead of leaving it in wide ribbons, it will actually be stronger. The wider pieces tend to tear from the edge when twisted.
  9. roamer1000
    roamer1000 Scout
    Jan 20, 2011
    520
    Tifton Ga
    good job, now go catch a fish on it.
  10. Spider
    Spider Tracker
    May 29, 2012
    131
    Minnesota
    I've heard that willow can be strengthened by boiling in water high in tannins like maybe try Chaga tea water.
  11. Thaddius Bickerton
    Thaddius Bickerton Guide
    Dec 19, 2011
    1,143
    35
    Southern Appalachian Foothills
    Looks good for simple cordage.
    Keep working. If you have nothing else to practice with grab some knitting yarn as it is good to work with or you could try to twist / spin some out of cotton balls.
    If you have like dog shed fur or other small fibers a drop spindle can turn this into usable yarn to make a decent cord out of. A simple "drop spindle" can be made using a dowel, a bent straight pin, and a plastic lid off of a jar like a peanut butter jar or a old CD or 3 glued together. Just google fu drop spindle for pics and youtubes on how to make and use them.
    I use twisting cordage and any other cordage tricks I can learn to help my fingers learn to work since my stroke.
    My friend taught me how to twist cordage and I know words are not as good as seeing with someone looking at your work to learn the fancy stuff but I want to try to share some things I do to help make more faster better cords.
    A small step up from just twisting with hands or rolling on your thighs.
    take your fibers and two sticks (about the size of those fat first grade pencils we used to use is about right but what ever suits you would be fine.)
    Cut a couple small splits a couple inches into the ends of them (might want to wrap it with tape or some cord etc. and "pinch the fiber in each one kind of like a cloths pin.
    there are fancier ways where the fibers can be rolled onto the sticks and simple small wire hooks used to hold the fibers. But these sticks can be field improvised and speed thing up to make making a set worth while if you need a long piece of cordage or a lot of shorter ones.
    Now place both sticks together and roll them down your thigh while holding the ends or tie them to something, even your toe works if you don't mind going barefoot to make your cordage.
    As the cordage gets longer I like to make a third stick and wind it up on that and just jab it into the ground to help it give me some extra tension while spinning the twist into the fibers. Also it stores the cord out of the way till I am ready to use it.
    by reversing the twist on made cordage the other direction you can double the thickness but you loose a bit more than half the length.
    Each time you double the cordage you reverse the direction of the twist.
    This will twist them and you can hold the sticks between your knees while you let your fingers let the cord twist up.
    Then just slip the fibers on down in the sticks so more fiber to twist the next segment of your line are ready and roll em again.
    For me it speeds things up once you get used to it.
    Remember to splice in more fibers do not do both sets at the same point on your cordage.
    Just lay some new fibers next to the ones already started into the cordage and twist them so they hold together.
    As you pass the two sets of fibers into the twist you add a new length.
    Then do this for the other set of fibers at another place in the cordage.
    This makes it stronger than both splices at the same point in the cordage and allows you to make as long a cord as you need or have fibers for.
    Well I probably just confused things, but IMHO cordage is second after a knife for someone who is making things out in the woods. given just a sharp rock and some cordage you make up you can haft the rock to a stick for a hoko knife, then make a stone axe and keep improving your tools.
    Glad you found joy and success in the effort.
    I often just sit with some old string of any type I have found, or even just strips of cloth from the rag bag and twist up cordage. It helps me learn to use my body again, and there is no such thing as to much string.
    Thad.
    OrienM likes this.
  12. LarryB
    LarryB Scout
    Mar 17, 2014
    365
    1,169
    Ottawa, Ontario, Canada
    Wow! Just had to bump this. Too easy! Too cool! I'll be try'n this out real soon. Thanks for showing us this neat skill @bmatt :) lb
    rsnurkle likes this.
  13. ugar-6
    ugar-6 Supporter Supporter
    Jan 2, 2016
    640
    2,804
    Georgia
    Well done sir!
  14. OrienM
    OrienM Guide
    Mar 13, 2013
    1,657
    5,517
    Gila, NM
    Nice job!
