Flat vs. Scandi Grind?
Discussion in 'Edged Tools' started by Trojan1994, Sep 7, 2011.
  1. Trojan1994
    Trojan1994 Scout
    Aug 25, 2011
    362
    For a bushcraft knife, blade less than 5", primary task, general food prep, cutting cord and possible light wood work/batoning/fire wood prep when a heavy knife/ax isn't available.
    Which grind would you choose? Is the Scandi that much less of a slicer for food than a Flat grind assuming the knife is available in both grinds?
    Regards,
    Tony
  2. Newt
    Newt Scout
    May 28, 2011
    293
    11
    Neither can compare to a convex for strength and durability.
    Food isn't typically much of a challenge unless you are talking about my Mother In Law's.
  3. bushwolf
    bushwolf Guide
    Jan 11, 2011
    2,761
    331
    Central Maine
    A scandi will carve better, but can be damaged by rough use.
    A flat grind will be tougher, and better for batoning.
    In the end, it comes down to how you plan to use your knife.
    A thin scandi will slice just fine BTW.
  4. Hiwa
    Hiwa Guide
    Mar 28, 2011
    1,667
    936
    Alberta
    I actually don't like scandi's too much and prefer flat. I find it easier to sharpen ( less metal to take off). My Blind horse bushcrafters (3) and all my favorites are full flat grind. I like the look of the blade better also.
  5. whiskersnitch
    whiskersnitch Guest
    Ah, the age old (and somewhat tired) debate... In the end, as with all things, it comes to personal preference.
  6. Trojan1994
    Trojan1994 Scout
    Aug 25, 2011
    362
    Interesting,
    had a conversation with a guy that was telling me the scandi would be better for batoning...main use would be for food prep, light cutting/fire prep...
    Regards,
    Tony
  7. Trojan1994
    Trojan1994 Scout
    Aug 25, 2011
    362
    What a coincidence...
    I just ordered a BH Bushcrafter, flat grind!!!
    Any sharpening tips as to angle and/or stones/diamond stone?
    Regards,
    Tony
  8. beanbag
    beanbag Guest
    IIRC, the BHK flat ground Bushcrafter has a convex edge, so forget about angles, put the stones and diamonds up on the shelf, and break out the wet/dry sandpaper and a leather strop.:dblthumb:
  9. goosefacer
    goosefacer Guide
    Feb 18, 2010
    1,552
    85
    cFL
    Since we're talking the same knife and therefore same width at the spine, a flat grind will only be tougher if there is a secondary bevel - if it's a full flat to zero there will be less metal at the edge than a Scandi and therefore not be as tough.
    The full flat will be the better slicer and probably will fit the bill for you - IMO.
  10. Trojan1994
    Trojan1994 Scout
    Aug 25, 2011
    362
    Hmmm, its listed as Flat Grind...
    Guess I'll find out when it arrives!
    Regards,
    Tony
  11. Quarter Tank
    Quarter Tank Tracker
    Jul 29, 2011
    58
    i prefer full flat convex grind
  12. Kerri
    Kerri úlfheðnar Bushclass I
    Sep 3, 2010
    12,115
    2,010
    You can always convex the edge
  13. Iz
    Iz MEMBER of a BANNED Hardwoodsman Bushclass I Bushclass Instructor
    May 2, 2009
    29,227
    1,424
    The outlaw state
    A modern scandi grind is a flat grind. It's just not a full flat grind, it's about 1/4 height on most knives.
    Try them both and see what works for you I say. If you listen to us you'll get nothing but confused.
  14. Trojan1994
    Trojan1994 Scout
    Aug 25, 2011
    362
    Thanks, by reshaping it to convex
    what advantages does that provide?
    Regards,
    Tony
  15. Trojan1994
    Trojan1994 Scout
    Aug 25, 2011
    362
    I hear ya, its
    appearing to be similar to a Ford vs. Chevy debate. Thanks, I've got a bit to learn about edged tool design/materials! I just may just have to pick up a scandi as well...for the sake of knowledge!!!:4:
    Regards,
    Tony
  16. petrifiedwood
    petrifiedwood Guest
    After fooling around with a few scandi grinds I think a 28 degree scandi bevel is optimum.
    If I were making a flat grind I'd want about a 34-36 degree edge bevel.
  17. Hiwa
    Hiwa Guide
    Mar 28, 2011
    1,667
    936
    Alberta
    Congrats on the knife. Very good choice.
    I usually go 20 deg. a side for those. Sharpmaker or just by eye on a benchstone ( Norton fine india , 1000g wetstone , or 600g diamond) I have 2 black micarta with thinner handles and a green regular one. My favorite knife along with my Esee 4.
  18. Trojan1994
    Trojan1994 Scout
    Aug 25, 2011
    362
    Thanks, what is a Sharpmaker?
    Is that a brand of sharpening stones/kit or a model theddireof?
    Regards,
    Tony
  19. Kerri
    Sep 3, 2010
    12,115
    2,010
    It will help with stengthening the edge as well as in my opinion at least makes it much easier to sharpen
  20. Geneh
    Geneh Supporter Supporter
    Sep 14, 2010
    436
    456
    Mpls area
    Congrats on the knife! Now that decision is settled, the only suggestion I have is from a little wake-up call this weekend: my flat grind Rat-7, though a bit thick, wouldn't break the smaller wood (3 in, dry) as well as my son's 1/4" thick Becker...
    So I made a small wedge and after a cut, just stuck that and one smack it popped the wood open and done. Try using your sharp knife to turn another stick into a wedge. Lot's of folks here suggested it, I just didn't listen.... :)
  21. Hiwa
    Hiwa Guide
    Mar 28, 2011
    1,667
    936
    Alberta
    Sorry for the late reply. Had to log off.
    Norton makes waterstones as well as silicon carbide bench stones ( along with a lot of other items) I use their waterstones. You can buy them individually. A 220/1000 grit combination stone will do most of your sharpening. A 4000 grit can be used for a higher polish. If you can sharpen freehand they are an excellent way to go. A lot of folks sharpen with sandpaper also ( convex edge)
    DMT makes a lot of different diamond stones ; so does Lansky, Eze-Lap and others. I prefer waterstones and silicon carbide stones myself; a personal choice through experience. I prefer freehand as I can control the angle and " feel" the edge I'm making. There are very many opinions on this subject ; this is only mine.
    Hope this helps you.
    Pete
  22. Trojan1994
    Trojan1994 Scout
    Aug 25, 2011
    362
    Thanks Pete!
    I appreciate the info., last night I ordered up a Diamond Stone Sharpening Kit from Lansky as nothing similar was available locally.
    I saw the Eze-lap and may pick up a set as well.
    I will google the Norton products and read up some more, thanks again!
    Regards,
    Tony
  23. JC1
    JC1 Guide
    Aug 29, 2011
    1,425
    1,548
    Alaska
    does anyone have cross cut pics showing the different grinds? I dont have a clue which is which, actually I never cared as long as it was sharp because I didnt know it made a difference
  24. Hiwa
    Hiwa Guide
    Mar 28, 2011
    1,667
    936
    Alberta
  25. EagleRiverDee
    EagleRiverDee Guide
    May 10, 2011
    1,076
    25
    Eagle River, Alaska.
    Look here:
    http://www.bushcraftusa.com/forum/showthread.php?t=12382
    Scroll down to the third post.
  26. JC1
    JC1 Guide
    Aug 29, 2011
    1,425
    1,548
    Alaska
    thank you
  27. moxonone
    moxonone Scout
    Nov 9, 2009
    890
    15
    timmins ontario canada
    Aint that the truth.Ive been confused for the past few years. :4:
  28. mountain joe
    mountain joe Scout
    Apr 16, 2010
    537
    218
    South Central Alaska
    If I'm not mistaken, With two blades the same, one with a flat grind and the other with the scandi grind the scandi blade would be a tougher more durable blade overall. There is more steel on the overall blade on a scandi. Therefore the scandi blade would be a better blade in my opinion where rougher work is to be done such as batoning. The leading edge of a scandi may not be quite as durable as a full flat grind with a secondary bevel at the leading edge. Looks like a full flat with secondary bevel at the leading edge would have more metal at the leading edge back towards the back of the blade for a fraction of an inch. So it appears to me that a flat with secondary bevel would have a slightly more durable edge but that the scandi would be a more durable knife blade overall.
    I'm not an expert by any means. This is just the way it appears to me by looking at the two edge types.
  29. idahoelkhunter
    idahoelkhunter Scout
    Dec 1, 2010
    247
    Coastal Pacific Northwest.
    As luck would have it i just tried slicing some cheese with my Mora before checking the posts. It sucked. Cuts great until it hits the end of the grind then kicks it out. But I am not sure i would trust a 100% flat to camp chores for fear of chipping it due to the lack of metal.
    My suggestion - buy both and play with them. There are some cheap good knives to be had. Mora, Old Hickory, Green River etc. My mora has become my primary backpacking blade but I carry a Forchner boning and skinning knife when i am hunting. BTW - they never come out of the pack except to butcher.
    So... I am of no help. lol.
  30. idahoelkhunter
    Dec 1, 2010
    247
    I want to add. The mora is the first scandi i have owned. It's true what they say. There are e-a-s-y to sharpen. A convex is next on my lest for t and e before i settle on a primary carry knife. Even when i choose a primary i will probably choose to carry the dedicated butcher knives for butchering. Tried butchering a moose with a Seal Pup - that was a nightmare. Actually gave it away after the hunt i was so po'ed. Now I realize i was just using the wrong tool for the job and gave away a great survival style knife.
