Foggy Glasses
Discussion in 'Other Skills' started by crewhead05, Dec 11, 2014.
  1. crewhead05
    Mar 14, 2014
    5,275
    14,567
    NW Montana
    I have yet to find anything that will stop my eye glasses from fogging up while wearing a winter face mask. Im looking for ideas that may have worked for people. Thus far I have tried and given up on.
    - Cat crap
    - Toothpaste
    - Spray on anti fog
    - Dish soap
    - Shaving cream
    I usually just dont wear my glasses when its cold enough for a face mask because I just cant keep them un fogged. Any ideas would be appreciated. Thanks!
    Cro, JKR and Jim L. like this.
  2. okcmco
    okcmco Hobbyist Hobbyist
    Dec 23, 2013
    4,324
    2,076
    Central Oklahoma
    I spend a lot of time in a walk in freezer. It is -5 degrees F in there. I have not been able to wear my glasses with a face mask or ski mask either.
    I figured out it is not really fog. In my case, when I have to exit the freezer and hit the warm moist air, or if I try to cover my face, this fog actually turns to ice on the cold service of my lenses. I absolutely have to wear my glasses at all times so my face just gets cold.
    I wish I had a solution to tell you
  3. JohnP
    Jul 10, 2011
    5,305
    20,387
    Trinity, TX
    I feel your pain. I weld quite a bit and in the winter my glasses fog up instantly when I lower my hood. I weld without my glasses, which is like welding blind. I've tried just about everything and nothing works. Wish I could be of help.
    JohnP
    GrayGhost and Jim L. like this.
  4. Mr. Tettnanger
    Jul 14, 2010
    9,736
    13,650
    SE Pennsylvania
    I sell eyeglasses for a living.
    I have yet to find a product that works.
    JohnP and Jim L. like this.
  5. okcmco
    Dec 23, 2013
    4,324
    2,076
    Central Oklahoma
    Maybe try bush crafting while holding your breath?
    Jim L. likes this.
  6. Prof
    Prof Guide Bushclass II
    Dec 15, 2010
    2,236
    72
    Illinois
    I don't know how your mask is constructed, but if you can prevent your exhaled breath from rising up around your glasses, perhaps fogging would diminish. Maybe foam padding in the areas beside your nose, over your cheek bones, would block warm, moist, rising air, and direct it down and out of the mask.
    I have never had much luck with ski masks or even scarves over my face. Exhaled breath would soon condense, soak in and then freeze. Cold and wet was less comfortable than just cold. I have experienced some of the same problems in mummy-type sleeping bags.
  7. Frank1960
    Frank1960 Scout
    Sep 1, 2014
    857
    837
    Evans, CO
    Drat I was hoping for a cure for this but looks like we have to suffer the dreaded fogged glasses
    Jim L. likes this.
  8. caspice
    caspice Life size Supporter
    Sep 9, 2013
    241
    515
    Here and there
    I can relate to your frustration having worn eye glasses from 1979 until 2005. -180 L and -220 R.
    Beginning in 1986 I regularly rode a motorcycle during all seasons and my glasses would fog up terribly during the colder months. Made for some interesting rides to work.
    I tried Contact lenses, but they would get overly dry and itchy during the colder months riding at highway speeds.
    They were okay during normal activities, but still got a little dry during the winter and required regular re-wetting drops. YMMV
    Have you tried Contacts yet?
    I finally took the plunge and had Lasik in 2005.
    Resulted in 10/20 L and 20/20 R.
    After nine years the vision in my right eye has slipped a bit, but I still do not require eyeglasses.
    If not limited by budget restraints, Lasik might be an option.
    Those are the only options I can suggest.
  9. Blaker55
    Blaker55 Scout
    Oct 31, 2012
    215
    202
    I have this trouble to a limited degree. I usually wear a thin merino wool Buff neck gaiter pulled up to just cover my nose. The merino fabric is quite thin and most of the time my breath will pass through it and not interfere with my specs.... but not always. My biggest problem is when I come in from outside. Instant fog due to the cold glass and the humidity condensing on them.
    I worked for a large company that made respirators like coal miners wear. There was always a piece of metal that formed around your nose to seal that area from dusts. It also kept your glasses clearer so that exhaled air didn't rise up. Later, exhalation valves were added for worker comfort. Gets rid of the warm moist air inside of the respirator.
    You might try one of these masks under your facemask?
    Or you might try weaving in a small wire into the seam around the nose area so that you can form it around your nose and see if that helps reduce the warm moist air rising into the glasses area.
    Or make openings or flaps in the fabric for your breath to escape the facemask?
    Or, invent a heater that keeps your glass warm so the moisture doesn't condense on them.
    I might have to have a go at one or two of these ideas next time I have to blow snow. The way my house is situated and kind of "L" shaped, I always have to blow snow into the wind and I come in looking like frosty.
    Jim L. likes this.
  10. Bullhed78
    Bullhed78 Scout
    Jan 26, 2014
    930
    2,433
    I haven't tried them personally but I know a guy that swears by sea drops. He applies it in the morning before starting work and again at lunch time.
  11. werewolf won
    Jan 29, 2010
    14,873
    26,368
    Divers typically spit in their masks, it works well. Worth a try? My dog's nose prints always show as clear on a foggy window.
  12. Tripper Harrison
    Tripper Harrison Scout
    Sep 21, 2011
    298
    The 17 of Des Moines
    I went with laser surgery, so I could get rid of the glasses. Best 5K I ever spent.
    Jim L. likes this.
  13. mab0852
    mab0852 Supporter Supporter Bushclass I
    Jan 18, 2013
    1,359
    159
    Ft. Worth in the great state of TEXAS!
    Hmmm...a mixture of cat crap and unspecified dog snot applied with a liberal amount of spit. On my way to the patent office. I'm going to make a fortune.:18:
    Jim L. and Dubhelix like this.
  14. Myr1ad
    Myr1ad Scout
    Apr 26, 2014
    820
    1,471
    NE Massachusetts
    Rain-X wipes. My dad wears glasses and tried them on his glasses. I gave the wipes to him for the inside of his windshield.
    Ragman and Jim L. like this.
  15. Gii shi kan dug
    Aug 10, 2011
    3,958
    4,888
    3rd planet from the Sun
    Grow a beard
    GrayGhost, Jim L. and Dubhelix like this.
  16. Cro
    Cro American Grouch Hobbyist Lifetime Supporter Supporter Bushcraft Friend Bushclass I Bushclass Instructor
    Sep 29, 2010
    5,241
    2,948
    The Canadian Shield
    This, and suck it up. :18:
    I've had the problem too, for a long time. Leupold makes a set of lens wipes for their optics. They come in singles and they helped to an extent.
    I also bought a pair of rx sunglasses, Oakley Gas Cans, the way they are made the lower part is quite tight to the face, not a seal but tight. I've had pretty good luck with them not fogging up.
    Almost did the lasik but didn't go through with it. Been wearing glasses for years and years, to the point that I figure I'd lose an eye if I wasn't wearing them. Can't count the number of times mine have kept me from taking hard pokes and slaps from branches to the eyeball. Could wear safety glasses if I had the surgery to prevent this but that's back to square one so I used the coin for other things.
    Gii shi kan dug and Jim L. like this.
  17. teb_atoz
    teb_atoz Banned Member Banned
    May 10, 2010
    2,163
    572
    Do like I have had to do and design a face mask that wouldn't push the air into your face.
  18. Papa Tac
    Papa Tac Guide
    Jul 12, 2012
    1,115
    862
    Codroy Valley, NL
    Thanks, I was just wondering about Rain-X. Gonna give it a try.
    I've worn glasses since I was 8 (40+yrs), and when exerting in cold temps they fog up something fierce.
    I've given up on contacts as well, for the dryness reasons given above.
    Maybe Lasik is the answer...
    Cheers
    Jim L. likes this.
  19. Mr. Tettnanger
    Jul 14, 2010
    9,736
    13,650
    SE Pennsylvania
    Lasik may not be the answer.
    In my experience, I find that a majority of lasik patients end up in glasses eventually anyway. Some patients need them for reading, some for driving, and some to correct for the residual prescription after surgery.
    Jim L. likes this.
  20. Papa Tac
    Papa Tac Guide
    Jul 12, 2012
    1,115
    862
    Codroy Valley, NL
    Yeah, I figured that - that's why I've avoided it all this time.
    A co-worker lost his night vision after Lasik, too.
    Jim L. likes this.
  21. Woodknot
    Woodknot Scout
    Mar 28, 2014
    480
    16
    I always had good luck with cat crap while skiing, just have to use enough for a good layer.
    There are also goggles with built in fans, almost impossible to fog them up, if you dont mind wearing goggles with your mask that is.
    Jim L. likes this.
  22. runswithscissors
    runswithscissors Scout
    Jun 9, 2014
    486
    101
    Near Muncie, IN
    In Basic we just used Ivory soap. Clean glasses well and make SURE you get any grit off of them, then use bar of dry Ivory like a Crayon. Go light on it, and once you've colored both sides, rub it off with a wash rag until it's all off of there (that you can see). Worked for me at Ft. Benning and ever since :) Retreat as needed.
  23. skfsteveskf
    skfsteveskf Banned Member Banned
    Aug 16, 2014
    57
    Toledo Ohio
    I was wondering if anyone checked this out yet, it doesn't say anything about not fogging up glasses...
    http://www.rei.com/product/791256/t...ferralID=1709b5be-815c-11e4-ac6c-001b2166c2c0
    http://www.rei.com/product/791255/t...ferralID=889789c5-815c-11e4-ac6c-001b2166c2c0
    This one specifically states that it keeps GOGGLES from fogging up:
    http://workingperson.com/cold-aveng...igh-performance-mask-cap-reg-blk.html#details
    AND THEN GOOGLE HAD THE AUDACITY TO SUGGESTED THIS: http://www.instructables.com/id/Easy-Mask-To-Wear-With-Glasses/ :12:
  24. skfsteveskf
    Aug 16, 2014
    57
    Toledo Ohio
    Thank You for your service!
    GrayGhost likes this.
  25. happywanderer
    happywanderer Scout
    Sep 24, 2010
    852
    1,150
    Central Florida
  26. jetravis
    jetravis Tinder Gatherer
    Jun 2, 2014
    I ride a motorcycle in all types of weather. My face shield would fog and it made for a very entertaining ride to work. I began using defog it a couple years ago, and can get a full day of riding in without fogging after one treatment. It might work for you.
    http://www.defogitworks.com/work
    Jim L. likes this.
  27. donk
    donk Guide Bushclass I
    Sep 7, 2010
    2,206
    54
    My Grandpa used to say if you walked in from the cold through the door backwards your glasses didn't fog up. Didn't work, but made him laugh anyway.
    Donk.
    Jim L. likes this.
  28. brionic
    brionic Blissful simpleton
    May 4, 2009
    6,846
    2,570
    Iowa
    Works in reverse, too. Walk out of an air conditioned room into the sweltering heat, and cold surfaces will fog. See glasses, camera lenses, bicycles, firearms, and tools for reference.
    Jim L. likes this.
  29. chopchop
    chopchop Scout
    Apr 28, 2011
    483
    274
    east coast of Kansas
    That's what I was going to say. Has worked for me when snorkeling.
    Jim L. likes this.
  30. Luchtaine
    Jan 16, 2014
    5,293
    17,389
    Upstate, NY
    Something to try. Go to the auto parts store. The company Rain-X who makes the windshield treatment that amazingly beads water makes a product called Fog-X. It's meant for inside your windshield, may work for goggles too. I use it on the bathroom mirror to prevent fogging after a shower and it works for that.
    Jim L. likes this.
  31. crewhead05
    Mar 14, 2014
    5,275
    14,567
    NW Montana
    Good idea. Im going to try this
  32. Mr.Black
    Mr.Black WILDEROXEN Tracker Pack #1 Lifetime Supporter Bushclass I Bushclass Instructor
    Aug 17, 2010
    8,952
    6,516
    USA
    Ready?
    Potato slice, wipe the juice on wipe It off.Long story but give it a try lol
    Jim L. likes this.
  33. crewhead05
    Mar 14, 2014
    5,275
    14,567
    NW Montana
    ill try anything once..... mostly
    Jim L. likes this.
  34. wingnuts
    Feb 1, 2012
    3,139
    3,219
    NJ
    What the heck I'll throw in my 2 cents, remember YMMV. When scuba diving I use sea drops GOLD, for some reason it works better than the standard stuff. That being said here's what I've been told (as it applies to dive masks) the tooth paste is for new masks to clean off what out gasses from the silicone of the mask, so it will do little if anything for glasses.
    What happens when a mask (and I guessing glasses) fog up is tiny droplets condense on the lens surface. What sea drops and other products do is break down the surface tension of the condensed water vapor thus causing more of a "sheet" of water as opposed to droplets, so the lens doesn't fog. That being said I have had semi-acceptable results by using baby shampoo! It was recommended to me by other divers. What I might try for glasses in the future is wetting solution used in photo developing (will check the safety factor first!). Baby shampoo is prefered as it does sting your eyes but any soap or shampoo should give similar results!
    Good luck and let us know how you make out!
  35. Lerch
    Lerch Bushmaster Bushclass I
    Jun 13, 2010
    5,632
    188
    Wentzville Missouri
    I wouldn't consider this if anyone else told me that ..... worth a go I guess. I only need it for my sunglasses though since I invested in lasik. I think it has been said but it was the best 3 grand I ever spent. Went from legally blind to just about 20/20
  36. Mr.Black
    Aug 17, 2010
    8,952
    6,516
    USA
    The first time I did it was intersession skiing in Jr High our instructor showed us for our Goggle and Vaurnets( that dates it as well) it also came in handy with a 7O ford pickup,62 Chevy shortbed and a 72 dodge tradesman as a anti fog window treatment lol do a teast patch on the outside of wind shield and see if it deices better than un treated as well
    There may be a little smudging if you use it too heavy,other than than give it a go
    DISCLAIMER
    Not Responsible for any misshaps lol
    Jim L. likes this.
  37. HiWayMan
    HiWayMan Tracker
    Dec 6, 2011
    101
    I use a 3M 6000 Series half face respirator with the filters removed. It functions as a pre-warmer and does not allow fogging to happen. It does need emptied occasionally to get rid of the condensation. I wear it primarily when riding my bike in the winter months.
  38. Robson Valley
    Robson Valley Banned Member Banned
    Dec 26, 2014
    212
    27
    McBride, BC
    I worked as a commercial scuba diver for some time.
    XXX-cheap baby shampoo inside my mask. Just the very thinnest
    of wipes. It breaks the surface tension so sweat can't sit there as droplets/fog.
    Use the same inside all the rear windows of rigs like old Blazers and Suburbans.
    There are some high-molecular weight detergent (solid) sticks
    which work just as well. Does not appear to affect lens coatings on expensive
    scopes like my Nikon Prostaff 82.
    Carry it. Cool to write stuff on people's bathroom mirrors during parties.
    Next time they take a hot/steamy/foggy shower = BOOOO!!!!
  39. Bruce_A
    Bruce_A Guide
    Jul 17, 2012
    1,102
    14
    North Carolina
    I've used candle wax with good results. Just put some on both sides of your lens and polish off.
  40. Watcher of the Woods
    Watcher of the Woods Supporter Supporter Bushcraft Friend Bushclass I
    Oct 9, 2013
    1,549
    5,312
    Eastern Iowa
    Bringing this thread back to life.... Anyone found anything that works better than the fog-x?
    Mr. Tettnanger likes this.
  41. GrayGhost
    GrayGhost Tracker
    Nov 3, 2018
    38
    182
    Glasses and welding are a pain. I've taken to using the magnifier lense that attaches the the filter lense inside your hood. No glasses, no fog, no problem.
    crewhead05 likes this.
  42. riverjoe
    riverjoe Supporter Supporter
    Jun 5, 2011
    11,036
    15,846
    Northern In. On the river
    We were taught not to retreat in basic .
    Hillbilly stalker and crewhead05 like this.
  43. riverjoe
    Jun 5, 2011
    11,036
    15,846
    I didn’t read all the threads but it would seem some little clip on heaters with a battery pack would h keep the glasses above the dew point which should solve the problem
    shouldn’t take much . I suppose a guy could buy some nichron wire and fashion his own .
