Mold & Funk On Gear
Discussion in 'Backpacking' started by bourbon&bisquits, Oct 10, 2018.
  1. bourbon&bisquits
    bourbon&bisquits Scout
    Jan 14, 2012
    405
    13
    VaBchVa
    its been 3 weeks w/o the sun and nothing but fog and rain --- any tricks to clean up my gear/bags? (lysol and bleach not doing the trick)
  2. Leshy_apprentice
    Jan 14, 2016
    904
    3,319
    Mildew might leave a stain that won't come out, but I believe it is killed by the methods you mentioned. Air out indoors and make sure it's well dry before storing. I've heard the mildew stain can be reactivated easier than non-stained areas on the same gear later on if it gets stored damp. If drying outdoors, take it in overnight otherwise you'll find it damp from morning dew reversing your drying from the previous day.
    bourbon&bisquits likes this.
  3. KFF
    KFF Supporter Supporter
    Feb 8, 2017
    1,221
    5,567
    Finland
    Soaking in white vinegar before wash should help some
  4. Usingmyrights
    Jun 27, 2013
    7,240
    13,943
  5. Harper
    Harper Supporter Supporter
    Dec 13, 2014
    6,033
    39,968
    +1 on the enzymes. It should help with the funky smell and maybe even get some of the stains out. It is also used on wet suits.
    Colloidal silver can be sprayed on and will also kill mold. It will be nicer to your equipment than bleach.
    bourbon&bisquits and xrayit like this.
  6. Kona9
    Kona9 Supporter Supporter
    Nov 15, 2016
    2,160
    10,170
    Buffalo, NY
    I have permanent stain spots on my kayak pfd from it developing mold when it was improperly stored one winter. I was able to clean the mold off, but the stains seem permanent. I should try those enzymes to see if it will help.
  7. NattyBo
    NattyBo Guide
    Dec 6, 2015
    1,199
    4,406
    South Central PA
    Tea tree oil diluted makes a great cleaner. It has natural properties that make it: antibacterial, antimicrobial, antiseptic, antiviral and antifungal.
    bourbon&bisquits and Harper like this.
  8. hillst1
    hillst1 Supporter Supporter
    Nov 13, 2009
    1,266
    2,753
    North Carolina
    I use oxyclean to get the stains out and concrobium mold control to ensure it does not come back.
  9. Chriiis.Glover
    Chriiis.Glover Tracker
    May 15, 2018
    105
    380
    What do you dilute it with?
  10. NattyBo
    NattyBo Guide
    Dec 6, 2015
    1,199
    4,406
    South Central PA
    I have used this on hard surfaces:
    1/2 cup white vinegar
    3 cups water
    1/4 teaspoon tea tree oil
    mixed in a spray bottle.
    -Edited to add, I personally would not be afraid to use this mix on my own bags and such(nothing in it to mess up anything), I just have a huge bottle of the Dr. Bronners already which makes it easier.
    I also use Dr. Bronners liquid tea tree castile soap mixed/lathered with hot water on softer surfaces like fabrics and my body.
  11. Chriiis.Glover
    May 15, 2018
    105
    380
    Thanks, I’ll give it a try.
    NattyBo likes this.
  12. gargoyle
    gargoyle Scout
    Jan 7, 2010
    331
    418
    Middlebury, IN
    Cleaning your moldy gear is one step, but you need to address the cause before you will eliminate the problem.
    Dank, moist areas need to be dried out.
    Peel back any carpet/pad and examine. Remove it if its wet or stained with mold. You may need to remove some drywall or paneling? Fix any exterior leaks that may be present. Clean the area and allow to dry.
    Try a dehumidifier to get rid of the moist air. Empty it often.
    Chemical treatments (Damp Rid) will also soak up excess moisture, which you then dump outside or down the drain.
    Adding ventilation or a fan will help, but be sure the mold is gone or you risk spreading the spores elsewhere in the home.
    Even putting a incandescent lightbulb in a closet can be helpful. The heat from the lightbulb (left on 24 hours a day) will reduce the moist air.
    An AC/Central air unit will also lower the humidity level.
    Clean your gear outside to prevent spreading the spores inside And then store your gear elsewhere until you remedy the cause.
  13. bourbon&bisquits
    Jan 14, 2012
    405
    13
    VaBchVa
    thanks to all -- some new ideas
  14. Ptpalpha
    5,663
    23,548
    My takeaway from this thread is the surprising (to me, at least) lack of any one product/mixture that has bcusa members saying "This. This is what works, used it for years and it does the trick on moldy funk."
    with other people posting "Yep. That's the stuff. Buy some and your mildewy gear problems are solved."
    This alone tells me that a mold & mildew problem is difficult to completely get rid of.
    Quick anecdote:
    I once bought a vintage ruck that arrived reeking of mildew. I tried oxy clean, white vinegar, sunlight, everything I could think of, but there were so many folds and crevasses in the thick canvas that it always ended up still smelling funky.
    After searching the vintage military uniform collectors forums for a few hours I came across a method that quite a few people endorsed: cheap vodka. Yessir, douse the offending piece with cheap vodka and let it dry completely.
    So I tried it and while I won't say it was a 100% success it worked far better than any of the other methods I tried.
    If all else fails, buy a cheap fifth of vodka, put it in a spray bottle, and soak the hell out of the stinky item.
    Plus it's fun to squirt vodka into your mouth with a spray bottle.
    Panzer likes this.
  15. grey mouse
    grey mouse Scout
    Sep 17, 2014
    813
    1,794
    Pace, Fl
    Often times the product that you use on mold or mildew only kills the exterior layer of the substance and runs off hence why you may see a stain or notice that it comes back. Mold often has tendril like roots that get into surfaces that the chemicals do not penetrate deeply enough to destroy. Using a product with Microban will usually do the trick since it seals the area and prevents the mold from getting oxygen. If the substrate is porous then treat both sides to re-mediate. Also, most fungi's and molds can be re-mediated with a proper fungicide or mildicide containing a micronized copper azole compound (aka copper dust like they use in pressure treating lumber). Just look for ones that are green to blue in color as that is often a sign of the copper tarnishing inside the bottle.
    Ptpalpha likes this.
