Multiple Firestarters And Order Of Use
Discussion in 'Fire' started by CSM-101, Jul 25, 2017.
  1. CSM-101
    CSM-101 Scout
    May 7, 2015
    361
    1,387
    I was talking to someone recently about what type of gear I carry and I mentioned that I carry several types of fire starters. I generally carry a ferrocerium rod, a Bic lighter and a pack of storm matches along with some tinder.
    Of course they asked why I carry multiple starters and I explained the importance of being able to start a fire and the need to carry a backup or two, and then they asked which one I would use first.
    That was actually a good question, and got me thinking about the order I use them. My Light My Fire Army 2.0 is rated for 12,000 strikes, so even with several strikes per fire means I should get several thousand fires out of one. It makes sense to me to use this first as it will last the longest.
    I've never smoked so I don't really know how long a Bic lighter will last, but based on my usage a butane lighter should be good for several hundred fires. So I figure this is my second to use item.
    A match is a one time use item, so I tend to save these as my 'last resort' option.
    Obviously there are some conditions that would change things. A ferro rod is pretty dependent on good tinder prep, so if I couldn't get good feather sticks due to wet wood or (shudder) not having a knife on hand I might have to use some of the tinder I carry, which is also a one time use item. And if I were very cold I'd skip straight to the Bic to get a fire going as quickly as possible (insert 'ain't nobody got time fo that' meme here. :D)
    Thoughts?
    Broke, DomC, Midwest.Bushlore and 9 others like this.
  2. Red Wing
    Red Wing Guide
    Mar 10, 2016
    1,836
    5,211
    Dublin, oh
    Ill tell you I think 100 fires from a bic might be generous. May e if you throw a rubberband under the gas lever.
    I dont get a ton of mileage out of them, usually have a spare in my kit for that reason.
    Also carry a ferro rod and waterproof matches. Uses the bic 100% of the time. Has came in handy on more than one occassion.
    In cranberry my buddys bic shat out and didnt have any source of fire. Needes one for his canster stove.
    I was the only guy with multiple sources of fire and he ended up needing mine.
    Broke, DomC, longhunter and 7 others like this.
  3. quietmike
    quietmike Hardwoodsman Supporter
    Aug 4, 2010
    820
    1,002
    middle Tn
    The ferro rod or especially friction methods get used when its covenient, simply because my skill with them aren't where I'd trust my life to them. Basically I'm still practicing them to get better.
    If I'm cold, wet, or otherwise NEED a fire, I'll use whatever is fastest and most foolproof
    Usingmyrights, Broke, DomC and 6 others like this.
  4. Jasonacraft
    Jasonacraft Scout Bushclass I
    Feb 8, 2015
    829
    1,895
    Central, North Indiana
    I use a ferro rod almost exclusively. Still carry two bics, but honestly usually forget they're there.
    Broke, DomC, crewhead05 and 6 others like this.
  5. Winterhorse
    Winterhorse Supporter Supporter Bushcraft Friend
    Feb 14, 2013
    10,006
    29,556
    Kansas
    I am of the school of, "Go hard to easy". In other words use the least dependable method first when you have the time and conditions. If you use your ferro rod for 90% of your fires then you're teaching yourself good tinder discipline. (I would add that regular paper book matches are great for learning to patiently prep
    Your tinder and wait out breezes or find a wind break) If you can consistently get a fire going with a paper match then you're pretty skilled.
    Usingmyrights, Broke, DomC and 10 others like this.
  6. motman241
    motman241 Scout
    Mar 5, 2014
    300
    493
    Flint and steel, then ferro rod, and if I have to - Bic lighter.
    The Bic lighters (I just say that so as to not be confused with Zippo-style lighters) are cheap enough and small enough, I have them stashed in bags, and pouches, and packs, and pockets.... even when empty, they still spark. ;)
  7. DomC
    DomC Retired Old Scrub Stomper Supporter
    Dec 12, 2011
    8,671
    23,281
    East Central Florida
    I carry three ignition devices, ferrocerium rod, matches, and Butane lighters. The majority of the time I use my ferro rod first. I rarely use matches or the lighter, but they're there, just in case.;) I also use f&s when I'm feeling 'primitive'...
    Dom
  8. MrFixIt
    18,549
    71,095
    The same for me. I also have a credit card sized Fresnel lens stashed here and there.
  9. perdidochas
    perdidochas Scout
    Mar 28, 2013
    985
    797
    It depends on your time frame, and the urgency. I don't think any one rule will work for all. If you need the fire fast, the lighter or matches are the best bet. If the lighter or matches doesn't work, then go to ferro. However, to effectively use the ferro requires practice, so if you have time, it's probably best to use the ferro. If you were in a long term emergency situation, your order makes sense. Short term, it's probably go with the lighter first.
  10. HP500
    HP500 Scout
    Jul 4, 2016
    853
    2,905
    Preferred order:
    Flint and steel
    Bow drill
    Ferro rod
    Zippo
    Bic
    Matches
    However, if I fell into an icy creek, I would whip out the Bic first.
    Broke, rsnurkle, MrFixIt and 4 others like this.
  11. Coryphene
    Coryphene Guide
    Mar 27, 2014
    3,992
    12,431
    Chapel Hill, NC
    Ember based>Ferro rod>Bic>Stormproof Matches>Road Flare
    Tinder order is always: on-site gathered>fatwood>go home cause fire is not happening, seriously, who can't get fire going with fatwood?
    Broke, morganbw, DomC and 5 others like this.
  12. Bent Chile
    Bent Chile Tracker
    May 28, 2012
    153
    223
    Heyburn Idaho
    My fire carry other than everyday is flint and steel with a lense, Bic , and matches. Now I tend to use them in that order but IF I need a fire right now I go with the Bic. I know a lot of folks question a Bic and its useful life but as a former smoker I seldom bought more than 3 lighters a year and on average I flicked my Bic 60 times a day! and a flick was a 3-5 second burst so unless your lighting wet or overly large fuel you can expect a bic to last for 6 months or more in the woods cuz I doubt you'll be lighting 60 fires a day. As a smoker I carried my Bic in my pants pocket and in the 45 years I smoked I don't think I found my lighter had emptied in my pocket by accident so carried in a tin in your fire kit is a pretty safe bet it will preform.
    Broke, DomC, MrFixIt and 2 others like this.
  13. Terasec
    Terasec Guide
    Dec 7, 2016
    1,326
    4,483
    NYC
    To me depends how badly i want that fire
    Cold and hungry ill use gasoline if it will speed things up
    I have a few zippos but stopped carrying them
    They just dont store well and lose fuel quickly
    Bic lighters i mostly use for when i cut cordage to stop the ends
    Fire starting its matches or ferro rod
    Pretty even split of which i use the most
    Broke, DomC, MrFixIt and 3 others like this.
  14. Chris L
    Chris L Tracker
    Oct 17, 2017
    101
    425
    New Jersey
    Great thread. I’m still trying to come up with the right fire kit for me and more importantly the skills. Currently I’d go with a ferro rod, lighter, and matches, but I need to work on my tinder supplies too.
    Broke, CSM-101 and MrFixIt like this.
  15. House of Horst
    House of Horst Have knife, will travel Supporter
    Jul 5, 2016
    831
    2,895
    Tucked in the WV Eastern Panhandle Appalachians
    I normally have a ferro rod, an Exotac titanLIGHT zippo-style lighter (leak-proof), and occasionally also a Bic (which I honestly haven't carried as much now that I have the titanLIGHT) with me. That titanLIGHT has been freaking awesome. It is seriously leak-proof. If I had any complain it's that occasionally when I open it some fuel has collected around the cap threads, but it burns off/evaporates quickly. That being said, I've been trying to start all fires with ferro rods as of late. I like the practice it makes me take with tinder prep.
    Broke, CSM-101, DomC and 1 other person like this.
  16. DomC
    Dec 12, 2011
    8,671
    23,281
    I read somewhere a regular Bic lighter could light 3000 cigarettes depending upon usage....
    If You Were A Chain Smoker You could Light Your Next Cig With The Last one and save on your lighter....ugh!:eek::46::p
    Dominick......
  17. field-expedient
    field-expedient Misfit Supporter Bushclass II
    Jul 5, 2013
    2,697
    10,191
    My most used and first choice is just regular old book matches. Can get them free at the gas station, they are expendable, and go unnoticed in the watch pocket on a pair of jeans. I carry some other stuff too but most of the time the book of matches gets it done.
    BBizy, Broke, CSM-101 and 3 others like this.
  18. CSM-101
    CSM-101 Scout
    May 7, 2015
    361
    1,387
    I have a weakness for Exotac gear, and I've been eyeing that TitanLIGHT. I was curious about how well it retained fluid, I didn't want to end up with another disappointment like the CountyComm Peanut lighter.
    MrFixIt, Broke and House of Horst like this.
  19. Fat Old Man
    Fat Old Man Perpetual Student Supporter
    Jun 12, 2011
    4,183
    6,718
    SW Tenn, McNairy Co.
    If I'm out having fun, I'll use the ferro rod, a SERE sparking tool, Doan MagBar, or flint-n-steel. If I mean bidness, a BIC lighter or matches. I have not embraced "friction" fire-making to date.
    MrFixIt, Broke and CSM-101 like this.
  20. Kona9
    Kona9 Supporter Supporter
    Nov 15, 2016
    1,338
    4,592
    Buffalo, NY
    I have a suspicion that Santa will be leaving me a Titan light in my stocking. I'm looking forward to using it as I wanted a lighter with all of the pros of a Zippo such as a large continuous flame, but without the negatives of going dry quickly.
  21. House of Horst
    Jul 5, 2016
    831
    2,895
    I've only had it for about a month, but it has retained fluid CRAZY well. The seal is awesome (both of them). If I had a complaint, it's that while sealed, some fluid may leak slightly and get around the cap threads. Just be careful when lighting. It's never leaked on me yet though. I love it. Seriously awesome piece of gear if you like/prefer liquid fuel lighters.
    MrFixIt, Kona9, Broke and 1 other person like this.
  22. House of Horst
    Jul 5, 2016
    831
    2,895
    In my experience, it's not QUITE as wind proof as a zippo, but it's darn close. Definitely willing to put up with it for not leaking fluid, though.
  23. DarrylM
    DarrylM Supporter Supporter
    Sep 2, 2016
    2,746
    12,966
    NE Washington State
    Chain-smoking is a destructive habit, but the mindset of using what one has in order to get what one wants, is worthwhile.
    MrFixIt likes this.
  24. DarrylM
    Sep 2, 2016
    2,746
    12,966
    NE Washington State
    I carry many methods of ignition because it's fun. I also carry a goodly quantity of prepared tinders. And order of use is dependent only on whim. If, however, I was to find myself facing weeks without an opportunity to resupply, I would become a tinder hoarder of the first magnitude. Anything we can find around us that lends itself to tinder and kindling makes preserving our ignition sources easier. Once the fire is going, it helps prepare the resources for the next fire.
    MrFixIt likes this.
  25. Paul Caruso
    Paul Caruso Scout
    Dec 8, 2011
    286
    732
    North of Lake Superior
    When I am out I always have a bic lighter. If I am out and about in the woods I use and ferro rod; flint and steel, matches; bic; or a magnifying glass in my bag. In the woods I always carry cotton balls saturated in vaseline. I am going to start using friction fires again as I just found my old bow drill kit I made over 10 years ago. It should be even drier now.
    MrFixIt and DarrylM like this.
