Question about Artificial Sinew ?
Discussion in 'Other Skills' started by mainewoods, Mar 11, 2018.
  1. mainewoods
    mainewoods Maine Supporter Bushclass I
    Jan 18, 2010
    18,364
    17,074
    Central Maine
    whats a good needle size ?
  2. mainewoods
    Jan 18, 2010
    18,364
    17,074
    Central Maine
    Will a sail needle work ?
  3. YetiJack
    YetiJack Scout
    Feb 14, 2017
    311
    1,575
    Northern Kentucky
  4. Seeker
    16,998
    21,103
    In the woods
    If you're having to use an awl to punch the holes anyway, I use an embroidery needle... part of that's my old eyes (easier to thread), part of it's necessary due to the thickness of the sinew.
    A normal sail needle would be too thick for most of the leatherwork I do.
  5. Scotchmon
    Scotchmon Supporter Supporter
    Dec 14, 2016
    2,052
    10,470
    Crystal Lake, Il
    I’ll pick one by the size of the eye. If I can thread the waxed nylon (artificial sinew), through the eye, the needle is is most likely stout enough to handle the task.
    That being said, the thinner the needle, the easier it is to pass through materials.
  6. mainewoods
    Jan 18, 2010
    18,364
    17,074
    Central Maine
    Going through birch bark .
  7. Boondocks70
    Boondocks70 Supporter Supporter
    Dec 11, 2012
    275
    925
    Eastern Ohio
    + one on the "S" curve needle from Tandy. Expensive, but worth every penny. It does take a bit to get used to using but easiest by far once you learn!
  8. Scotchmon
    Dec 14, 2016
    2,052
    10,470
    Crystal Lake, Il
    I’ve never sewed birch bark, but my guess would be to punch holes first. With a heavy enough needle one may be able to push the threaded needle through. On thick materials I’ve used a leather pad to push, and at times a pliers to pull. Needles are generally widest at the eye so it may need a little force to go through. Punching holes prior would sure make it easier on your fingers.
  9. Gman1051
    Gman1051 Scout
    Dec 7, 2017
    260
    879
    Hewitt, Texas
    I don't think artificial sinew is cotton; it melts instead of burning. Maybe polyester or nylon.
  10. YetiJack
    YetiJack Scout
    Feb 14, 2017
    311
    1,575
    Northern Kentucky
    mainewoods likes this.
  11. Scotchmon
    Dec 14, 2016
    2,052
    10,470
    Crystal Lake, Il
    Good call! Very strong stuff, too! I have a large spool of the stuff that I acquired over 40 years ago and my Pops and I have used it since then and I would say it is more than I’ll use in my life time. My guess is that it is about 900 yards.
  12. werewolf won
    Jan 29, 2010
    14,711
    25,286
    I use that to lash my wood frame kayaks together, I have a boat that I was making while listening to the summer Olympics in Atlanta so that was 22 years ago, and they lashing are as solid as when they went in and have never rotted in years of exposure to salt water. That is tough stuff!
  13. J.M.
    J.M. Scout
    Aug 26, 2012
    479
    225
    Pretty sure artificial sinew is nylon. Very tough and strong, rot free. As to sewing with it , I usually split it by half. Its a lot easier to work with this way. You just have to flatten /straighten it and then pull it a part slowly so as to not get a snarl in it. Tandy makes a sewing needle with a larger eye, that's what I use.
    werewolf won likes this.
  14. snapper
    snapper Guide
    Jan 4, 2012
    1,224
    1,573
    central NYS
    Folks who have mentioned that artificial sinew is made from nylon are 100% correct. As for the size of the needle to use, my guess is that will be based on what it is your sewing. I've only worked on birch bark once and I totally blew it. The bark was too dry and my holes eventually broke through the seam area I was making. You might want to be sure the bark is limber, at least dampened down, before sewing it. Pre-punching your holes is probably a good idea as well.
    Also, J.M. already mentioned it above but you don't always need (or want) to use "full strength" sinew on your projects. I use very narrow strands when doing beadwork but beefier ones when making moccasins. Eventually you'll get the hang of what it is you'll need but until then, it's all just one big experiment :D
    That's all for now. Take care and until next time....be well.
    snapper
    J.M. likes this.
