Quick Release Knife to Belt Dangler Attachment - No metal hardware!
Discussion in 'Self-made Gear' started by oneshot, Dec 11, 2016.
  1. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    Hello everyone, I'd like to share method I came up with to attach your knife to your belt using a quick release system. It forms a dangler type attachment without using any metal hardware. My earlier thoughts/post about Ötzi the Iceman's belt actually give me idea for this!
    Here it is with the knife attached:
    Knife removed:
    Benefits
    1) Quick Release-call me lazy but I don't like to undo my belt and take off my knife every time I decide to climb into a bed or hammock for a cat nap!
    2) Turns a regular sheath into a dangler type for freedom of movement
    3) No metal hardware, can be made using wood and cordage
    4) Can also be used to hold a folding saw (temporarily)
    I think it's pretty easy to see how it is made, but here are a few details:
    Toggle
    -My toggle is fairly simple, but make yours as fancy as you like!
    1) Make the toggle out of a piece of hardwood or any other suitable material. Mine is about 2 ¾” (70mm) long and 1/3rd inch thick (9mm). Chamfer the ends.
    2) Drill a hole through the center of it (mine is 5/64” but you'll need to customize yours based on the cordage you are using)
    3) Take a 6 inch piece of bank line or other cordage, slip it through the belt loop of your sheath, and push the ends through the hole in the toggle. Tie an overhand knot as a stopper on the other side of the toggle. You want about an inch distance between the toggle and the sheath. Melt the the stopper knot slightly to prevent it from undoing.
    Belt loop
    -The belt loop can be left on the belt which is handy. It can be moved into different positions but tends not to slide when under tension. Please note that these loops could catch on something causing injury, so use them at your own risk! Use cordage that is rated less than your body weight for safety.
    Back (inside) of the belt:
    Here is alternative method using an overhand knot, if you don't want to melt the ends together:
    1) Start with a piece of cord about 7 inches long. You'll need a knot called an inside cow hitch to tie around the belt. It is quite simple to tie, and instructions can be found here.
    2) Melt the free ends of the cord together, check for strength when cooled, and slide things around so that the joint is on the back side of the belt. ***For those of you that are concerned about the strength of a melted joint, you could use the alternative method above, also see notes below***
    3) Make sure that the resulting loop is just under an inch in diameter so your toggle just barely slips through it, as seen below. If it is too large you could lose your knife.
    Slipping the toggle through the loop:
    An added bonus of the system is that a small folding saw can also be attached to the toggle temporarily. Just tie a short loop of paracord onto your saw and loop it around the toggle! Very handy when you have cut some wood to take back to camp.
    Notes
    Don't trust a melted joint? You can use a knot (eg. overhand or other small two-strand stopper knot) at the bottom of the belt loop. If you do I suggest you melt the knot slightly because they can come undone too! There are also alternative methods of joining the ends of paracord that can be found online. Some involve extra stitching which is a good idea. Personally I like a weak point in the system in case the loop was to catch on something***
    -the secret to a strong melted joint is to use a ensure that the inner strands/outer sheath are cut flush and use a stationary flame like a candle. Melt both ends at the same time, press together symmetrically, and smooth with moistened fingers when it is just cool enough to touch. Don't burn yourself please! To test the joint, pull in opposite directions as hard as you can... if it can take the force without breaking (even a little) then I think it can handle the weight of your knife.
    -the same system can be used to attach other tools/items to a belt or backpack such as flashlights, saws, heavier firesteels, etc.
    -for a leather sheath, paracord may be better for the toggle loop as it would probably abrade the leather less than bank line.
    -this system is not great for flimsy/thin belts, as the belt loop may cause the belt to compress and the loop to become too large. A stiff leather belt works well.
    -the belt loop can be removed and used on another belt of the same width
    -the belt loop does make getting the belt on more difficult, so it is not a great system if you are using the same belt with many different pairs of pants. In this case a permanent loop in the belt would be better.
    -be sure to check the cordage and melted joint regularly and replace if abrasion is present
    No doubt you will all suggest improvements to this design, so please let me know what you come up with and post photos if you can!
  2. Subdood
    Subdood Ex-bubblehead Supporter Bushcraft Friend Bushclass I
    Apr 24, 2012
    5,236
    6,080
    Anniston, AL
    Dude, this ingenious indeed. Great idea and thanks for sharing it.
  3. ineffableone
    ineffableone Guide
    Apr 20, 2012
    1,689
    294
    Pac Northwet
    Simple and oh so smart. Great idea and great of you to share with the community.
    vyking, woodsmanjohn, oneshot and 2 others like this.
  4. Winterhorse
    Feb 14, 2013
    7,687
    12,505
    Kansas
    Love it and I'm going to use it!
    vyking and oneshot like this.
  5. Leshy
    Leshy Scout
    Aug 4, 2016
    457
    1,439
    Very cool. Thanks for the idea and the inside cow hitch tutorial too.[emoji106] Very useful indeed.
    vyking, oneshot and Haggis like this.
  6. bo'sun carl
    bo'sun carl Hobbyist Hobbyist Supporter
    Oct 20, 2013
    704
    531
    lincoln coutny, Missouri
    Very cool. Thank you for sharing.
    Carl
  7. Jean
    Jean Guide
    Aug 2, 2012
    1,641
    584
    I've got a couple of places to throw one of those cow hitch loops on right now.
    vyking, Haggis and Subdood like this.
  8. davidchagrin
    davidchagrin Scout
    Jan 7, 2016
    394
    971
    Great concept. It got me thinking about creating a button quick release. Button on a loop of fabric(leather) around the belt, then have a slit in the sheath to receive the button.
    Sent from my LGMS428 using Tapatalk
    vyking, Togus and Haggis like this.
  9. CoolBreeze135
    CoolBreeze135 Scholarly Woodsman Supporter
    Feb 20, 2014
    2,992
    10,766
    East TN, Smoky Mtns
    Great idea!
    vyking, Subdood and Haggis like this.
  10. twotreesjoe
    twotreesjoe Tracker
    Jan 14, 2016
    125
    63
    This is going to be vey handy, thanks!
    vyking, oneshot, Haggis and 1 other person like this.
  11. Guillaume Longval
    Guillaume Longval Scout
    Apr 6, 2016
    993
    4,030
    Québec
    Awesome!
    I love it!
    vyking and Haggis like this.
  12. backwoodstrails
    backwoodstrails anatidaephobic Supporter
    Jun 20, 2010
    2,479
    1,557
    Southern California
    Great idea, seems a bit Otzi inspired.
    vyking, Barry J and Haggis like this.
  13. bladesmith3
    bladesmith3 Supporter Supporter
    Nov 2, 2016
    862
    1,830
    any helpful hints on how to make the melted paracord junction strong? call me paranoid. lol I have melted tons of paracord but never welded it together.
  14. highlander
    highlander Guide
    Apr 11, 2010
    2,930
    2,645
    Scott County,Tennessee
    Nice idea! Another wood turning project for someone to consider.
  15. NJHeart2Heart
    Jul 29, 2016
    2,416
    9,974
    That's brilliant! and applicable to all kinds of other stuff too. thanks for sharing!
  16. MrFixIt
    11,224
    28,149
    I'm just going to echo what everyone else has said, a great idea!
  17. bobs1415
    bobs1415 Supporter Supporter
    Jun 25, 2014
    682
    1,455
    Clever you are.
  18. WildMedGuru
    WildMedGuru Scout
    Mar 18, 2010
    432
    448
    TN
    If that just isn't kinda cool!
    Haggis likes this.
  19. kelpie13
    kelpie13 Tracker
    Sep 25, 2014
    197
    411
    Pacific Northwest
    Brilliant!
    Haggis likes this.
  20. longhunter
    longhunter Northman Supporter Bushcraft Friend
    Jan 13, 2011
    1,335
    1,273
    Upstate
    Good idea him say.
    Haggis likes this.
  21. Haggis
    Haggis Supporter Supporter
    Jan 27, 2014
    3,221
    7,267
    Northern Minnesota
    That belt/loop idea would work well for a hatchet too,,, don't even need the toggle, just enough loop to accept the handle,,,
  22. Rockgod1619
    Rockgod1619 Supporter Supporter
    Apr 18, 2015
    1,730
    2,590
    Oklahoma
    That's awesome!! I'll be using it!
  23. Togus
    Togus Supporter Supporter
    Jan 11, 2016
    1,213
    2,912
    K.I.S.S. I like it.
    Subdood likes this.
  24. Spork
    Spork Supporter Supporter
    Jun 14, 2009
    6,035
    3,106
    Zombiewood, CA
    I think I would prefer a one piece cord arrangement. It would be just as easy to feed the toggle behind your belt and hitch it. I think also I rather close the loop with a button or lanyard knot rather than depend on a melted joint.
    I think I'll give it a try...need to carve a toggle first
    SmilinJoe and Subdood like this.
  25. backwoodstrails
    Jun 20, 2010
    2,479
    1,557
    Southern California
    I agree on the knot, that's how I have done a similar arrangement. Knot in the loop, girth hitch around the belt, however I have been using the tips of antler tines for
    my toggle, I like wood but love the look of the antler tine.
    I like the way the OP has attached the loop to the belt since the girth hitch seems to come undone from the belt easily when there is nothing attached.
    Subdood and Spork like this.
  26. Spork
    Jun 14, 2009
    6,035
    3,106
    Zombiewood, CA
    I was thinking maybe two knots tied close together to form a buttonhole of sorts to hold the toggle more securely.
    TN_Woodman and Haggis like this.
  27. ACinSA
    ACinSA Bring it, don't sing it! Supporter
    Nov 17, 2011
    1,261
    981
    San Antonio, TEXAS
    Pretty slick doings sir...well done!
    Haggis likes this.
  28. Draketake
    Draketake Guide
    Jan 3, 2013
    1,206
    414
    Central Oregon
    This.
    Haggis and MrFixIt like this.
  29. chasntuna
    chasntuna Guide
    Aug 25, 2013
    1,088
    1,660
    Upstate SC
    Yooooooouu.....yoooooooooouu...
    Your gooooooood!
    That'll be used when I go tuna fishing for my plier sheath. Sucks taking by belt off every time I sit in the galley.
    Very slick!
    Haggis, Subdood and savage99nc like this.
  30. tiny80022
    tiny80022 Hobbyist Hobbyist Supporter
    Jul 24, 2009
    1,811
    767
    colorado
    Brilliant. Thanks for sharing
    Haggis likes this.
  31. Hoof
    Hoof Guide
    Apr 11, 2015
    2,351
    8,894
    South Louisiana
    I like it. Thanks for sharing this
  32. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    Good question! I have updated the post with some tips on melting the paracord together. See the notes section.
  33. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    I have updated the post with a second method using knots rather than joining the paracord together. Is that sort of what you mean?
    Spork likes this.
  34. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    Good idea! Could you post photos if you end up using it?
    chasntuna likes this.
  35. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    Oh it is! You might find my post about Otzi's belt in this same forum from a couple of years ago, it got me thinking about this modern version!
  36. Spork
    Jun 14, 2009
    6,035
    3,106
    Zombiewood, CA
    Took me a while to carve the toggle and wait for the finish to set enough to handle...here it is...
    Two Matthew Walker two-strand knots for the "buttonhole"...spaced so that the toggle needs to be pushed through. A third Walker knot is behind the sheath.
  37. Black5
    Black5 Supporter Supporter
    Sep 28, 2016
    126
    452
    Ozark Mountains
    Very cool. The OSS in WWII used something similar to your belt loop part, turned inside the pants, as a IWB holster for a Govt model 45.
  38. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    That is a very cool way of doing it, thank you for the great photos! I really like your toggle as well!
    Does the whole rig stay put or slip along the belt during use?
    I guess you could always adjust the distance of the part that goes around the belt to make it tighter if it was slipping around.
    Haggis likes this.
  39. Spork
    Jun 14, 2009
    6,035
    3,106
    Zombiewood, CA
    You're right...it would depend on how you space it. With a lightweight knife like a Mora it shouldn't move around much. No ideal how it will run...your loop setup gave me the ideal to try this one.
  40. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    I hope you'll let us know how it works! One of the things I really like about these systems is that you can move the knife to different positions on your belt depending on what you are doing, without removing the belt. For example if you are skinning an animal or cutting a lot of cordage it is nice to have your knife at the front because you have to access it so frequently, and it is easier and perhaps safer to re-sheath at the front. Then you can move the sheath to your back when you are finished. I think your system would work better than mine for this, as I have to have a loop a the front as well which can catch on things.
    Haggis, Subdood and Spork like this.
  41. Spork
    Jun 14, 2009
    6,035
    3,106
    Zombiewood, CA
    I don't often belt wear Mora...prefer a Puukko myself. Moras usually get carried in a pack or bag, but I can see a toggle used to secure things through the PALS or other webbing on a pack.
    Holmesmade, HardBall, Haggis and 2 others like this.
  42. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    Really?!? Are there any pictures of this somewhere?
    Subdood likes this.
  43. Gumbi
    Gumbi Guide Bushclass I
    Jan 19, 2012
    1,143
    973
    Iowa
    Awesome idea!
    It bothers me that you have nearly 45 comments saying what a great idea this is, but your original post only has 5 likes. I'd give you a lot more than 1 if I could!
  44. hurricane0331
    hurricane0331 Tracker
    Aug 17, 2016
    142
    358
    That is a pretty neat idea. I also don't like undressing just to take my knife off
    People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
    Subdood and oneshot like this.
  45. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    If I remember right I had quite a few likes for the original Otzi post, I am not sure where they ended up! It's fine with me though, even if one fellow bushcrafter reads a post of mine at least it's out there in our community. Your single like is more than enough! Thank you.
    Haggis, Subdood and Gumbi like this.
  46. Mr. Tettnanger
    Jul 14, 2010
    7,689
    3,685
    SE Pennsylvania
    Very slick! Thanks for sharing!
  47. 8thsinner
    8thsinner Guide Bushclass I
    Jun 23, 2010
    1,191
    293
    Very nice
  48. demonslaer
    demonslaer Scout
    Feb 25, 2012
    451
    194
    W.V.
    I made one that's pretty slick works great specialty getting in and out of the car
  49. oneshot
    oneshot Tracker
    Dec 11, 2011
    38
    172
    Canada
    Great to hear! Could you post a picture or two if you have time? Yes it is great for getting into and out of the car, or if you have to go in to a store and you don't want your knife out for everyone to see!
  50. demonslaer
    demonslaer Scout
    Feb 25, 2012
    451
    194
    W.V.
    14820941937162072487858.jpg 1482094288469252561797.jpg here you not very good pictures sorry
