Removing paint from cast iron?
Discussion in 'Cooking & Water Purification' started by NattyBo, Mar 19, 2019.
  1. NattyBo
    NattyBo Guide
    Dec 6, 2015
    1,210
    4,499
    South Central PA
    I have a cast iron kettle that was painted black. Is there a way to strip the paint and have it safe to cook food in? I've stripped tons of furniture and have several commercial strippers like Stripeze and Citrastrip. Can I burn the paint off, hoping it's not high-temp?
    I'd really like to use it, it's a great little size and has the number 4 on the bottom.
    Thanks for any help!
    Lode, Outdoor Dauber and J. Pierce like this.
  2. CSM1970
    CSM1970 Guide
    Aug 2, 2014
    2,065
    8,810
    I don’t think a propane blowtorch would hurt it. Keep it moving so as not to overheat one spot. I mean, it was made to sit in/on a fire! Cast iron melts at about 3000F so no acetylene torches. Just burn the paint to an ash and wire brush it. Get it thoroughly clean and reseason it.
    Outdoor Dauber, NattyBo and J. Pierce like this.
  3. Myr1ad
    Myr1ad Scout
    Apr 26, 2014
    907
    1,865
    NE Massachusetts
    Walnut shell medium in a sand blaster.
  4. J. Pierce
    Jun 22, 2013
    2,881
    12,843
    Wisconsin, the north end
    I'd set it in a fire pit and cook it off, wire brush it and start the seasoning process.
  5. DKR
    DKR Scout
    Nov 3, 2014
    807
    2,757
    Take it to an Aviation bead blaster. That's how I clean old cast iron. The beads are glass.
    AdamD1776, Outdoor Dauber and NattyBo like this.
  6. Outdoor Dauber
    Sep 8, 2018
    2,723
    12,891
    Central PA
    I think any of these suggestions would work. I'd start with adding some water and putting it in a fire to burn off the paint. Then wire brush.
    NattyBo likes this.
  7. 66drifter
    66drifter Guide
    2,036
    6,218
    ¿ painted inside too or just outside ?
    NattyBo likes this.
  8. NattyBo
    NattyBo Guide
    Dec 6, 2015
    1,210
    4,499
    South Central PA
    Both, I think they wanted to display it outside or were just really lazy with rust prevention.
    Outdoor Dauber likes this.
  9. NattyBo
    NattyBo Guide
    Dec 6, 2015
    1,210
    4,499
    South Central PA
    It was found, abandoned when some tenants left a rental unit, then given to me. Ive taken it to classrooms and set up a small tripod for history demonstrations. Can't have a fire in class so it was fine as is, but it's just too cool not to use.
  10. Outdoor Dauber
    Sep 8, 2018
    2,723
    12,891
    Central PA
    Oh, painted inside too? :33:
    AdamD1776 and NattyBo like this.
  11. AdamD1776
    AdamD1776 Scout
    Mar 16, 2018
    243
    1,072
    SE Wisconsin
    Have it media blasted, then re-season it like you would a skillet. Most metal-working or auto-body shops should have a media blaster (or at least know one that does), and if you know someone there, you may be able to get it done for a 6 pack or some cash on the side.
    Edit- Based on some quick internet searches, it appears that media blasting is not highly recommended for cast-iron cookware (though some do use it), and that the preferred method of stripping rust is electrolysis. I don't think it would work for paint, though.
    Edit 2- The suggestion of using walnut husks for blasting media would probably be best if going that route, as there is some concern about blasting media being embedded in the cast iron. The walnut husk would probably just burn out on the first good heat, and be no different than ash from a fire.
    NattyBo likes this.
  12. AdamD1776
    AdamD1776 Scout
    Mar 16, 2018
    243
    1,072
    SE Wisconsin
  13. Gizamo
    Gizamo Scout
    Dec 21, 2014
    411
    1,397
    I've done this with kettles. They haven't warped.
    Don't thing I'd try it with a flat bottomed pan.
