Scandi grind blade thickness
Discussion in 'Edged Tools' started by charles, Jul 9, 2018.
  1. charles
    charles Tracker
    Jun 27, 2018
    13
    55
    Hello everybody, I am wondering about different peoples opinions on what blade thickness goes well with a scandi grind. I’m usually a fan of the thicker blades but I’ve heard a scandi performs better with a thinner blade. What do you all think?
  2. DCP
    DCP Guide Bushclass I
    Jul 29, 2010
    2,295
    475
    Western NY
    Thin blade no more than 1/8” in my opinion
  3. anrkst6973
    anrkst6973 Scout
    Feb 4, 2017
    358
    1,855
    My main users are 1/8", but I also have a Varustelka which I think rolls in at 5/32". It's a a mean slicer as well as tank tuff. ;)
  4. GoKartz
    GoKartz Sharpaholic Supporter
    Jul 22, 2017
    1,501
    6,732
    Quakertown, PA
    My scandis that are at 1/8” are wonderful. I have one that’s thicker (not sure how thick) and it’s also great. I think it often depends on how high that bevel goes - 1/4” vs 1/2” vs etc - that makes a bigger difference.
  5. Vanitas
    Vanitas Supporter Supporter
    Feb 28, 2013
    6,263
    6,347
    New England
    buckfynn, charles and John Harper like this.
  6. Keyser Söze
    Nov 26, 2008
    16,137
    16,754
    Narnia
  7. 08H3
    08H3 God, Family and Freedom Vendor
    Oct 30, 2013
    3,457
    5,089
    Middle of flat lands Oklahoma
    I'm a fan of 1/8" or 3/32" for scandals, but to be fair with the right guy behind the grinder anything is possible. Its all about the geometry of the edge on some knives.
  8. John Harper
    John Harper Scout
    Oct 4, 2017
    219
    558
    Like the others have said.
    I like to add that "scandy" is a pretty broad church and a lot depends on the width and angle of the bevels desired, and also on what one expects to cut with the knife. Also, consideration must be given as to whether one wishes to have just a plain primary grind edge or a microbevel.
    For all round usage, I would not go beyond 1/8" blade thickness and the primary grind set to around 23 degrees included, maybe 25. Even so, it will not cut anything other than woods as well as a convex or full flat grind would.
    Something else to consider is the game changing hybrid scandy-full flat grind as found on the Mora Kansbol, which improves the all round usefulness of the knife.
    Cheers
    John
  9. batmanacw
    batmanacw Guide
    Jan 24, 2015
    3,842
    10,203
    NE Ohio
    I found the Jaakaripuukko too thick for a scandi. It cuts like a fat knife with the factory grind. 1/8" or under for me.
    buckfynn, morganbw, charles and 2 others like this.
  10. GoKartz
    Jul 22, 2017
    1,501
    6,732
    Quakertown, PA
    My 110 wasn't a true scandi and it processes wood like a champ. I put a true scandi on the first 50mm of the blade by the handle and that's made it a very nice carver, but I don't know if it actually improved its performance...
  11. charles
    charles Tracker
    Jun 27, 2018
    13
    55
    I meant for general bushcrafting, feathersticks, wood processing, maybe even a little food prep
    John Harper likes this.
  12. Fixedblade
    Fixedblade 3% Supporter
    Jun 8, 2015
    5,594
    26,942
    The Old Line State
    Anything over a 1/8 is overkill, just my opinion. I like 3/32.
  13. morganbw
    morganbw Scout
    Jul 4, 2015
    473
    1,135
    East TN
    I have a few, I like to use the thin bladed ones best.
    There is plenty of room for the eighth inch and beyond but the less than the eighth inch feels better, to me, during use.
  14. byksm
    byksm Scout
    Aug 30, 2014
    439
    1,274
    woburn, ma
    It depends.
    If you do more fine carving, a thinner blade is better. Look at a sloyd for example.
    If you're doing more heavy cutting chores, a wider blade will be more robust.
    I believe the more critical dimensions are the angle of bevel (imho about 24 degrees total) and the width of the blade from edge to spine.
    Have fun
    -p
    morganbw, GoKartz, buckfynn and 3 others like this.
  15. John Harper
    John Harper Scout
    Oct 4, 2017
    219
    558
    A less obvious advantage of knives sporting scandi grinds is that if one insists on a full tang, the knife can be made lighter than an alternative grind because they require a thicker spine, which translates into a heavier tang.
    One of my favourite knives is a Cold Steel Peacemaker witha 5 1/2" blade, 1/8"thick, and with a hybrid scandi- full flat grind. This is an exceptionally light knife weighing in at 4.86oz, yet it has pretty much a full hidden tang and is strong enough to withstand a lot of harsh bushcraft type use.
    Cheers
    John
    GoKartz and charles like this.
  16. ra2bach
    ra2bach Bushmaster
    Jan 8, 2014
    5,054
    6,508
    ATL
    I never thought about it that way, though I question what the best angle is. I'm not a big fan of Scandi grind but whatever the angle/thickness of a Mora Companion seems about right for what I use that knife for...
  17. John Harper
    John Harper Scout
    Oct 4, 2017
    219
    558
    I tend to agree that Mora has got it pretty much right. I am not a huge fan of scandis, but must admit that for a budget priced knife, especially if one is conscious about the weight being carried, they are hard to beat. I guess that at the end of the day it is all about compromises....
    Cheers
    John
    ra2bach, buckfynn and charles like this.
  18. JasonJ
    JasonJ Guide
    Nov 26, 2014
    1,441
    3,606
    Bay City, MI
    3mm or 1/8" feels best without having to get creative (or weird) with grind angles and bevel heights. Granted, my Jakaaripuuko's are 4mm ... but they do not cut as well - I should say, with as minimal effort, as my thinner scandi ground blades. My Bogdan custom, Mora Companion's, etc are much much better cutters because of their blade thicknesses.
  19. batmanacw
    batmanacw Guide
    Jan 24, 2015
    3,842
    10,203
    NE Ohio
    The way my Jaakaripuukko came it was sharp but took many times the effort to do simple tasks because of the fat scandi with a secondary. I convexed the whole thing and I'm never going back. No secondary needed and it cuts much nicer. Not as nice as a thinner higher convex like my BR Aurora.
  20. A Seedy Lot
    A Seedy Lot Scout
    Apr 10, 2017
    516
    2,353
    NW Montana
    I personally like thin blades made of steels that can handle acute angles. My current favorite knife is 0.080, 2mm, thick with a 8dps scandi. My wives favorite knife is 0.060, 1.5mm, thick with a 10dps scandi, she gets very defensive if I start using her knife.
  21. nograveconcern
    nograveconcern Supporter Supporter Bushclass I
    Dec 4, 2013
    1,709
    5,725
    N of ATL
    For crafting in wood and hard use tasks, a thick blade isn't a detriment. As long as the grind angle is thin enough a thick blade will cut, split and feather as good as a thin.
    A thin scandi blade shines when cutting meat, leather, plastic or other slicing tasks. No argument here, .1" or even .07" is what you want for slicing.
    John Harper, charles and ra2bach like this.
  22. ra2bach
    ra2bach Bushmaster
    Jan 8, 2014
    5,054
    6,508
    ATL
    yeah, I'm neither a Scandi nor a Mora fan but I do have a few stainless steel ones scattered about in my beach bag, cooler, tackle box, etc.. they're also my favorite giveaway to friends who have no knife other than something bought in the camping section of Walmart years ago.
    I'm in the minority but I don't consider bushcraft to be all about wood carving or vice-versa. for an outdoors knife I like a full height convex, or a saber-grind if it's thin.
    some folks confuse a saber-grind with a Scandi but to me, a Saber grind is made from thicker stock, has a higher grind, and either a convex or double bevel.
    it doesn't matter much though. I believe you should just pick one and use it till you find something it won't do. by then, you'll know enough to know what you prefer...
  23. ra2bach
    ra2bach Bushmaster
    Jan 8, 2014
    5,054
    6,508
    ATL
    I bet that Jakaaripuuko would cut better with a higher grind/thinner angle. I'd like to find someone to put a full height grind on one and I bet it would transform that knife...
  24. ra2bach
    ra2bach Bushmaster
    Jan 8, 2014
    5,054
    6,508
    ATL
    I'd like to see that. got any pics?..
    John Harper, charles and batmanacw like this.
  25. JasonJ
    JasonJ Guide
    Nov 26, 2014
    1,441
    3,606
    Bay City, MI
    Thinking the same. It's already a high grind for a scandi (needs to be), but I think it should be higher yet, 75-85% of the way up the blade. Full convex might suit it better as batmanacw did.
  26. halo2
    halo2 Supporter Supporter
    Jan 24, 2010
    907
    933
    I made one that's 3/16" or so thick. It works but I think 1/8" is probably better.
    A quick google suggests the Woodlore is 5/32". So somewhere around there?
    John Harper, charles and buckfynn like this.
  27. MJGEGB
    MJGEGB Guide
    Jan 2, 2013
    3,837
    9,169
    Portsmouth Virginia
    The grind limits the thickness in that assuming that you maintain the same bevel angle eventually at a certain thickness given the same angle it will simply be a full flat grind. I have a hand forged puukko blade that is like this with the more traditional slightly hollow grind with a micro convex secondary bevel. The primary grind runs very close to the spine as it's a 5mm thick blade.
    Personally I perfer under 1/8 as I find that thickness works best for what we call Scandi grinds.
  28. JasonJ
    JasonJ Guide
    Nov 26, 2014
    1,441
    3,606
    Bay City, MI
    That's basically 4mm... same as the Varusteleka Jakaaripuuko blades. I didn't know the Woodies were that thick.. wow.
    John Harper and charles like this.
  29. Kona9
    Kona9 Supporter Supporter
    Nov 15, 2016
    1,436
    5,309
    Buffalo, NY
    5/32” or 4mm is my max for scandi now. I have a knife that is 3/16” with a scandi grind that doesn’t get much use as I prefer thinner. I like thinner than 1/8” as well. I have a few Moras that are probably closer to 3/32”.
    morganbw, charles and buckfynn like this.
  30. flip888
    flip888 Tracker
    Mar 18, 2015
    84
    342
    I like thinner knives in general but I like especially thin scandi ground blades.
    1/8" or less is a good thickness for a general purpose knife for me. If I can go a little thinner, I will in a scandi.
    I like scandi ground knives because at the same thickness as a flat ground knife for example, I feel like the scandi ground knife is going to be a more durable blade due to the extra metal left in the blade. And that's why I feel like I can have a thinner scandi blade vs flat ground or whatever else.
    morganbw and charles like this.
  31. Ragman
    Ragman Supporter Supporter
    Oct 11, 2014
    1,551
    2,582
    3/32" then 1/8" then 9/64" and that's it for me.
    I don't like them over 9/64"
  32. batmanacw
    batmanacw Guide
    Jan 24, 2015
    3,842
    10,203
    NE Ohio
    Belt sander
    After sandpaper and polishing the edge without changing the curve.
    GoKartz, trafficjuzz, ra2bach and 3 others like this.
  33. JasonJ
    JasonJ Guide
    Nov 26, 2014
    1,441
    3,606
    Bay City, MI
    Must... convex... Terava 110...
    Great, now I have to snag a mousepad from work and grab some wet or dry sandpaper out of the garage!
  34. batmanacw
    batmanacw Guide
    Jan 24, 2015
    3,842
    10,203
    NE Ohio
    I did the initial grind with a belt sander. You will want to start very coarse and lay the bevel basically flat as you work away the old secondary.
    GoKartz, trafficjuzz and John Harper like this.
  35. ra2bach
    ra2bach Bushmaster
    Jan 8, 2014
    5,054
    6,508
    ATL
    GoKartz and John Harper like this.
  36. ANFwoodsman
    Jan 27, 2014
    1,297
    2,187
    Eastern US
    I like a scandi grind, but I like them fairly high. I'm moving away from the shorter scandi grinds unless they are if super thin stock.
    For me - The higher scandi seems more traditional to me, performs better, and sharpens easier than the shorter (or shallower ?) ones. I have some high grind scandi knives in stock over 5/32 and they still perform well. The thicker stock scandi blades aren't ideal for detailed carving with longer cuts, but works for other tasks.
    Some may consider this a 0 half height flat grind.
    GoKartz, charles and John Harper like this.
  37. batmanacw
    batmanacw Guide
    Jan 24, 2015
    3,842
    10,203
    NE Ohio
    I can tell a pretty significant difference in the cutting forces compared to when I only convexed out the steep factory secondary.
    As it comes, the Jaakaripuukko 110 sucks.
  38. PatrickKnight
    PatrickKnight Supporter Supporter
    Jul 20, 2013
    318
    532
    Southwest Ohio
    I want nothing over 3.5mm or 9/64 in a scandi. I have passed on some great knives that were 5/32 scandis.
    For me a scandi is a carving tool and I want it to do that well. I prefer other grinds for an all purpose tool.
  39. stewey1
    stewey1 Scout
    Jan 6, 2012
    284
    421
    New Zealand
    Ive recently purged most of my high end scandis. Ive realised anything over 3/32 makes an average general purpose blade. They just dont slice well. I also like the blade height to be about 5/8. JMHO
    John Harper and PatrickKnight like this.
  40. PatrickKnight
    Jul 20, 2013
    318
    532
    Southwest Ohio
    I am glad you mentioned blade height as I feel it's often over looked. As I said I see a scandi as a carving tool and they just dont perform to well on wider blades. Generally I go for a 1 inch max with a few exceptions.
    John Harper and stewey1 like this.
  41. stewey1
    stewey1 Scout
    Jan 6, 2012
    284
    421
    New Zealand
    X2 bud! thumbs up
  42. buckfynn
    buckfynn Old Geezer Supporter Bushcraft Friend
    Jul 13, 2011
    342
    981
    Central Idaho
    I say it is all relative. It depends on the thickness of the blade, and height of the scandi grind, which are going to determine the grind angle.
    What I don't care for is a knife with a thick blade and a low scandi grind. The angle is too awkward for most of my purposes.
    The Enzo Trapper has a thickness at the spine of approx 0.144." The Mora Companion HD approx. 0.125." The Mora #2 Classic 0.100." The Mora Companion approx. 0.080." All of them have worked fine for me for what I do.
    John Harper and GoKartz like this.
