Squirrel Snaring 101- A Tutorial
Discussion in 'Hunting, Fishing & Gathering' started by Bitterroot Native, Mar 16, 2018.
  1. Bitterroot Native
    Bitterroot Native Indigenous Skills Junkie
    Sep 15, 2016
    2,051
    10,683
    Hello BCUSA! Last summer I decided to try my hand at snaring squirrels and found great success with it. I am far from an expert on snaring squirrels with only a scant few months of trapping them under my belt but I would like to share what I learned!
    Always check local laws and regulations before setting any traps/snares and also make sure to have permission from the land owner if applicable.
    The western red squirrel has an unmistakable presence in much of the northern US/Canada as well as the higher elevations further south, such as the Rocky Mountains. They are PLENTIFUL, taste excellent, and their hides are very useful and versatile for making clothing. Squirrel hides were used as a source of year round fur and meat for many indigenous groups.
    Whether it be for food, fur, or use in a survival situation, knowing how to catch these tree ninjas is a skill I think every woodsman/bushcrafter could benefit from.
    (Don't let the lack of a sword and mask fool you, squirrel is a ninja in almost every sense of the word.)
    Almost all survival texts and information online I came across on this subject describe using a snare pole (a wooden pole with multiple snare loops attached) leaned up against a tree to make a "leaning pole set." I'm sure that squirrels can be caught using this method, however myself and many others have found that a horizontal pole set (a snare pole placed horizontally between two trees) produces much better results.
    The equipment needed to make horizontal pole sets is VERY minimal. Bait is not needed or encouraged. All that a horizontal pole set requires is a wooden pole, some cordage (or large nails), and some snare wire... that's it. The pole and cordage is easily obtained on site so all you really need to bring with you is wire. A pair of pliers can also come in handy for cinching down the snares to the pole or twisting the snare loops but isn't necessary. Lets get into the details!
    The Wire-
    From what I could gather (I'll include a link to the article I got most of my info from) 24ga brass wire OR 26ga stainless steel wire is your best option. I can't remember the exact wire ga I started out with but it was slightly larger in diameter than 24ga brass wire and I didn't have many catches until I switched to 24ga brass. Wire size is crucial to success.
    Snare Dimensions-
    Snares should be around 17 inches long with a small 1/8th inch loop twisted onto one end. I made mine slightly longer due to the squirrels being so big near the Arctic.
    Once your snares are finished you need to find a place to put them.
    Location-
    Your snares need to be set in an area that has a high concentration of squirrels, the more squirrels in an area the greater your chances of a catch. The tell tale sign that an area has a lot of squirrel activity are middens. A squirrel midden is a mound of squirrel table scraps so to speak. A huge part of their diet are seeds found in spruce cones (pine in some places) and as a result they leave behind huge piles of husked and shelled out cones.
    Larger piles mean more squirrel activity so look for the largest middens you can find to make your sets. Don't completely discount small middens however, if you have a good feeling or can't find any larger middens go ahead and make a set. Squirrels can still be caught off smaller middens sometimes in surprising numbers.
    Poor quality pic (sorry!) but note the mounded shape of the midden. They are easy to spot in the woods from a distance.
    Once you have located a suitable midden, find the trees that the squirrels use most. They will generally be the larger trees nearest to the midden. Squirrels almost always sit in these trees to eat. Your snare pole will be tied between these trees at a height of roughly six feet. Clear all brush and limbs below that point as well as the ones slightly above where you will tie your pole.
    The Pole-
    Cut a dry and straight pole long enough to span the distance between the two trees you're using. Preferably with the bark still on it so the wire grips better. It should be about 1-1.5 inches in diameter. It needs to be small enough that the squirrel has no choice but to run down the center.
    Two poles at one midden, the snares are barely visible.
    With your pole cut and stripped of limbs/stobs either tie or nail the pole between the trees at a height of around 6ft.
    I used spruce root but any cordage will work.
    Setting the snares-
    With your pole in place and the brush cleared you're ready to tie your snares to the pole. Take one of your wires and thread one end through the loop you twisted. Pull that through until you have a loop roughly 2in in diameter. Slightly smaller or larger works also, play with the size and find what catches the most for you.
    Twist this snare onto the pole then adjust it so that it comes up the side leaving the eye of your snare dead center at the top of your loop. Bend the wire so that the bottom of your loop is an inch above your pole. Also ensure the loop is right above your pole. If it's off to the side the squirrels head wont go through and it will be pushed aside by his body as he runs down the pole.
    The first and last snare (the ones on the ends, closest to the trees that the pole is anchored to) needs to be spaced 12 inches from the trees the pole is tied to. Too close and the squirrel will be able to grab the tree once snared and will surely escape. Set as many snares on a pole as you can, spacing them out about 12 inches between each other. I was normally able to get between 4-6 snares per pole. Longer poles will obviously accommodate more snares.
    Once your snares are tied on move on to your next set, setting as many middens as you care to. The more sets you have out the greater your chances of catching squirrels will be! Check your sets daily if you can or at least every other day. Predators can and WILL steal your catches from time to time so it's something that you need to keep on top of. If everything falls into place, you will be rewarded with success!
    I only had about 3-4 sets going at any given time and was impressed with how quickly I started getting catches. I didn't keep track of the total number I caught but I would guess it was 30-40 over the course of a couple months. It was not uncommon to have 2 and sometimes 3 squirrels waiting for me on 1 pole.
    More info can be found in this article https://trapperman.com/forum/ubbthreads.php/topics/1126006/Snaring_the_Western_Red_Squirr
    It was my go to and guide to learn how to snare squirrels, without that info I would have had a lot more trial and error to go through!
    Hope you guys enjoyed the read and got some useful info out of it. I'm sure there is something I missed or some crucial detail I forgot to include so feel free to ask any questions! :dblthumb:
  2. Muleman77
    Muleman77 Supporter Supporter
    Feb 13, 2014
    4,203
    23,001
    Very useful info!
  3. bosque bob
    bosque bob Guide
    Feb 18, 2017
    1,436
    5,468
    Than you, well written and done.
  4. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
    Thanks guys! Writing this brings back so many good memories haha :D
  5. CivilizationDropout
    Jul 2, 2010
    11,022
    70,357
    The Swamp
    all hail the hangman. Nice job Bitter!
  6. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
  7. Kvothe
    Kvothe Birch Bark Aficionado
    Apr 28, 2014
    1,447
    2,055
    Southern Germany
    Great write up and a very useful tutorial, brother! :dblthumb:
    thanks for sharing and I hope to read some more adventures from your time up north in the future!
  8. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
    Thanks man! I have more posts in the works :D
  9. Wasp
    Wasp DOWN IN DIXIE Supporter
    Dec 29, 2014
    16,266
    74,701
    Arkansas (Central)
    Very nice work and tutorial.
  10. IzaWildman
    IzaWildman Grey Owl Supporter
    Mar 7, 2016
    3,775
    26,032
    North Cacalacky
    Excellent write up. Thanks.
  11. GKiT
    GKiT Guide
    Dec 30, 2010
    4,694
    12,532
    I remember reading that thread on trapperman. I always thought that snare belt was a neat idea.
  12. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
    Thanks Wasp!
    Glad you enjoyed it :D.
    Trapperman is the only other forum on the internet I'm a member of :16:. I really liked that belt idea too, cool thing about trapping squirrels is that you can throw up squirrel sets while you're out trapping other things. The small ga wires are nothing to throw on your person and hit the woods with as they take up hardly any space/weight.
    longcruise, LarryB, NWPrimate and 3 others like this.
  13. Leshy_apprentice
    Jan 14, 2016
    922
    3,561
  14. Hoof
    Hoof Former Genius
    Apr 11, 2015
    6,745
    52,432
    South Louisiana
    Excellent! Does your squirrel hat have multiple tails hanging off?
  15. atlastrekker
    atlastrekker Guide Bushclass III Bushclass I Bushclass II
    Mar 8, 2016
    1,967
    10,167
    Nor Cal
    I will definitely give this a try during the next squirrel season. Thank you for all the hard work that you put into writing this.
  16. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
    You know me all too well Hoof! Haven't made anything with them yet but I did separate and dry the tails to use as clothing fringe :dblthumb:. Also used a few to decorate my tent with, really gave it that home like feel ya know?
    Give it a shot! You would be surprised how much fun catching these lil guys can be. You're welcome! I searched the forums and didn't see anything about snaring squirrels so I figured this would be a good guide/tutorial to add.
  17. Paul Foreman
    Nov 20, 2012
    11,143
    30,959
    excellent tutorial ...
  18. oldpinecricker
    oldpinecricker Supporter Supporter
    Jun 28, 2010
    2,315
    6,269
    Ideho of coarse
    Nice. Fun to read along and it makes me hungry.
  19. Seeker
    18,333
    28,310
    Excellent. Have always wanted to try this out.
    (Unfortunately, trapping/snaring squirrels is illegal in LA... can shoot my longbow inside city limits, but no squirrel snaring.)
  20. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
    Thanks! I really enjoyed writing it.
    You and me both! Squirrel gravy and fried potatoes sounds like the best breakfast a man could have right about now.
    Might want to check into your states trapping laws. With a trapping license you might be able to trap them! Cool that you can shoot your bow in city limits! I would have an awesome back yard range set up :D
    longcruise, Guttersnipe and NWPrimate like this.
  21. Primordial
    Primordial MOA #40 Supporter
    Sep 8, 2017
    6,612
    54,232
    Upper Great Lakes
    Awesome! Info has been downloaded into my hair covered computer. Thanks for the great write up!
  22. Rockgod1619
    Rockgod1619 Supporter Supporter
    Apr 18, 2015
    3,768
    11,435
    Oklahoma
    Awesome information and write-up! Thanks so much for sharing!
  23. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
    You're welcome! Took me longer than it should have to get what you meant by hair covered computer haha.
    Thanks and you're welcome! Feels good giving knowledge back to a community that I have learned so much from.
  24. Wasp
    Dec 29, 2014
    16,266
    74,701
    Arkansas (Central)
  25. Seeker
    18,333
    28,310
    Nope. I asked a game warden who was stopped at the gas pump opposite me. No trapping season for squirrels, and snaring is an "Illegal method of take" regardless.
    Yeah, I do have a range set up. Pretty cool.
  26. Jacob
    Jacob Guide
    Sep 10, 2016
    1,185
    7,083
    Thanks for taking the time to put that I writing for us. These little gems are hard to come by and can save a ton of trail and error time. Truly appreciate it.
  27. halo2
    Jan 24, 2010
    1,669
    4,424
    Looks like a great write up. Thanks!
  28. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
    Guttersnipe likes this.
  29. longcruise
    longcruise Scout
    Nov 4, 2013
    726
    2,372
    Who'd a thunk it?
    Not lawful in my state but it's committed to memory as a survival tool. I snared snowshoe hares as a kid and it is truly effective on them and certainly many other edible animals.
    24 gauge brass wire, don't leave home without it! :)
  30. Winterhorse
    Feb 14, 2013
    13,159
    55,009
    Kansas
  31. j_d
    j_d Scout
    Aug 23, 2013
    436
    734
    Great post. Regular trapping is illegal in many cities but nuisance trapping pests is not. Just fyi.
    Bitterroot Native likes this.
  32. southron
    southron Supporter Supporter
    Aug 29, 2015
    1,682
    5,569
    N.E Alabama
    Ya might try a couple rat traps, some peanut butter and a nail to fasten em where ya want em.
    I don't much mess with em anymore, I think I ate to much in years gone by and kinda am burned out now.
    But the rat traps will catch a fair ton of stuff is ya get creative with em.
    Just another quiver fer yer arrow I though ya might want to add.
  33. Nathan H
    Nathan H Tracker
    Jan 16, 2010
    197
    540
    North East, United Kingdom
    Thanks for this Idea, im going to have to give this a try.
  34. Nathan H
    Nathan H Tracker
    Jan 16, 2010
    197
    540
    Thank you for this info, it really helps a lot
    Next time i'm out, ill see if I can catch an illusive squirrel. thank you.
  35. Bitterroot Native
    Sep 15, 2016
    2,051
    10,683
    Thanks! it's great to be back :D!
    Squirrels might even be considered or classified as pests in many cities, they are mischievous and always into shenanigans haha
    Rat traps would probably work really well for squirrels, great idea :dblthumb:. Would have to get some of the larger traps for the squirrels up north, they are huge!
    Guttersnipe and BBizy like this.
  36. j_d
    j_d Scout
    Aug 23, 2013
    436
    734
    I had ohio gray squirrels get in the house and begin running amuck. Rat traps did not hold them, neither did sticky traps. It just gave them bald patches... . 110 connibears took care of my problem but weigh alot more than snare wire.
    Haggis, Guttersnipe and BBizy like this.
  37. will62
    will62 Guide
    Dec 29, 2010
    1,405
    4,428
    Southwest Missouri
    Thanks for the information, going to try this.
    j_d and Guttersnipe like this.
  38. WhisperInThePine
    May 28, 2013
    2,568
    5,926
    Thanks for sharing!
    j_d likes this.
