Tempering blade question
Discussion in 'Other Skills' started by HP500, Nov 6, 2017.
  1. HP500
    HP500 Scout
    Jul 4, 2016
    845
    2,880
    I just finished forging a small wood carving knife for the first time. I heated it to non-magnetic and quenched it in oil. A file test told me the blade was hard.
    To anneal it, I put it in an old toaster oven at 425 degrees for one hour. When I checked it afterwards, there was no color on the blade (straw, blue, etc.) I put it in for another hour and there was still no color. Is this normal? I've seen heat treating in a coal fire and you can watch the colors progress.
    Bryan King, Scotchmon, Jim L. and 3 others like this.
  2. 10eyedtofu
    10eyedtofu Scout
    Sep 28, 2012
    302
    49
    tempering is what you are referring to, not annealing otherwise your are back to square one with soft steel
    did you file test after the first temper cycle? if so and the file still skates then that probably indicates your toaster oven isn't hot enough
    Scotchmon, Jim L., gohammergo and 3 others like this.
  3. byksm
    byksm Scout
    Aug 30, 2014
    409
    1,091
    woburn, ma
    i like to shine the blade up a little with some coarse paper before and between tempering cycles. i can see the colors much better that way.
    a fair test is to sharpen the edge and flex it against a brass rod.
    if its still too hard it will chip. too soft and it will roll.
    Scotchmon, J.M., gohammergo and 6 others like this.
  4. Guillaume Longval
    Guillaume Longval Friction Fire Addict Supporter
    Apr 6, 2016
    1,568
    8,566
    Québec
    Yep, color is oxydation. Wont show if theres already oxydation on the surface. Probably not clean enough. If its not the problem, then, its more of a mystery!! We ll have to ask the rainbow spirit! Mouahahaha...or the toaster gost.
    Scotchmon, Jim L., gohammergo and 5 others like this.
  5. HP500
    HP500 Scout
    Jul 4, 2016
    845
    2,880
    Sorry, my mistake, I meant tempering. I did hit it with some 320 grit before I put it in the oven to shine it up a bit first. Perhaps I didn't do a good enough job. I'll try to post a picture soon.
  6. byksm
    byksm Scout
    Aug 30, 2014
    409
    1,091
    woburn, ma
    oh great rainbow spirit... tell us the riddle of steel
  7. HP500
    HP500 Scout
    Jul 4, 2016
    845
    2,880
    OK, here it is. It is my first attempt at a blade, but not a serious attempt. I had a scrap piece of car coil spring about 2" or 3" long and I just wanted to see what I could do with it.
    I just hit it with a file again a few minutes ago and the file still skates for the most part. Is the file not supposed to skate after tempering? It definitely did after I quenched it in oil.
    DomC, Scotchmon, Jim L. and 4 others like this.
  8. Red Yeti
    Mar 3, 2017
    1,096
    8,449
    Pacific Northwest
    FWIW, That looks like a what I would call a straw yellow color (a little hard to tell on the computer, but compared to the ruler) looks like a tad of peacock color around the 6.5 mark. The straw color is subtle, but that is what I want for a carving knife.
    Looks good to me. If it were mine, I'd move on the the final grind and remember to keep it cool during that step.
    Good job!
    Scotchmon, Jim L., gohammergo and 4 others like this.
  9. Mikewood
    Mikewood Supporter Supporter
    Aug 9, 2013
    2,088
    2,677
    I agree. Sharpen it and see how easily it sharpens and how easily it dulls thru use. If those are satisfactorily to you during you Wood carving consider it done. My wood carving tools are pretty hard next to blade steel but they are also much thinner in cross section so they sharpen more easily than a thicker blade.
    Scotchmon, Jim L., gohammergo and 2 others like this.
  10. HP500
    HP500 Scout
    Jul 4, 2016
    845
    2,880
    Will do, thanks!
    Scotchmon and Jim L. like this.
  11. Guillaume Longval
    Apr 6, 2016
    1,568
    8,566
    Québec
    I think @Red Yeti is right.
    THis is clean enough to see the colors.
    Scotchmon, Jim L. and HP500 like this.
  12. Guillaume Longval
    Apr 6, 2016
    1,568
    8,566
    Québec
    Nice little blade btw;)
  13. boisdarc
    boisdarc Scout
    Jan 29, 2015
    639
    2,068
    Illinois
    Looks like a winner.
    Jim L., Scotchmon and HP500 like this.
  14. Red Yeti
    Mar 3, 2017
    1,096
    8,449
    Pacific Northwest
    You know you have to post a picture when it is done, right?
  15. HP500
    HP500 Scout
    Jul 4, 2016
    845
    2,880
    Absolutely! :D
    Scotchmon, Jim L. and Red Yeti like this.
  16. gohammergo
    4,595
    20,850
    Nice looking blade! I'll have to give something like that a try. :)
  17. 10eyedtofu
    10eyedtofu Scout
    Sep 28, 2012
    302
    49
    a good file should just about be able to scrape into a blade after tempering.
    i would still test out your toaster over too, to make sure it is getting hot enough and an easy way to do so would be to stick a piece of bright clean steel in and see if colors form at the temps...400 degrees at an h2 should be giving you a straw to dark straw/ bronze color and anything hotter will be more purple and blue
    of course you could also just use an oven thermometer
  18. HP500
    HP500 Scout
    Jul 4, 2016
    845
    2,880
    I finally finished the blade. I made the handle out of a piece of cherry I found in the woods. The ferrule was made from a copper pipe cap. It's not perfect, but it was a good learning experience. 20180106_120504.jpg
    boisdarc, Bryan King, Jim L. and 4 others like this.
  19. Jim L.
    Jim L. Supporter Supporter
    Mar 24, 2011
    1,482
    6,145
    Brunswick, Georgia
    I'm sorry I missed this thread some how. That Sir, is a solid looking knife.
    Who told you it wasn't perfect? To paraphrase, "one man's imperfection is another's Shangri La."
    -Does it hold an edge to your standard? (check)
    -Does it perform as intended?
    (check)
    -Does it bring a sense of satisfaction with use, this is something that you made?
    (check)
    This sounds about perfect to me.
    Primordial, HP500, Sinjin and 2 others like this.
  20. 10eyedtofu
    10eyedtofu Scout
    Sep 28, 2012
    302
    49
    very reminiscent to one of my 1st knife attempts
  21. Zunga
    Zunga Guide
    Dec 5, 2017
    4,595
    20,853
    British Columbia
    Not only very well done! But I love a tool made from found items. Spring, cherry and copper pipe. I am very impressed!
    Jim
  22. Jim L.
    Mar 24, 2011
    1,482
    6,145
    Brunswick, Georgia
    I love seeing what people can do when repurposing.
    Bryan King and HP500 like this.
  23. Greg Johnson
    Greg Johnson Tracker
    Apr 16, 2018
    21
    35
    That copper fitting is brilliant!! I must try that. And that knife is awesome.
    Toaster ovens can be very inaccurate. As others have suggested an oven thermometer is wise. Also, bring the oven to temp before putting knife in. If not your blade may get hotter than desired as oven ramps up. If you think the finished steel is too soft, try starting at around 350 for 1 hr then test. Too hard bump it 25 and re test. When you get it where you want then do another temper at that same temp. During the first temper some of the steel that didn't harden in the quench will harden. The second temper will temper that. Look up kevin cashen, a master Jedi when it comes to heat treating blades.very helpful. Diff steels require diff heat treat to bring out the best in them. How hot you get them, How long they stay that hot, how fast the quench oil cools them, and the temp you temper them matters. Cashen explains all this and provides recommendations for several types of steel. Good luck.
  24. HP500
    HP500 Scout
    Jul 4, 2016
    845
    2,880
    Great info, thanks Greg!
