Tomato plant fell over
Discussion in 'Homesteading' started by highlander, Jul 10, 2019.
  1. highlander
    highlander Veni Vidi comedit lardum
    Apr 11, 2010
    6,448
    24,681
    Scott County,Tennessee
    My bucket tomatoes are thriving. This heat has me watering heavily during the evening. Tonight I came home and noticed that one of my Roma plants had fallen over. I suspect because of the heat and number of tomatoes about 10 so far with plenty more blooms. I picked a few of the larger green ones off to take some of the weight off the plant. I’ve staked them and tied them off since they’ve began to produce.
    The main stalk had crimped above the bottom few branches, but was not broken or cracked in any way. I carefully straightened it out, added a few more ties around the main stalk, gave a generous amount of water, and a little high nitrogen fertilizer. Is it a good possibility that my plant will survive?
    I’m not new to this stuff, but I’m a bit out of practice. This is the first year in a long time that I’ve grown anything.
    Tomorrow I plan to add some more stakes and better support as some of my plants have outgrown the original stakes.
    RavenLoon, xrayit, Bryan King and 5 others like this.
  2. schapm
    schapm Elitist Inflated Ego LB42 Supporter
    Aug 11, 2011
    2,477
    10,597
    Indiana
    It could go either way. My daughter has a green thumb and a lady at the Farmers Market gave her a tomato plant that had bent over like that to see if she could revive it. She staked it and it seems to be doing fine three weeks later. Cages are also a good idea for big productive plants.
    Primordial, KFF, JeffG and 4 others like this.
  3. AdamD1776
    AdamD1776 Scout
    Mar 16, 2018
    344
    1,456
    SE Wisconsin
    As mentioned, cages are your friend. As for saving the plant, it could go either way, depends on how much damage it took. I would just go for it, and hope for the best. Make sure to save seeds from the tomatoes you did get!
  4. highlander
    Apr 11, 2010
    6,448
    24,681
    I may build some kinda trellis for this one. I have two plants in one container, and they’re both loaded. I hope that with the heat and humidity it doesn’t go into shock. I’ve been battling that too. I’ve pruned back a few of the lower branches on my bigger plants.
  5. highlander
    Apr 11, 2010
    6,448
    24,681
    I had one pepper plant, a Mad Hatter, that had been bent or broken at the nursery. It grew back crooked, almost like a shepherd’s crook, so I had to compensate for that when I staked it. They’re over 3 feet tall now and loaded with peppers.
  6. NevadaBlue
    14,675
    99,155
    Most tomatoes are vine plants. Give them something to climb and crawl on. :dblthumb:
    highlander likes this.
  7. Crusher0032
    Crusher0032 Appalachian Arthfael LB-42 Supporter
    May 9, 2016
    2,770
    15,772
    West Virginia
    I've had tomato plants actually snap and then splinted like a broken bone that managed to hang on through the season, I'd say you're probably going to be alright. Just do some creative staking and enjoy your 'maters
    NevadaBlue and highlander like this.
  8. Ragman
    Ragman Supporter Supporter
    Oct 11, 2014
    2,017
    4,488
    My parents have been growing tomatoes for decades and they stake all of them.
  9. highlander
    Apr 11, 2010
    6,448
    24,681
    I made some makeshift trellises and did some creative staking today.
    Everything seems alright.
    NevadaBlue, schapm and Ragman like this.
  10. bwallenjr
    bwallenjr Tracker
    Oct 2, 2016
    156
    617
    Blue Ridge Mtns SW Virginia
    If the crimp is close to the soil heap dirt over it. Tomatoes are a vine if you bury part of the stalk it will put off roots. I have had many plants damaged some partially broken from a variety of reasons...me being a big cause. This trick has saved a good 70 to 80% of damaged tomatoes plants.. Also if I may. You may want to switch your watering from daily to a really heavy drenching once every 5 or so days..tomatoes like a consistent watering with good intervals. Closer to daily watering sometimes ends up in blossom end rot. Just some thoughts hope your plants make it.
    highlander and Crusher0032 like this.
  11. highlander
    Apr 11, 2010
    6,448
    24,681
    Thank you. So far the crimp has not had any negative effects on the plant. I did heap some more topsoil on the plants and mulched with dry grass. No straw was available, and I mowed 5 days ago. The clippings have been baking in the sun. The extra 4” layer of grass in the containers should help the soil moisture. This should cut my watering times and amounts down significantly.
    It’s supposed to rain this week a few days.
  12. bgf
    bgf Scout
    Mar 12, 2014
    349
    470
    Central KY
    It will be fine as long as it is mostly intact on the outer part, where the "veins"(?) are. Stakes are best for tomatoes pruned to a single stem. As a kid I worked For a tomato farmer who would stake plants about a foot apart and prune to single stem. They would grow up 8+ ft. high and he would regularly trim and tie.
    For a bushier plant cages are preferable, though mine always outgrow whatever cage I put them in... For romas (usually determinate) in a bucket, small cage would be fine maybe in addition to a stake. Sprawling works in the field, but there's a bit of loss, especially with larger indeterminate plants.
    I once broke a nice tomato plant off at the ground by accident. I stuck in a hole and wet it down good, and it wasn't even delayed more than a day or two.
  13. Scotchmon
    Scotchmon Supporter Supporter
    Dec 14, 2016
    2,950
    15,528
    Crystal Lake, Il
    Wish I had a picture of my buddy’s tomato cages. #8 (1”) rebar! Welded.
    Wonder if he has the Mrs. pack those out each season??
  14. highlander
    Apr 11, 2010
    6,448
    24,681
    Two days and no changes. I think it’ll pull through.
    Bryan King likes this.
  15. Bryan King
    Bryan King Supporter Supporter
    Mar 12, 2011
    1,201
    5,596
    Strunk, KY
    I had to stake mine right after planting, they grew unbelievable fast. I pulled sucker leafs off . I've been getting huge tomatoes off of them. My wife wanted some Cherokee Purple and they taste great, low acid, sweet. Look them up very nice history on them.
  16. TWill
    TWill Guide
    Dec 30, 2012
    2,275
    4,582
    central MN west of Twin Cities
    I had a couple of suckers that got some size before I snapped them off so I poked a hole in the soil and tucked them in. A day later they were standing up nice and fresh ready to make their own tomatoes just like their momma does. These are container grown in the large recycling box bins the trash haulers used to use around here then they changed over to the larger upright rolling bins and these started showing up for cheap or free. To use them you can line the bottom with old leaves or landscape fabric and fill them up with compost, manure and potting soil. They weigh about 120-150lbs depending on how wet they are so one tomato plant in each and they don't blow over.
    bgf and highlander like this.
  17. gohammergo
    12,990
    75,569
    Tomatoes are pretty hard to kill. We had some given to us by a plant seller because they looked so rough. We planted them with our sunflowers because we didn't think they would make it, they are doing fine. :)
