Winter Camping Shelter Idea
Discussion in 'Winter Camping' started by Back Off, Jun 13, 2017.
  1. Back Off
    Back Off Scout
    Mar 13, 2017
    619
    2,217
    Blaine, MN
    I have always wanted to camp in the winter. I have several early spring and late fall trips and yes, I have camped in the snow but not during the winter with cold temps. I am planning on making a hot stove out of a metal 5 gallon bucket and using my Double Bull Blind Horse as a tent. I know that will work, thick material and a heater. I have already spent many a day in that down to single digit temps just using a propane heater but not a stove. The other idea I had I got when I was camping this spring in my little tent. It got down to 39 degrees that night and honestly until the small fire I had burnt out I was more than warm in my mid weight sleeping bag. I thought along with a long fire I could fold over the bug screen, in this tent. Add reflective tarp/survival blanket to the back wall as well as clog the vents if I needed to. A wool blanket on the ground with some reflectics on top and then my cold weather bag. I could then drop a sheet of plastic over the opening in front and raise the tarp and put at more of an angle if I plan on getting snow. I would probably run a pole over it and set up a small lean to frame and put my tarp over it and tuck the tent under if it is supposed to snow a lot or just go without. Here is my tent, do you think it would work? I think it would almost be too hot for most temps as it is a very small space to heat but I think it would work well for winter. Here is my little tent that I think would work. I paid $35 for this from Sportsmens Guide several years ago. I should have bought another for my son as this thing is pretty sweet for the money. Swap out the heavy poles for old carbon arrows and its a packable low budget tent.
    Winterhorse and rsnurkle like this.
  2. Moondog55
    Moondog55 Guide
    Mar 11, 2010
    3,852
    1,425
    Geelong Victoria Australia
    So that is a little bug tent with a tarp over the top?
    So you are thinking about a pack-along Supershelter?
    No personal experience but I see no problems using it inside a pole frame lean-to; especially if you also layer up the browse however I get a shiver down my spine when people talk about below freezing sleeping without a proper mattress system in place, you really do need a thick CCF pad at a minimum in addition the the RFL and blanket
    Winterhorse, rsnurkle and Back Off like this.
  3. Walking Crow
    Walking Crow Scout
    Jan 2, 2013
    378
    321
    Ohio most of the time
    I agree with Moondog's concern about insulation underneath. On cold ground (or snow) a wool blanket and a layer of Reflectix is probably going to leave you with a very cold back, even if the air temp is balmy. Getting several inches of natural insulation (that is several inches when compressed) under the tent might be an option depending on location. In a true super shelter, the sleeping platform is about sitting height so warm air can get underneath the platform. That would be difficult to accomplish in your tent.
    I doubt you will get an airtight seal with the plastic around the front opening, so there will be some air exchange. I am assuming that the walls of your tent are waterproof and not breathable. You want some fresh air getting into the shelter.
    Remember too, that in a traditional super shelter, the fire is closer to the shelter (one long step) than in your picture. The placement of your fly as a leanto will have to take that into consideration, if you use the fly at all. If you have access to larger wood, the two or three log long fire will greatly reduce your cold awakenings through the night.
    In rereading the op, is see that the term super shelter is not used, so you may not be familiar with that term. A bit if searching, either bushcraftusa or youtube for Mors Kochanski Super Shelter should yield a thorough description of the concept and its execution. Using the tent as you propose would be workable, with allowance for the above concerns.
  4. Back Off
    Back Off Scout
    Mar 13, 2017
    619
    2,217
    Blaine, MN
    Thanks walking crow, forgot about the raised bed. That would be a must and that would leave this idea trashed as that cant happen in this tent as its too small. I have seen the supershelters being built on youtube. I was just thinking this would be a packable alternative but you are 100% right. Thanks for bringing that to my attention.
  5. Walking Crow
    Walking Crow Scout
    Jan 2, 2013
    378
    321
    Back Off, I wouldn't give up on your idea that easily.... If you put a couple of closed cell foam pads, Ridge Rest for high end price, generic blue foam or even surplus GI pads, They will help immensely. The plastic/reflector combination will warm the air around and above you to the point that both layers of your sleeping bag will probably be under you.
    If the vents at the ends up top are just mesh, you will want to put some nylon (uncoated would be fine) over them.
    Larry Roberts, of Alone fame, did a video on SuperShelters although his was basically a plastic wrap. It does show how effective a small fire can be. Trouble is, small fires need to be refueled frequently and you don't get the rest you need. That's where the longer lasting fire comes in. But if you are too "sealed up" you may be miserably hot... Here's a link to his video if you haven't seen it.
    Remember too, that the Super Shelter was intended for the person who lacked an adequate sleeping bag for winter. Mors' concept is to either rely on fire or an adequate sleep system (bag(s) and insulation underneath. You don't need both. While I have used fire a few times, I much prefer my Wiggy's bags or, if dry conditions are assured, my old Eddie Bauer Karakoram bag, along with a couple of pads. Those, tucked under the branches of a pine or spruce or a tarp if wind or snow was an issues have done well into negative F degrees. I don't like the dampness of tents.
  6. Moondog55
    Moondog55 Guide
    Mar 11, 2010
    3,852
    1,425
    If you are making a frame to cover with browse there is no reason you can't put in a raised bed big enough to hold the shelter, it all depends on how much time you want/need to devote to the build.
    If space inside that little tent leaves little height for a thick pad you can simply put the CCF pad under the floor, we do that here on snow all the time, we use our old beaten up pads under the floors to protect the tent floor rather than using footprints. It is a very effective strategy.
    It may not be the best winter shelter but it can be made to work if you are willing to also carry the tarp to use as a fly and have poles you can collect to make a frame and you can pitch in the shelter of trees.
  7. Back Off
    Back Off Scout
    Mar 13, 2017
    619
    2,217
    Blaine, MN
    I am glad I posted it up. Great suggestions, I am going to give it a try.
  8. Terasec
    Terasec Scout
    Dec 7, 2016
    833
    2,418
    NYC
    i have started to do that for all my tents,
    i had left over flooring underlayment that i used on 1 tent,
    now i gathered enough foam padding that i will be cutting to size for each of my tents, no need to carry ground cloth and pad,
    Winterhorse, Back Off and rsnurkle like this.
  9. mugsy
    mugsy Scout
    May 5, 2017
    309
    1,222
    a friend and i have been going on annual freezeouts for 30some years, we go when the nastiest coldest and snowiest weather is predicted. weve camped in tents, tarp shelters, leantos. the leantos are the coldest due to the fact that there is air (really cold air) beaneath the sleeping surface. now i have never slept on a raised bed in any of my shelters be it improvised or tent solely because of this. the coldest i personally have camped out in was -18f , had a 0 degree bag on a zrest (not a mummy bag either too confining for me just rectangular) never got cold and i sleep barefoot with longjohn top and bottom and a watch cap. ive used different bags over the years , +30 when i was alot younger and the cold didnt bother me , upgraded to +10 bout 20 years ago and then 0 bout 10 years ago. still use the +10 bag depending on wether the weather cooperates and gets cold. have always slept on the ground didnt start using sleep pads til i bought the +10 bag (more due to aging than cold). so in my opinion stick with your guns seems like you have a good idea , if you carry a folding shovel as we do you can dig down to ground so your not on snow and you can dig up leaves for use as insulation beneath tent.
    Winterhorse and Back Off like this.
  10. Moondog55
    Moondog55 Guide
    Mar 11, 2010
    3,852
    1,425
    'I'll suggest making a couple of trial runs before the real cold weather returns
  11. Tipi_Walter
    Tipi_Walter Tracker
    Oct 5, 2014
    140
    118
    I also used a propane heater in my big 12x12 Xtreme dome tent when I lived down on Chickasaw Creek in TN---Note gas tank outside of tent--- It's a good system but will never be as good in my opinion as a dedicated woodstove with ample wood inside a tipi or wall tent or witu or yurt etc.
  12. sonnyDdog
    sonnyDdog Supporter Supporter Bushclass I
    Apr 10, 2015
    714
    1,472
    Ontario
  13. Back Off
    Back Off Scout
    Mar 13, 2017
    619
    2,217
    Blaine, MN
    Thanks for sharing. That time of the year is coming up soon!
    Winterhorse likes this.
  14. James Levite
    James Levite Tinder Gatherer
    Aug 23, 2017
    Very nice sonnyDdog
