Did some load testing for 45-70
sledjockey
Skookum's Bro
Bushclass I
Jul 19, 2012
2,011
1,190
Western Washington
Finding reloading data on generic or lesser known bullets is not an easy feat. Most of the time you have to work up your own data. A few months ago I found some 405 gr cast bullets for my 45-70 and spent a lot of time looking for some reloading data so I can get them out and test them. Unfortunately, the data I found was never inclusive of any powder that was available so I have had to back up and “punt.”
In researching other bullet loads I found some data on the use of IMR 3031 that I thought I could use to establish a base and work up some loads from there. While working on this, my father did the same thing with the use of IMR 4198 using the same bullets. Since we had two different powder loads to evaluate, I talked him into getting out his old chronograph and we went out to the gravel pit to do some testing.
First off, his loads are using 40 gr of IMR 4198 and the same 405 gr cast bullets. Since I had not done any real testing yet, I went ahead and put together some ladder tests from 42 gr of IMR 3031 to a max of 49 gr in .5 gr increments. We chronographed each shot to look at the velocity and then checked for pressure signs. Again, all this work was based around finding a good load for the 405 gr cast bullets we picked up. Here is what we found.
My father’s load using 40 gr of IMR 4198 shot at 1702 fps.
My loads worked out as such:
42 gr IMR 3031 1271 fps
42.5 gr IMR 3031 1406 fps
43 gr IMR 3031 1434 fps
43.5 gr IMR 3031 1461 fps
44 gr IMR 3031 1482 fps
44.5 gr IMR 3031 1508 fps
45 gr IMR 3031 1549 fps
45.5 gr IMR 3031 1582 fps and the primer just began to flatten just a touch
46 gr IMR 3031 1586 fps and the primer flattened even more
46.5 gr IMR 3031 1589 fps and the primer flattened as far as I felt was truly safe for brass/rifle
The best range load for this powder, bullet and rifle seems to be around the 45 gr of IMR 3031 mark. Even though I now had loads for 45-70 using these 405 gr cast bullets, I wondered what Hornady 325 gr Leverevolution ammunition would chronograph. It was travelling at 1825 fps. Again, this is 80 gr lighter bullet than the ones we were testing.
Since we were out there I also chronographed my father’s 300 gr hollow point loads. He was using 46.5 gr of IMR 4198 in these cartridges and they came out at 1875 fps.
Lastly, there were some plinking loads that xRangerx made. He somehow found some 150 gr cast bullets and loaded them up with 11 gr of Trail Boss powder. These seemed to be a very light and fun round to shoot. They were like oversized .22 lr with regard to recoil and sound. Again, we decided that these would be a great small game round and were an absolute blast to play around with. The speeds of these ranged between 1262 and 1283 fps.
My father also brought out his 45-70 Sharpes 34″ barrel rifle to play with. I have excluded the data from that since it really made my little Marlin 1895 GBL look anaemic with regard to the speeds these loads produced.
All said and done it was a great outing. We had a great time and I found that I need to procure myself some IMR 4198 for these heavier grain bullets.
***********************************Edit************************************************
I figured that I would add that my father had worked out the numbers on his load to find the most accurate/highest energy load with the IMR 4198. Much more than the stated powder charges started flattening the primers, with the exception of the 300 gr HP. When he got to 47 gr the primers were still not flattening, but the accuracy went off a bit.
Thank you, SJ, for your load info. I picked up an H&R Handi Rifle in .45/70 a few months ago and laid in a big pile of cast bullets to play with (300's and some 405's) This will be helpful in working out a good mild load for it. I got some 4198, 3031, and AA 5744 to work with.
Ditto for me as well. I have some 405's I got to test with as well. how was the accuracy for the loads?
I wasn't doing any bench testing for accuracy with these loads. Now that I have the parameters, I will go back and get some MOA information. I can tell you that my father's 4198 loads and the 44 gr - 45.5 gr 3031 loads went exactly where my sites were pointed. The lighter and higher powder charges seemed to be a bit off from where I was aiming. That is about all the more specific I can get considering this outing's focus.
In a Marlin 1895 with a 22" barrel:
Hornady 350 grain bullet
45.2 grains of IMR 3031
MV 1400 fps
56.1 grains of IMR 3031
MV 1900 fps
Is that out of a book?
Yes, but I don't remember which one. I wrote down the recipe a long time ago. I'm using 50 grains of 3031. It's taken a lot of deer, and I've never recovered a bullet. I shot one moose with it, and recovered the bullet just under the hide on the far side after it went through a shoulder. Doesn't get any better than that.
This information doesn't exist for 405 gr cast bullets for IMR 3031 in any book and I couldn't find much online other than reference to one person that worked out their own, but didn't give the usability to excessive pressure. That was not available either. I basically created a range like you would find in a book for the 405 gr cast bullet.
Book information is nothing more than a guideline. You should really take their guidelines and then do your on chronograph tests over the range and check for signs of excessive pressure. Just blindly taking the word of a book can be quite dangerous when dealing with explosives.
I am glad that you found a load that works for you, however, I would suggest that you work the range and find the minimum and maximum loads for your rifle and then dial in the accuracy.
I've a Marlin 1895CB in .45-70govt, and all this talk about reloading has me thinking of dusting it off again. I bought it in the winter of 2002, killed three deer with it in the Fall of 2003, then put it into the gun cabinet to fossilize. It's really a cool cartridge,,, lots of history.
I shoot both the BFR and Browning High wall in 45-70. In the browning i use a 480gr 451 Whitworth bullet sized at .457 and bump up as needed. Loaded with 3031 I get about 1200fps and it is quit accurate at 100 yards (5 shots in under 2"). I don't know if it will fit in a lever gun. I also load the leverevolution 325gr and have a very accurate load for it and the hornady 350gr RN. I just acquired a 405gr PB mold and will try some out before long. If anyone is interested in the data I'll got get it out of the shop and post it.
I would be.... From what I read Leverevolution is not recommended for the 45-70 so seeing what you are doing with it would be interesting. Also, what is the OAL for your 480's?
Not to hijack sled's post but maybe he too wants this info. As you know leverevolution brass is shorter (2.350 OAL) than normal brass (new 2.990 OAL). Also, for whatever reason the box of factory ammo say's not for use in revolvers for some reason. I don't fire it in mine but others do. Below are some stats. Please do not load in firearms of lesser strength and as always work up to a safe load. My rifle is a Browning High Wall Traditional Hunter with a 29" barrel and crescent steel butt plate ( nicknamed Mule). My pistol (nicknamed Baby Jesus) is a BFR in 45-70 with a 10" barrel. The rifle's bore diameter is .456 using .457 lead projectiles (not .458/.459) and the pistol is .458 (.459 lead). I do not crimp rounds for the rifle so the length's tend to be long as I don't use crimp grooves on my projectiles. Crimping is an absolute must for the pistol. I believe that I have a competition load for BP for that 456-121PH also somewhere. The guy who gave it to me is a competition shooter and has taken all legal african game with it except Gemsbok in 45-70, 45-90, and 45-120. It will pass lengthwise on a quartering shot through a kudu bull at forty yards and you can eat all the way up to the hole. It is a suppressible round also but you can hear that baby whizzing as it rotates lol. I have this mold btw and cast my own out of WW+2% Tin. Also note that anything above 1200fps with the 456-121PH will be the laws of diminishing returns. At 1400fps it will start to mushroom and not penetrate heavy bone as well. At 1800fps it will leave a very massive entry wound (about four inches wide) but penetration will suffer drastically and will only wound a critter over 600lbs. If said critter is weighed in tons and your on the menu this is a bad choice. Slower is better in 45-70 most times.
These are NOT trapdoor loads.
325gr Flex Tip using 47.5gr of IMR 4198 with an OAL of 2.590 on the short brass for approximately 1850fps (Marlin #2 Load)= Easily groups under 2" for 5 shots with iron sights. This load kicks like the dickens at the bench with that steel pad. This load is known as "Mule Feed". You will not want to shoot many (buy a rifle with a pad!)
350gr Hornady RN using 44.0gr of IMR 4198 with an OAL of 2.547 on normal trimmed brass (2.910 OAL) for approximately 2050fps (Marlin #2 Load)- BFR load that I'm working on- Easily 2" or less at 50 yards if you can hold it at the bench. Many can not lol. Three rounds and you will be done for the day. This load has fractured one wrist already. Be careful if used in a pistol. Known as "The Hog Anchor". You can guess why lol. On a charging 300lb hog at close quarters in the swamp this is good medicine for Baby Jesus.
475gr 416-121PH 451 Whitworth using 37.0gr of 3031 with an OAL of 2.651 on normal trimmed brass (2.910 OAL) for approximately 1200fps= Easily shoots into the 1" area at 100 yards for 5+ shots if I do my part. This load is known as "The Freight Train" (it whistles as it chugs along to the target like a train) and is absolutely my favorite 45-70 load. Kicks like a 2/3rd load of 325gr's listed above but still not pleasant from the bench. It gets somewhere around 27"+ penetration in different media (bone/muscle) and keeps going straight after 18 milk jugs of water depending on what alloy is used....
456-121PH projectile OAL is 1.219"
325gr flex tip link http://forums.outdoorsdirectory.com/showthread.php/133279-Need-some-reloading-data-for-45-70
My next project 525gr Piledrivers in 45-70 https://beartoothbullets.com/open_sight/archive_open_sight.htm/21
Awesome! Thanks for posting all of that up. Sounds like you guys had a great time!
Sled. The projectile listed below may work in a lever action rifle and allow you some extra thump if your interested. I do not own one personally in 45-70. If it's too long you could try it on Leverevolution length brass I would think. The blunt nose may help it in length and will definitely deliver some smack down with that large meplat. They make these all the way up to 550gr for the 45-70 with this one being the lightest. I have also attached another picture with information (not mine) from the internet. Notice the relative penetration distances on 300gr projectiles that correlates with lower velocities. Start a 300gr at 1200fps and you'll get 12+ jugs of penetration. Add 1,000 fps and your down to 3 jugs. Of course bullet design and weight will alter these results but this still good info. It's vital information if you hunt larger game such as Caribou, Moose, etc in big bear country as in a worst case scenario you had to shoot a bear or moose in defense then you'll most likely want to leave daylight straight through your target. Do you shoot BP in your rifle ? I ask because some states like Mississippi allow you to hunt during primitive weapon/BP season with a 45-70 from what I hear. Also, I recently sold my Remington Falling Block 38-50 Remington Hepburn rifle because it weighed 13lbs (was considered a "ladies rifle") and a lot of "official" BP shoots won't allow 375 caliber rifles anymore for competition. It had a octagon barrel that was over an inch thick lol. Too heavy to hunt with but man was it awesome at 600 yards with Black Powder. If you don't shoot BP then at least consider giving it a try. I'll post a few pictures below for anyone who likes gun pics lol.
I do not use BP in mine. Been looking at other model rifles to use BP 45-70/90/110 in. Just love the old traditional stuff.
Thank you for the info. On my phone noe but will check it out on my puter tomorrow.
As per my first post, it's for the Hornady 350 grain bullet, not a 405. And that is the load I've come up with.
Book : 45/70 Reloading Info
Good advice to follow.. :dblthumb:
Heres a bit more " Book Info " .
FOR RUGER or MODEL 1895 MARLIN ONLY !
MV 1400 fps
MV 1900 fps
Is that your choreograph or what the the books says? I get 1900-1910 fps out of same powder load with Seirra 300 grain H.P.'s . I shoot a H&R Handi-rifle 22" barrel
I have killed deer at 225 yards with this load
Warning
These loads are safe in modern 45-70's only
Do not shoot them in antique guns !!!!!!!!!!!!!!!
