I bought the exact same kit about 2 years ago. Here's the finished product.
IMG_0215 by
MrKnobbie, on Flickr
I can explain exactly what I did, and in some places did wrong. This may follow much of what is out there, on this forum and others. The instruction here, on you tube, and knife forums is what ultimately got me to be a member here.
1. you will need to cover that blade- 2-3 layers of masking tape.
1.5. You should make a true to scale drawing of the side and spine profiles.
2. you need to cut that scale block in half lengthwise. This is more difficult than it sound unless you have a band saw with a guide. A pair of calipers helps too.
3. you should plane the scales flat. you might need to make a jig to hold the blocks. I nailed a couple 1/4 " pieces of wood to my bench at exactly the length of the block. I think that it is important to make sure the scales are close in thickness; again, the calipers help.
EDIT: I just noticed that the block is cut for you so ignore steps 2 and 3.4. outline the blade handle on one of the blocks. This is the time to pick your grain pattern, and to decide which side is the inside or outside of the scale.
5. Drill the main (big) holes using the blade as a guide. I can't remember the hole size but when in doubt go a little small. size up the bit by measuring the small part of the corby rivet. Be sure to clamp the blade to the block first.
6. make sure that the first hole is where you want it before drilling the second. maybe a better explaination is that you can re-align the second hole placement now, before you drill, if the blade has moved from your layout lines.
7. after drilling the second hole, make sure it will all line up on the handle, and will screw together. I can't remember how I did this part, but I might have used some dowels or something, or maybe some bolt I had laying around. If the fit is not perfect, you might use a needle file to make it fit a bit better. If it is way off- order a new block and make buttons out of that block.
8. figure out a way to put the liners and both blocks together and clamp it up tight. Make sure the blocks are aligned the way you want it. OPPS! I forgot to mention to clamp it up with the blade matching the holes! Drill through all parts- CAREFULLY. this is where a drill press would be helpful. Take your time, go slow. Use a sharp bit!
I gotta get back to work for a bit. I'll post back later today with additional instructions- If you want them...
