How to dye nylon pack fabric?
Roamer
Bushmaster
Jan 5, 2011
6,386
16,036
Sacramento, CA
I recently got a deal on a closeout Camelbak pack. It was a deal because it's a really ugly color: a bile-inducing neon green. I guess you might call it chartreuse.
The pack appears to be made of lightweight Cordura nylon. Does anybody know an effective and cheap way to permanently dye this material? Anything in the green/brown range would be awesome.
Kool-Aid? For real? Only problem there is I can't think of a Kool-Aid color that might be better...!
Maybe I'll just smear it in the mud real good.
Get one of those big 'ol Magnum 44 magic markers and a gas mask.
Wonder if that Rit dye from and grocery store cleaning isle would work. Have to go a darker color. Maybe soak it with coffee grounds and see what happens?
Or send it to me and we'll toss it in the next whites load...somethings been turning everything yellow...no clue why.
I have used acid-based dye to some success on a DCU ruck, I got it at joanne fabrics but I don't remember the brand. It's with the Rit, but Rit won't dye synthetics as it not acid based. Black or green would probably work out ok.
Thanks. I thought of trying coffee grounds. May give that a go as I'll probably soon try coffee on some leather as well.
the coffee grounds were a disappointment on my tarp project last summer, Twinsteel.
remember, I let it sit for a few weeks in coffee, then tea, then finally went to the Rit dye (which worked)
but nylon may be easier to dye...dunno.....
Believe it or not. Most of the men on military sniper teams spraypaint the patterns on their nylon packs. It works very very well. Just use flat camo spraypaint.
If you want a solid color stick with one color of paint.
i have dyed nylon gear, like DCU, and ACU. it comes out real nice if you take some time. the real problem with dyeing gear is you need to take into account the color you are starting off with. you need to play around with some material and dye before dropping your gear in as you could easily hate what it ends up being.
i did a big thread on dyeing gear on another forum. if you want to read all the info i put out, plus the recipe and steps used i could post it here. just let me know.
here is an example of what i have done.
MOLLE 3 day patrol pack in DCU before dye
same pack after dye
this is ACU after dye. i dont have before pics, but ACU is gray for the most part.
The dye job looks great darkside!
Twinsteel, I tried the cheap black powder dye, not Rit, from WM. I tried it on some Ranger green, ACU, and coyote 1000D nylon MOLLE pouches. (I think I either didn't let it sit long enough or tried too many pieces...) it darkened the coyote a little bit, did nothing to the ranger green (which had a lot of elastic anyway,) and "grayed" the ACU a little.
I'd say try the Jacquard or Krylon, or go throw it in the dirt for a bit! Then dye or paint it! LOL
Good luck!
I tried some coffee last night and it didn't do a damn thing. Wouldn't soak into the nylon at all. Maybe I had no idea what I was doing, but I just tried rubbing in some leftover coffee that I boiled down to thicken it up a bit.
Then I tried a Sharpie felt pen on a small area and that sure worked. But even though it's a small pack, it would take quite a bit of time with that small marker. I need to find something bigger as Gryphno suggested!
i prefer coffee on leather then to darken the coffee i apply a coat of olive oil. i used regular dye once and didnt like the having to rub it in a certain direction with a specific applicator under a certain temperature within a particular elevation on a lower populated continent.....
ok, so instead of start a new thread ill contribute to this thread keeping dye info in one place. this was originally poted on ZS.
the full thread can be seen here on ZS. there is a lot more pics and info on the original thread.
http://zombiehunters.org/forum/viewtopic.php?f=14&t=67780
here is one post that will give you most of the info you will need to get started.
STEP 1 - before any dyeing i washed this pack by hand in an 18 gallon bin with some laundry soap and some powdered oxy clean, and hung it to dry over night. i used about 1/2 of a cap of laundery soap and 1 scoop of oxy clean in warm water.
STEP 2 - i needed a container large enough for the pack so that it could be covered in water and would allow me to move it around. i used the 18 gallon plastic bin again. i turned on the tap in the bath to hot and waited a minute untill it was steaming, then i put the pack in the bin and filled it with just enough water to cover the pack. while the pack was soaking i used every large pot we had and boiled water on the stove.
STEP 3 - once i had the water boiling i mixed my dye. i used 12 tsp of rit golden yellow ( powder ) and 5 tsp of rit black ( liquid ) i bumped up my original mix quite a bit, more than i thought i would need to. this dye was mixed into simmering water and allowed to sit for a few minutes to let the granuals in the powder dye desolve. stir the dye mixture around very well to make sure you have all the granuals disolved. if teh yare not completly disolved you could get streaks.
STEP 4 - once my dye was mixed and my water was hot ( simmering ) i removed the pack from the bin, poured in my dye, poured in my simmering water, and put the pack bak in the bin.
STEP 5 - all i did at this point was stand over my MOLLE soup and agitated the bag pretty much non stop. i used a stick and kept poking and moving the bag around. every few minutes i would flip the bag. i think this is one of the most important steps to dying these packs. by constanly moving the pack and water around you are making sure you are getting consistant coverage. my pack has even color even behind the webbing and around flaps. i kept the pack in the dye bath for approx. 1 hour and 15-20 minutes.
i did something about half way through the dye bath. i wasnt sure i was happy at the coverage i was getting at that point. the material looked a bit "grainy" i know that i had read that acid dye was good for nylon, but i had also read that rit dye alone would work. i call BS on the latter. so i started thinking how do i get acid dye? well i had read about people using vinegar, so i looked in the fridge to see if we had any...looked in the pantry, and couldnt find any damn vineger....what to do?
we did have orange juice! a quick google search revealed that orange juice is about acidic as vinegar, so into the microwave went about 3 cups of orange juice. i nuked it to make it hot so it wouldnt drop the temp of my dye bath. within just a couple minutes i noticed much more even color and the pack seemed to suck up dye much faster and got alot darker. the OJ had pulp BTW! lol. i think there is something to be said about an acidic dye when working with nylon.
once i was happy with how dark the pack was i rinsed in warm water, then cool water. then i hand washed with just a little laundery soap and it was done.
thats about all i can think of at the moment.
the pack is a pretty sweet OD if i do say so myself. i am 100% satisfied with how this came out.
here are some pics with the pack next to different items of like colors. the two coyote EMT bags were purchased to ride on the sides on this pack, and they match pretty good. the camera plays tricks with the colors as does the incandecent lights. the buckles look like they are mustard/orange when in fact they are a great OD color. i will get the pack out tomorrow for some additional pics in natural light. THE PACK IS ACTUALLY A LITTLE GREENER THEAN IT LOOKS IN THE PICS.
as i mentioned. you will need to consider the original color of your gear BEFORE you dump it in a bin full of dye.
feel free to ask me any questions. i will try and help the best i can as i am no expert at this.
Well, wanting a quick fix, I decided to try the felt pen trick. I got a fat black permanent marker and spent about 15 minutes letting my inner graffiti artist run wild. I think it came out OK. Almost looks OD green.
BEFORE:
AFTER:
Did you add vinegar? Vinegar is what makes it stick.....
no ma'am...but that's good to know!
my thread was called "tarp tent coffee" and was on dying/darkening canvas.
I'm gonna be doing some nylon dying myself in the future....I'll think on the coffee/vinegar thing, thanks!
I should note I did this outdoors to avoid losing my faculties and fumigating my household! But it only took one pen, though I did have to let it rest at times as the tip would start to dry up from all the ink the nylon pack fabric was absorbing.
This is a small pack and I don't think I'd attempt this on something big.
Depending on what is coating your fabric and whether it is all nylon and no dacron, Rit will do nylon very nicely.
You need to check your dye to find out what will set it. Some set with an acid, like vinegar, some need hot water.
Twinsteel, I like the looks of your finished pack. I just hope that the ink doesn't fade to purple with the sun.
