I just got back in from playing in the woods, trying out this lesson
I decided to make the bow saw from a wire saw, choosing a bit of willow for the handle and using a bit of bootlace to tie it up with (well we always have those with us
After cutting my handle I tied the saw between two trees to notch the base to take one ring of the saw, the other end hooked securely onto a fork.
The tension on the saw started pulling one of the rings out of shape so I used the bootlace to secure it better
Then came the cutting!
I then moved on to the Bucksaw.
This I made using a Mora Bushcraft Survival knife, some Hazel, some cord from an MOD IPK (braided nylon) a fairly short (18"?) blade and a couple of key rings.
I would probably have done a neater job if I had not misplaced my glasses!
Batonning
fitting the parts together
lashing the joints
Tensioning
Then the cutting!
If you look closely you will see that one of the arms of the saw is actually bending under the tension I applied!
As the saw was "deep" between blade and crosspiece it took quite thick logs
Then came the wood splitting - and all I could find that I had not cut up already, was too rotted or too green was a bit of quite twisted oak...
It was hard on the hands but it worked!
Strangely enough it first split along the side /end I was holding...
The Bucksaw worked a lot better than the wire-saw bowsaw - boy was that slow! - but both blades worked better in the wood than on their own
