nock on string TuT
Keyser Söze
Chaos Muppet
Lifetime Supporter
Nov 26, 2008
17,893
37,750
Between Paradise&Hell
i had to install a new nock on new string so i took pics
what you need - Bow - string -bras nock-pliers, clip on string square , bow stringer
bras nock-pliers-clip
stringer-string the bow
measure and adjust string by twisting to 7-8"
put square on string and slide down on the rest barely touching the rug -not pressed down
measure 3/8" and put nock by hand not pressed
press nock with pliers-slightly
check with arrow then press hard the nock on string
Yer done
Nice tutorial Gaga, thanks.
I've not seen anyone put their string nock on top. Do you find it helps with prevent pinching the nock?
the nock is on top of the arrow always , you can install 2 , one down and one up, -
-But i like to use finger-savers -rubber slip on string tubes, that help if you shoot with a glove not to cut the circulation in your fingers -if you shot a lot ...like 1-2H with 12 arrows nonstop
I have mine set up with the nock under the arrow and use two fingers under. I wear a glove. I find having the nock under the arrow supports it and keeps my finger off of the arrow.
The nock on top helps keep the arrow from falling off the string, as the tip tends to pitch downward (the nock then pitches up).
Those bow square things seem like a great investment.
Another way to put a string nock is using dental floss. Same basic steps up to pinching the metal nock: at that point take a length of floss, and tie overhand knots until you have enough build up, and then tie it off. I then dab a bit of super glue on it an let it dry. If anything is poking out, I clip it with fingernail clippers.
Great Tutorial.
I've seen the finger savers and thought about buying them a time or two, but never got around to it.
MrKnobbie, I don't have a problem with the arrow dipping, but I'm not shooting broadheads, just field points right now.
bump, maybe you need to install a new string ....adding some more pics
don't forget to have fun...drink a cold beer slowly -it helps
Thanks. How 'bout a tut on building a stringer? My 55#'s are getting tougher as the years go by.
You musta had more than just one! youve gotten really good!
oowah oowah shoot thee arrow, oowah oowah shoot thee arrow. We gonna do the bow? I yanked a tendon the other day, but I might be able to shoot my 35#'er...
you need a 5 hour energy drink mixed with red bull mixed with Yerba mate , mixed with a SB grande .mixed with a Gatorade energy gel pack... and 5 drops of Bengay extra strength cream
